Scawt's HT Build Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 96 Old 09-25-2008, 06:58 PM - Thread Starter
Scawt's Avatar
Welcome to Scott's home theater and addition build. Thanks for the great info from the AVS guys, it was definitely a learning experience and still is a work in progress!
Updates are on page 3, here is a recent pic of the 2.35 acoustically transparent screenwall in progress
pics of the speakers going in
Scawt is offline
post #2 of 96 Old 09-25-2008, 07:48 PM
ndabunka's Avatar
Quoted: 552 Post(s)
Liked: 225
Square rooms (19x19) are bad for audio. Many here would extend the wall where that room inside your room is to make it more like 19x14
Epson 5040ub Projector, Elite Screens 120" Saker AUHD, Yamaha RX-A3060, B&W Speakers: Signature 7's, FMP4, CWM7.5s, CCM65s, Rythmik 15" CI Sub, 30' Monoprice Cabernet Ultra CL2, Tiara CI-Pro Series In-wall wiring, Phillips BDP7501 UHD BD Player, Niles 1230 WHA Amp, Xbox, WiiU, TiVo Premiere
ndabunka is offline
post #3 of 96 Old 09-25-2008, 07:53 PM
MohaimenK's Avatar
See, that is true, but there are so many theaters that are in square shaped...
What if the room has very good acoustic dampning? (Is that the correct term?)
Hmmmmm What to write?
MohaimenK is offline
post #4 of 96 Old 09-25-2008, 08:41 PM
MohaimenK's Avatar
Actually, scawt, here's an article I found, that might be useful for you as well.
How to properly treat a Square room:
http://studio-central.com/phpbb/viewtopic.php?t=45170
post #5 of 96 Old 09-26-2008, 07:59 AM - Thread Starter
Scawt's Avatar
Thanks for the link! Any other suggestions/comments on layout? I'm going to the depot today to pick up more wood for the riser, and finish up the wiring this weekend.
Scawt is offline
post #6 of 96 Old 09-26-2008, 08:09 AM
MohaimenK's Avatar
Well, is there a way for you to show us actual pics of the room? That way we'd know what's been done and what's there to do. That'd help a lot and make it easier for us.
post #7 of 96 Old 10-28-2008, 05:51 AM - Thread Starter
Scawt's Avatar
Any suggestions on the projector mount? Wall vs. ceiling for the Panny 3000?
Scawt is offline
post #8 of 96 Old 11-22-2008, 12:15 PM - Thread Starter
Scawt's Avatar
Made some progress over the weekend, since its just me at the house now
Mid atlantic 24U rack rails and a couple shelves. Thoughts on using the right side for a DVD rack or just insulate over it?
Back of the rack, took a long time to clean up the wiring
Spent some cash on Blue Jeans Cables (3 series 1 HDMIs & a component). I still have room in the conduit for more wires, also lots of mounting points for the projector in case it needs to be moved.
Here is the screen wall and the insulation is finally done in the theater room. Still need to finish up the rest of the addition in order to get the insulation inspection.
Mounted the Klipsch ceiling speakers & enclousures in the master bath. These are wired into the closet too.
Scawt is offline
post #9 of 96 Old 11-22-2008, 01:30 PM
smokinghot's Avatar
WOW.... 3 HDMI to the projector...? May I ask what prompted that..?
smokinghot is offline
post #10 of 96 Old 11-22-2008, 05:40 PM - Thread Starter
Scawt's Avatar
Lots of beer at the time of purchase, and multiple video inputs. I already have 13 speakers a couple subs running to the closet, so might as well add in some more HDMIs.
Scawt is offline
post #11 of 96 Old 11-22-2008, 06:50 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Yeah, I was thinking the same thing. Scawt, doesn't your AVR have HDMI switching?
CD
CDLehner is offline
post #12 of 96 Old 11-22-2008, 06:55 PM - Thread Starter
Scawt's Avatar
Nope, it's an older Yamaha THX that doesn't have HDMI. I'll upgrade later, so shouldn't be a problem
Scawt is offline
post #13 of 96 Old 12-04-2008, 04:54 PM - Thread Starter
Scawt's Avatar
Yeah, finally have some progress:
Ordered two buckets of GG, GG dispenser, and putty pads from Soundproofing Company (Ted)
Finished insulation in the addition
Insulation inspection is next week
Getting quote for drywall in the HT room
Scawt is offline
post #14 of 96 Old 01-01-2009, 11:17 AM - Thread Starter
Scawt's Avatar
Last update for the addition and HT room until the drywall is done:
I officially hate insulation now. I'm never doing this again by myself. The walls were fine, but ~15ft vaulted ceilings in the master bedroom weren't fun.
looking the other direction
So the plumber hooked up the tub and it was leaking from the jet lines. I'm glad the spa company replaced the part/labor under warranty, but still have to put the POS back in the hole
Built the final two inwall speaker boxes for the theater room. I'm glad those are finally done. The windows will have hinged cover eventually.
Picked up the last two surround speakers
I've never been so happy to have two buckets of glue
I should have put the putty pads on before the insulation, but didn't think about it till later. I'm glad their in before drywall though.
I had my electrician friend come back and wire in two dedicated 20A for the a/v closet. The 15A is the outlet below. I feel a lot better now
I'm waiting for some more rack shelves to come in and faceplates from stayonline. Custom PS3, XBOX, etc..
Scawt is offline
post #15 of 96 Old 01-01-2009, 09:48 PM
aluminumangel's Avatar
Wait until you try to hang the drywall on those ceilings. I ended up solving that little issue with the ol' checkbook. Goes against all my DIY street cred, but my lower back is more important.
