The "Z" Family Theater - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #391 of 413 Old 02-10-2011, 11:28 AM
Fastslappy's Avatar
Liked: 749
Originally Posted by yamahaSHO View Post
I like this better.
WoW that's looking Very Professional ...
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
post #392 of 413 Old 02-13-2011, 04:45 PM - Thread Starter
yamahaSHO's Avatar
Got the wood stained and poly'd. I'm going to give it a few days to set up and then glue the ends and throw some weight on them.
And the part that that looks nice, but won't be seen...
-Jason
The "Z" Family Theater - Almost "complete".
-Not your average sub build
-Klipsch Sonosub Build
SONY quality and customer service FTMFL
yamahaSHO is offline
post #393 of 413 Old 02-13-2011, 04:52 PM
Fastslappy's Avatar
Liked: 749
Looks Very Nice Jason !
Mike
post #394 of 413 Old 02-17-2011, 04:31 PM
cornfedksboy's Avatar
Do you still like the 100" screen, or do you wish you would have gone bigger?
cornfedksboy is offline
post #395 of 413 Old 02-17-2011, 04:40 PM - Thread Starter
yamahaSHO's Avatar
For 16x9 material, it's great. I did wish I had gone with a 2.40:1 for a little while keeping the same screen height, but after installing TMT5, I can zoom the really wide stuff to fit 16x9... I hate black bars no matter where they're at.
So yes, I'm quite content with the 100" screen.
-Jason
post #396 of 413 Old 02-21-2011, 08:58 PM - Thread Starter
yamahaSHO's Avatar
Little more progress. I got the bottom end cap glued on with some Loc-Tite PL Premium. I tried pulling the plastic liner off in the tube, but it wanted to pull too much paper off as it went around. I ended up sanding it off instead.
I put several coats polyurethane on the ID of the tube to seal it off. I wanted to get all plastic off, but since it was a pain, I decided to just seal it in.
I took this pic to reference size.
Now I got that I have the interior of the tube all sealed up and the end caps glued on. Both my 1/2" plywood boards (top/bottome) didn't exactly center up with the MDF and I knew it would give me some more work when I got to this point.
Because I'm trying to make this look like my SVS, I only want to put a single layer of velvet on the sub and want it to be smooth. Since the endcaps both over hang one direction 1/16" (or less), I need some type of filler that will adhere to the polyurethane finish and glue, does anyone have recommendations for this? All I want to do is build it up and smooth it out into the tube so you wan't notice anything when the sock is on. I should have done like SVS and made the caps just slightly smaller than the OD of the tube and center it... I'd be only needing the sock at that point if I had.
I tried to use the glue to smooth it out... But that didn't turn out like I hoped.
As always, I love pics:
When I build another one, it'll be much faster, I've figured it all out now.
-Jason
post #397 of 413 Old 03-09-2011, 10:57 AM - Thread Starter
yamahaSHO's Avatar
Small picture updates. More can be found in my build thread.
-Jason
post #398 of 413 Old 03-09-2011, 11:13 AM
Brad Horstkotte's Avatar
Liked: 69
Looks awesome - you're really going to have to start a sonotube sub business.
Brad Horstkotte is offline
post #399 of 413 Old 03-09-2011, 11:43 AM
Fastslappy's Avatar
Liked: 749
Wow ! great job Jason !
how's it sound now with the three ?
Mike
post #400 of 413 Old 03-09-2011, 11:44 AM
Fastslappy's Avatar
Liked: 749
Hey did U get those grills from Madisound ??
look just like the ones I using for my CS-1.5's 2 piece right ?
Mike
post #401 of 413 Old 03-09-2011, 11:52 AM - Thread Starter
yamahaSHO's Avatar
Thank you, but I don't think SVS would be happy if I sold them looking like this.
I do have a few friends that want me to build them some Sonosubs, so I think I'll help them build them.
Most of them have spare drivers that they want to put to use.
I have to take a day to seriously address sub placement right now. I get better bass from one sub in my green room than I do with any amount of subs in my theater.
http://www.parts-express.com/pe/show...number=269-972 - They look EXACTLY like the ones on my SVS.
-Jason
post #402 of 413 Old 03-09-2011, 12:04 PM
Fastslappy's Avatar
Liked: 749
Yeah @ the time Madisound had a better price & parts express didn't have those in stock now it's the reversed PE has the best price
same grill .. but they are Very nice !
