The "Z" Family Theater - Page 12 - AVS Forum | Home Theater Discussions And Reviews
Old 01-13-2011, 10:00 PM - Thread Starter
yamahaSHO's Avatar
/\\ What he said
If you want to look further into building one of these, do a search on this forum, Home Theater Shack, and/or Google for "Sonosub" and you'll find LOTS of these builds. Mine is very, VERY tiny compared to many of the builds out there. Also, check out the link below for sizing your build.
http://www.subwoofer-builder.com/sonosub.htm
You can use it in conjuction with WinISD (also freeware) to help really fine tune a setup.
EDIT: BTW, where in Iowa are you located?
-Jason
The "Z" Family Theater - Almost "complete".
-Not your average sub build
-Klipsch Sonosub Build
SONY quality and customer service FTMFL
yamahaSHO is offline
Old 01-14-2011, 09:17 AM
Jon_B's Avatar
Quoted: 25 Post(s)
Are you building this sub to save on costs? Or is it more for the experience and/or extra customization?
Jon_B is offline
Old 01-14-2011, 09:41 AM - Thread Starter
yamahaSHO's Avatar
Just for fun really. I had a spare driver sitting around doing nothing.
-Jason
Old 01-14-2011, 09:53 AM
Jon_B's Avatar
Quoted: 25 Post(s)
That's cool, it looks like it would be a fun project to do.
Jon_B is offline
Old 01-14-2011, 11:54 AM
edmove's Avatar
Jason, are you asking me about Iowa? If so I am in West Des Moines. If not, I am still in West Des Moines.
I have to say I spend a good hour looking on the web last night at the sonosubs. Very cool. I used to build boxes back in the 90's for my vehicles. I am going to pick up a sub in the next couple of week and see what I can build with the tube method. Pretty excited about it. I guess I will new need to get a sub amp as well.
edmove is offline
Old 01-14-2011, 10:03 PM - Thread Starter
yamahaSHO's Avatar
I built a few in the 90's as well, but aside from a refresh on the sub in my signature, I haven't built my own sub in at least 10 years. This is the last sub I built in 1999 or 2000... I could have gotten away with only one of those subs, but it was fun. I wish I had kept the drivers as I would have love to build a couple sono's with them.
Got a chance to do a little more work on my current build today. I'm going to get the other baffle glued tomorrow and then go use a drill press to drill my holes and install Hurricane Nuts.
With the gasket on the port, it sits just a tad high. Screwing it down should make it flush.
Couldn't find the "egg crate" stuff, but this should work. It's a bit more dense than the old egg crate stuff I have for my blow up matress which I purchased about 8 years ago.
Couple of questions... I know a lot of people use about 6" of fiberglass on the port end, but I really hate that crap. Anyone know of an alternative that won't be so nasty and is nearly as good. I've been searching the web, but I haven't really found anything.
Also, I've seen some like to dampen the port as well. I have quite a bit of extra Dynamat from a computer build and was wondering if it would be beneficial to stick that on the OD of the port and then wrap with some more of the foam. Any thoughts?
-Jason
Old 01-15-2011, 03:00 PM
Fastslappy's Avatar
Liked: 749
[/quote]Couple of questions... I know a lot of people use about 6" of fiberglass on the port end, but I really hate that crap. Anyone know of an alternative that won't be so nasty and is nearly as good. I've been searching the web, but I haven't really found anything.
Also, I've seen some like to dampen the port as well. I have quite a bit of extra Dynamat from a computer build and was wondering if it would be beneficial to stick that on the OD of the port and then wrap with some more of the foam. Any thoughts?[QUOTE\\]
I used Wal-Mart PolyFill batting
it's in the fabrics section get the thickest dbl it over or dbl it over agin
worked Great when I build the CornScala's
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
Old 01-16-2011, 12:01 AM - Thread Starter
yamahaSHO's Avatar
I might give that a shot and see how it does. I really don't like working with fiberglass.
-Jason
Old 01-16-2011, 07:12 AM
HuskerOmaha's Avatar
Quoted: 48 Post(s)
Liked: 45
Don't think you mentioned it...where did you get the egg crate stuff and what were they calling it?
HuskerOmaha is offline
Old 01-18-2011, 08:59 PM - Thread Starter
yamahaSHO's Avatar
It just a mattress pad found at Wal-Mart for $10 or so.
I couldn't help but try out the unfinished sub at the back-side of the theater and boy did it make HUGE and very positive diference. There is more even sound throughout the room and more importantly it moved lots of clean bass to the seating position.
I must say that this has exceeded my expectation. The Klipsch sono sounds very smooth, hits low and and still has plenty of output. So far, I have less than $100 in the build. My buddy came over to hear it and all he could say was "wow". He thought it made the original Klipsch box sound like a toy.
EDIT: I've been running test tones and 20's to low 30hz tones showed in projector movement, rattling sconces, and doors.
Anyway, I'm very happy. I've been playing some scenes from movies just to experience the bass!
-Jason
Old 01-18-2011, 09:36 PM
Quoted: 48 Post(s)
Liked: 45
Sweet!
I might not make it over to your pad for a few more weeks dealing with stuff here, but that sounds like a cool project...
Congrats on the newest sub!
Old 01-19-2011, 02:58 AM
Fastslappy's Avatar
Liked: 749
We need photos PLZ !
Mike
Old 01-19-2011, 10:50 AM - Thread Starter
yamahaSHO's Avatar
It's still not done, but here is what I have so far:
I need to find some time to go to the base wood hobby shop and use their drill press. Once that's complete, and I receive more Hurricane nuts, I'll be able to stain and poly the wood and then assemble.