"Cheap, Fast, Good... pick any two."
Visit the home theater build thread...
LOGANED 12/31/08
aluminumangel is offline
post #16 of 96 Old 01-02-2009, 05:58 AM - Thread Starter
Scawt's Avatar
Good advice. I think I'm going to do the same thing, I don't want to deal with the drywall on a project this big. I had my drywall/sanding/mudding experience with the kitchen remodel already
Scawt is offline
post #17 of 96 Old 01-02-2009, 07:22 AM
jamis's Avatar
If you are planning on putting a door (such as glass) on your equipment rack, I would recommend setting the rails back at LEAST 3 inches to allow for knobs, buttons, and other protrusions from the equipment.
My rack is set back about 2.5" and its BARELY adequate for my glass door.... it's good enough that I don't want to dismantle the whole thing to move it back .5-1"... but annoying enough that I wish I had..
jamis is offline
post #18 of 96 Old 01-02-2009, 10:14 AM
Quoted: 3255 Post(s)
Liked: 2743
If I'm not mistaken that is actually one dedicated 20A hooked up to four outlets. You would need two runs of the yellow romex for two dedicated 20A. Don't worry you should be fine.
However you do have a code violation of using a 20 amp receptacles on the 15 amp circuits. I also spotted one next to the bucket of GG. I suspect you bought them for every outlet?
A few locations are now also expecting the ground plug to be on the up side for new construction.
Theater looks like it is coming along great.
post #19 of 96 Old 01-02-2009, 10:33 AM
Liked: 2743
post #20 of 96 Old 01-02-2009, 10:35 AM
Vcook's Avatar
I noticed that too, 20amp outlets on 15amp circuits is a no-no.
Vcook is offline
post #21 of 96 Old 01-02-2009, 12:02 PM
warrenP's Avatar
Liked: 60
... A few locations are now also expecting the ground plug to be on the up side for new construction. ...
Yep, our house is one of those. Ground plug up, thankfully we found out (from a neighbor who also built his own home) about that before I wired them in - otherwise I'd be redoing the entire home.
Looking forward to more pics! BTW, I'd second the $$$ on the drywall - going high and vaulted, etc... not too much fun. I don't think it will hit the cred too much. ;-)
Every man dies. Not every man really lives.
warrenP is offline
post #22 of 96 Old 01-02-2009, 12:16 PM - Thread Starter
Scawt's Avatar
Thanks for the heads up guys! I'm going to give him crap about the outlets, so they will get fixed before final inspection.
I'm pretty sure the two 20A are on a single 12/3, so I guess they are not dedicated.
Scawt is offline
post #23 of 96 Old 01-02-2009, 12:31 PM
Liked: 2743
Dedicated means that the line comes from your breaker box directly to the outlet box with nothing else connected that consumes power or more importantly for HT that introduces some interference or ground loop issues into the system.
Your two duplex outlets (4) connected to the yellow Romex are probably dedicated.
post #24 of 96 Old 01-02-2009, 01:07 PM - Thread Starter
Scawt's Avatar
Aww, I thought they had to be separate runs for each outlet to be dedicated, but yes he ran it directly to the box. Thanks for the info!
Scawt is offline
post #25 of 96 Old 01-02-2009, 09:47 PM
dk-customs's Avatar
If the run is 12/3, then it can be wired as two dedicated 20A by sharing the ground and neutral. In the breaker box the black to one breaker, red to another breaker, white to neutral, and bare or green to equipment ground. Caution if you use half size or tandem breakers, be sure to plug the black and red onto opposite legs of the panel.
I also think it's a good idea to use a 2 pole breaker for a shared neutral circuit. The down side is when one breaker trips, it trips the other as well.
dk-customs is offline
post #26 of 96 Old 01-25-2009, 05:53 PM - Thread Starter
Scawt's Avatar
I'm leaving to Sandy Eggo for a week, but here are some updated pics:
Scawt is offline
post #27 of 96 Old 02-05-2009, 08:19 PM - Thread Starter
Scawt's Avatar
I love the green stuff
I can't wait till I can paint and cover the windows. I'm going to Lowes tomorrow to pick up some black and a dark red for the theater room. I'll test out of some other colors too.
Guest bedroom:
Going upstairs:
Master bedroom, bath and closet :
I should be able to finish the flooring next week for the hallway and guest bedroom. I'm going to pay for the carpeting since I don't want to do that again.
I still can't decide whether to do the AT screen, but I'm definitely leaning towards it after all of the threads that I read. I need to start sketching some ideas out.
Scawt is offline
post #28 of 96 Old 02-05-2009, 08:25 PM
queendvd2's Avatar
Looking good! Love that you put ceiling speakers in the master bath-very cool. Vaulted ceilings look great too.
queendvd2 is offline
post #29 of 96 Old 02-05-2009, 08:40 PM - Thread Starter
Scawt's Avatar
Thanks! I'm trying to figure out what to do with the 4 zones and the volume control. I ran speaker wire and extra Cat5e to zone 2 and 3 from the rack, but 4 got neglected and is outside without the Cat5e. I want a single receiver to control everything, but 7.2 plus 3 other zones is getting complicated
Scawt is offline
post #30 of 96 Old 02-06-2009, 05:49 AM
queendvd2's Avatar
I'd be curious how you achieve that. In my own build (7.2 for HT and 2ch for ceiling speakers in the playroom), my installer had me pick up a separate 2ch receiver, aside from the Marantz AVR8003 driving the dedicated theater. I had just assumed that the ceiling speakers could share the Marantz with the HT.