Mike
post #403 of 413 Old 04-20-2011, 08:12 PM - Thread Starter
yamahaSHO's Avatar
I picked up an external sound card and gave REW a shot and did a comparison with my Klipsch Sono before and after the 8033 EQ as well as the same with the SVS.
Here's what I came up with:
Klipsch Sono vs SVS PC12-NSD w/ NO EQ:
Klipsch Sono vs SVS PC12-NSD w/ Anti-Mode 8033 EQ:
Klipsch Sono before and after 8033:
SVS PC12-NSD before and after 8033:
Klipsch Sono Waterfall w/ NO EQ:
Klipsch Sono Waterfall w/ Anti-Mode 8033 EQ:
SVS PC-12 NSD Waterfall w/ NO EQ:
SVS PC-12 NSD Waterfall w/ Anti-Mode 8033 EQ:
I suppose my Klipsch Sono is doing pretty well and is a farily close match to my SVS.
-Jason
post #404 of 413 Old 11-16-2011, 07:30 AM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
Jason
Whats been up? you finish up the basement yet
Scott
The CopperFields Cinema
          Current Photo's
W00lly is offline
post #405 of 413 Old 11-16-2011, 11:31 AM - Thread Starter
yamahaSHO's Avatar
Hey Scott,
I still need to build the fabric frames, paint the doors and put trim around the rack, but it's done for the most part. It's true what they say; once you put the projector up, work slows down drastically. I also lost a lot of motivation in actually working on it as I use the theater all the time for gaming.
-Jason
post #406 of 413 Old 01-20-2012, 09:09 AM
cdika17's Avatar
Any updates!?!
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #407 of 413 Old 01-20-2012, 10:07 AM - Thread Starter
yamahaSHO's Avatar
Honestly, not really. The green room got curtains and such and was converted into a toy room for my daughter as we never used the room.
The theater really has no change as I got really tired of working on it and everything is functional. Maybe I'll get to the final touches this winter.
-Jason
post #408 of 413 Old 01-20-2012, 03:59 PM
hanesian's Avatar
Quoted: 36 Post(s)
Liked: 84
Winter is almost over now
I wish.
The Un-Theater Un-Build
hanesian is offline
post #409 of 413 Old 01-20-2012, 04:08 PM - Thread Starter
yamahaSHO's Avatar
It hasn't even been "Winter" for a month yet.
alekhp likes this.
-Jason
post #410 of 413 Old 12-04-2014, 04:05 AM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
Jason
I cant believe that the last post to your thread was in 2012 we need to have a movie night and shoot the sh%t
Scott
          Current Photo's
W00lly is offline
post #411 of 413 Old 12-04-2014, 08:09 AM - Thread Starter
yamahaSHO's Avatar
I haven't posted because I haven't done anything to the basement/theater other than remove a few things due to very low usage. I need to finish the fabric panels around the screen, paint the doors and trim the rack we built. Other than that, it's been done but largely unused.
I have been meaning to get ahold of you recently. I'll have to stop by soon.
-Jason
post #412 of 413 Old 12-04-2014, 09:30 PM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
I'm off work for the winter so daytime is great time for cranking up the SUBS drop by any anytime How old is Honor now my youngest is turning 14 next week man I cant believe how time flies.
Scott
          Current Photo's
W00lly is offline
post #413 of 413 Old 09-23-2016, 07:58 PM - Thread Starter
yamahaSHO's Avatar
It's been some time since I posted here, but now I'm onto a new setup. I moved from Omaha to Denver this year and it took me a good 3.5 months to find a house and beat and outbid anyone else interested. I don't plan to do a dedicated space again as it didn't get used, so now I'll be making the living room more entertainment-centric.
I kept most of the equipment from my basement theater build minus the projector/screen, floor standing center channel, and two SVS subs. I did keep the Klipsch sonosub build and plan to use it as the only sub due to keeping the clutter in check.
The new house is definitely a bit different than the previous, but we're happy with it so far. It is on a mountain...
And this is the view from the living room.
Starting to unpack. The idea I have now it to remove the really high mantle above the fireplace and build my own, but also make it a center channel speaker. It will also be lowered a good amount so that the TV isn't so high. As for the TV, I picked up a 55" Vizio P-series 4K w/ HDR.Google Cast TV. I wanted to get a bigger TV, but it would over-hang the sides of the fireplace.
-Jason