-Jason
Old 01-20-2011, 12:16 PM
cuzed2's Avatar
Quoted: 98 Post(s)
Liked: 152
Nice workmanship - looking forward to the finished product !
Cuzed2
CuznEddy Cinema
cuzed2 is offline
Old 01-20-2011, 12:41 PM
edmove's Avatar
Great to hear that the performance is what you wanted or exceeding your expectations. I can't wait to build mine next month. What is the power rating of your sub and what are you putting into it? I am debating on what sub to use right now. Might get one of the e3.12 Sub from eD. Not sure if I need something to pump 800 watts into or just a few hundred. Thoughts?
edmove is offline
Old 01-21-2011, 02:12 PM - Thread Starter
yamahaSHO's Avatar
Thank you. I'm trying to figure out how I want to do the legs now to ensure they are symetrical and straight. I think I'm going to go with 1" wood doweling and use a 1" forstner bit to sink it in about 1/4" to both the baffle and bottom plate. I'll screw and glue it to the baffle, then just use a screw/bolt for the bottom plate... It sounds good in my head anyway.
I am not sure of the power handling of the subwoofer driver itself. In the RW-12d conifiguration, it is powered by a 350w BASH amp. I have this currently powered by a 300w PE BASH plate amp and it seems like it's doing just fine. I was considering the Oaudio 500w amp, but I think I'm just going to pick up another PE 300S. I wish I had purchased it before the new year as they were on sale for $100.
I actually am running this sub wirelessly with the Outlaw OAW3 and it's been working GREAT. I was afraid it might sound off running it wirelessly, but I can't tell a difference. This saved me from having to run a wire since I didn't plan on putting a sub in the rear from the beginning.
-Jason
Old 01-22-2011, 08:34 AM
cuzed2's Avatar
Quoted: 98 Post(s)
Liked: 152
Jason,
The countersunk dowel pegs sound like a good method for mounting the base. Are you going to run it as shown with the driver up, and the port down?
I wonder if you might want the dowel pegs longer to increase the gap between the cylinder and the base, so that it can breathe a bit easier?
Cuzed2
CuznEddy Cinema
cuzed2 is offline
Old 01-22-2011, 02:41 PM - Thread Starter
yamahaSHO's Avatar
I will actually be running it as a downfiring sub, but had to turn it up to test without bolting anything together. My SVS have a 2" gap, so I was looking at 2-2.5" gap on mine.
I think the upfiring looks cool, but I'd have to run a grill on it all the time as it would be easy to damage.
-Jason
Old 01-22-2011, 02:46 PM
Fastslappy's Avatar
Liked: 749
make the bottom plate outta MDF & make it DDb thick that way you get a strong reflection off of it
Mike
Fastslappy's Avatar
Liked: 749
Iron plate is actually the best !
Mike
Old 01-22-2011, 02:54 PM - Thread Starter
yamahaSHO's Avatar
I actually have plywood ready to be cut for it. I was looking to put a 3/4" and 1/4" pieces together to make an inch thick plate.
What's the need for a strong reflection? It won't absorb the frequencies coming out of this thing.
-Jason
yamahaSHO's Avatar
-Jason
Old 01-22-2011, 03:01 PM
Fastslappy's Avatar
Liked: 749
down firing woofs need a solid reflection off the base plate the better the reflection ,the tighter the bass
plywood is too absorbing ,It's just not dense enuff
Mike
Old 01-22-2011, 03:12 PM
Fastslappy's Avatar
Liked: 749
of all your structures in your sub the base plate is most important
as the port is to size
Mike
Old 01-22-2011, 03:15 PM - Thread Starter
yamahaSHO's Avatar
I wouldn't imagine the wavelength being produced would be effected by the difference of plywood to MDF base plate.
The are quite a few downfiring subs tha do not use a plate and actually suggest to be placed over carpet. Where are you getting your information?
-Jason
Old 01-22-2011, 03:24 PM
Fastslappy's Avatar
Liked: 749
a SVS sales rep told me that on the phone ,when I asked about the baseplate on the PC12-NSD
Mike
Old 01-22-2011, 03:30 PM
Fastslappy's Avatar
Liked: 749
i'd be easy to add later if U feel like it
seeing how U have the plywood already , just saying there is a reason why they don't use plywood in speakers any more
Mike
Old 01-22-2011, 03:33 PM - Thread Starter
yamahaSHO's Avatar
SVS uses plywood
I've seen more and more speakers using plywood these days.
-Jason
Old 01-22-2011, 03:50 PM
Fastslappy's Avatar
Liked: 749
paste from SVS website ..
Thousands of hours go into optimizing the materials, finish, bracing, and layout of every SVS, box or cylinder. Using state of the art computer assisted design (CAD) and our relentless regimen of simulations and extensive real-world measurements, no other manufacturer makes a more robust and acoustically inert subwoofer enclosure than SVS. Using a 1" medium density fiberboard (MDF) core with extremely high grade clear real wood veneers or high-tech, high-fashion black finishes, these subs make a statement
the base plate on my PC12-NSD's are MDF 1" thick
Mike
Old 01-22-2011, 04:00 PM - Thread Starter
yamahaSHO's Avatar
I own two PC12-NSD's and pulled back the fabric a little and there is plywood. Also: http://www.avsforum.com/avs-vb/showt...1#post15335691
I can't tell you what my base plate is made out of, it's laminated. How did you determine what yours is made of?
My response was to your plywood comment on current speaker builds. I'm sure SVS also used MDF (especially on the boxes), but what I have seen so far with the cylinders is plywood.
-Jason
