The "Z" Family Theater - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 02-25-2010, 11:09 AM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
Jason
I would like to come down and check out those light switch's whens a good time ?
Scott
The CopperFields Cinema
          Current Photo's
W00lly is offline
Old 02-25-2010, 11:12 AM - Thread Starter
yamahaSHO's Avatar
I get off work at 4:30... I'm pretty free since I'm living like a bachelor for the next few weeks. You can stop by anytime after then!
-Jason
The "Z" Family Theater - Almost "complete".
-Not your average sub build
-Klipsch Sonosub Build
SONY quality and customer service FTMFL
yamahaSHO is offline
Old 02-25-2010, 11:22 AM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
I think I will swing down tonight after dinner if thats cool
Scott
          Current Photo's
W00lly is offline
Old 02-25-2010, 12:18 PM - Thread Starter
yamahaSHO's Avatar
Come on over! I think I'll be building a computer and maybe mopping the floor in the theater for some leveler.
-Jason
Old 02-27-2010, 04:29 PM - Thread Starter
yamahaSHO's Avatar
Okay, here are a few better pictures The trim came in today and will be put in this week.
Got the Superseal All-in-One floor in:
Yes, I have some touch-up work to do on the paint.
Theater
Closet coming along...
-Jason
Old 03-02-2010, 12:11 AM - Thread Starter
yamahaSHO's Avatar
I started installing the floor in the closet today, but ran out of planks... Between destroying a few planks and under-estimating the job, I have to go pick up some more material.
I first used some self-leveling compound which I appeared to have missed a spot or two I then laid down the Superseal floor followed by some dense foam material before the laminat floor. I really love the way this stuff looks, however, I may be pulling it out to re-level the floor. The two spots just irritate the crap out of me when I step on them.
-Jason
Old 03-02-2010, 07:52 AM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
Looking good Jason I really like the color you chose for the theater room.
I think I will swing down tonight if thats OK with you.
Scott
          Current Photo's
W00lly is offline
Old 03-02-2010, 08:29 AM - Thread Starter
yamahaSHO's Avatar
Sure thing, stop on by! I'll be removing the floor I put in last night to do a better job at leveling. I hope I don't have to do any grinding....
I should be home after 6:30, as I have to stop at NFM after work.
-Jason
Old 03-03-2010, 04:11 PM - Thread Starter
yamahaSHO's Avatar
Quick update... I pulled the floor out yesterday and used a 50lbs bag of leveler and it's looking much better. There are a few small dips now where the leveler didn't completely mesh with itself while drying. I will use some floor patch to smooth that out.
I will likely not have the floor ready before trim tomorrow, so I will have to have everything but the closet done. I want to make sure the floor under the wood/laminate is completely flat or I'll kick myself later.
-Jason
Old 03-04-2010, 08:52 PM
red2003cobra's Avatar
Looks good. I like the lights.
Lance
red2003cobra is offline
Old 03-21-2010, 09:40 PM - Thread Starter
yamahaSHO's Avatar
I need to get some sand and plywood, but the stage is almost done! This is the last thing needed before carpet!
-Jason
Old 03-22-2010, 08:37 AM
cuzed2's Avatar
Quoted: 191 Post(s)
Liked: 247
Looking good Jason!
Cuzed2
CuznEddy Cinema
cuzed2 is offline
Old 03-23-2010, 02:12 AM - Thread Starter
yamahaSHO's Avatar
I went to get some sand today at Menards and all of it was completely soaked like it had been stored outside. I am going to try Lowes and Home Depot tomorrow and see what I come up with. I may have to lay it out on some plastic in the basement with the dehumidifier on for a day or so....
On a side note... I am going to pull up the laminate floor once again. There is a high spot I just can't live with right when you walk in and it will require I pull half the floor and grind it down. Everything else I did for leveling feels pretty good though.
-Jason
Old 05-23-2010, 09:20 PM - Thread Starter
yamahaSHO's Avatar
Ha! Bumping a dead thread!
I gotta say THANKS to Scott (W00lly) for coming out with his saw/tools/truck and helping me finish up the stage. It's done and awaiting carpet. It's completely filled with sand and boy is it solid.
My camera ran out of a power after this shot, so this is what I have for now.
On a side note... To get the project done, I've pulled up the woold/laminate and will be installing carpet in the closet.
EDIT: Better Picture.
-Jason
Old 05-23-2010, 09:55 PM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
Now I need to get myself in gear and do some work in my basement.
Can't wait to see it finished Jason its going to look really nice.
Scott
          Current Photo's
W00lly is offline
Old 05-24-2010, 07:52 AM
jelloslug's Avatar
jelloslug is offline
Old 05-24-2010, 06:33 PM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
Jason
I tried that sample of the center stage XD fabric and its amazing how much brighter that piece is then the SMX I do believe an upgrade in fabric will be happing later this summer
I mite have to snap a photo so you can see the difference
Scott
          Current Photo's
W00lly is offline
Old 05-25-2010, 12:19 PM - Thread Starter
yamahaSHO's Avatar
Wow, is it really that much brighter? I guess I could upgrade later, but I've got my old material (just like yours) that I haven't even used yet.
I'd like to come check it out sometime.
-Jason
Old 05-25-2010, 08:56 PM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
I think I will order the 2'x2' piece for a better test
Scott
          Current Photo's
W00lly is offline
Old 05-25-2010, 09:01 PM - Thread Starter
yamahaSHO's Avatar
I am interested to see the results. I can see it being brighter due to the tighter weave not allowing as much light to pass through.
-Jason
Old 05-26-2010, 07:02 AM
78f1hundo's Avatar
In the last picture.
What is the height you went with for the sconce height from the floor?
Steve
78f1hundo is offline
Old 05-26-2010, 08:27 AM - Thread Starter
yamahaSHO's Avatar
I'll have to measure when I get home. Are you looking from ground to the center of the light/electrical box?
-Jason
Old 05-26-2010, 11:52 AM
premiertrussman's Avatar
Quoted: 17 Post(s)
When i saw your screen name i wondered if thats what it was referring too.
When i turned 16 i had a 94 Taurus GL. I wanted a SHO so badly but anything i could afford had like 250k miles on it! Thats a sharp lookin SHO, gratz.
_____________________________________
Shades of Grey Theater
Currently Playing: Overwatch/WoW - Legion
premiertrussman is offline
Old 05-26-2010, 08:18 PM
78f1hundo's Avatar
Bottom of the electrical box would be cool.
Old 05-27-2010, 01:52 AM
couillerot's Avatar
wonderfull !
great colours ;-)
Stef
couillerot is offline
Old 05-27-2010, 07:38 AM - Thread Starter
yamahaSHO's Avatar
Will do. I'll measure today for you.
Originally Posted by couillerot View Post
wonderfull !
great colours ;-)
Stef
Wow, all the way from France! Thanks!
-Jason
Old 05-27-2010, 02:21 PM
couillerot's Avatar
yes !
it's really interesting to discover the "american touch" (design) about personal home theater ; really different from what we can see in europe ;-)
Stef
Old 06-01-2010, 01:12 PM
78f1hundo's Avatar
Any luck?
Old 06-01-2010, 01:24 PM - Thread Starter
yamahaSHO's Avatar
Any luck?
HA! Sorry, I completely forgot. I'm sending myself a reminder e-mail to measure them tonight. Sorry about that.
-Jason
Old 06-02-2010, 06:41 AM - Thread Starter
yamahaSHO's Avatar
It's roughly 70" to the center of the fixture/electrical box.
-Jason
