My Ridiculously Inexpensive Dedicated KICK *** Home Theater! <<The Sequel>> - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 362 Old 01-08-2009, 06:53 AM
In2Photos's Avatar
Originally Posted by docprego View Post
Thanks for those ideas. Lowes did have a bracket which would work but they did not have a rod long enought that would fit in the support channels of the bracket. You're idea to use a dowel might be the solution. I could get a dowel thick enough to be supportive that will fit the bracket. Metal pipe might work too but I guess that would be a lot heavier and much more difficult to cut.
Actually the metal conduit available for electrical work is very easy to cut. You can use a hacksaw, jigsaw, or even one of those pipe cutters since it is hollow.
Mike
In2Photos is offline
post #182 of 362 Old 01-08-2009, 08:22 PM - Thread Starter
docprego's Avatar
Update: I found a perfect curtain rod at Bed Bath and Beyond today. It was a bit pricey, $48 after 20% off coupon, but it was worth it. I am hanging it and the curtains right now. Pics coming later....
My Ridiculously Inexpensive Dedicated Kick *** Home Theaters!
RIDKAHT <The Original>
RIDKAHT <<The Sequel>>
RIDKAHT <<<Part III>>>
docprego is offline
post #183 of 362 Old 01-09-2009, 12:25 AM - Thread Starter
docprego's Avatar
It's done! I cannot believe how incredible it came out. It is so nice that I found the lights I had purchased were concealing a lot of the beauty, I removed them! Either they find a new spot in my room (not likely) or they go back to Target. I just couldn't hide the beauty of the velvet curtains with a couple of lamps. Some of you out there are going to tell me my speakers are too low again, I know, I can live with it.
In this shot I am almost half done hanging the curtains. I hung all the panels with the plan that I would cut down the ones over the screen later once everything was hung. You can see the ugly BOC I needed to conceal, it was really the inspiration for this project.
A mess of curtain supplies:
The bracket from the rod I found mounted on the wall:
The rod sitting in the bracket:
And the final product which I have to say looks even better in person, my camera had a really hard time filming this:
Between lowering the screen and the curtains I am now in HT nirvana!
docprego is offline
post #184 of 362 Old 01-09-2009, 05:40 AM
In2Photos's Avatar
WOW! Looks great!
Mike
post #185 of 362 Old 01-09-2009, 04:02 PM - Thread Starter
docprego's Avatar
WOW! Looks great!
Thank you! I am thrilled with how it turned out, way exceeded my expectations. When my wife walked in to see it for the first time this morning she was stunned and said it made the room feel like a true movie theater. I am so glad I went with the burgundy, it is a beautiful color.
For anyone interested these were on clearance at Bed Bath and Beyond for $14 for each shorter panel and $22 for the longer ones. That's cheap for velvet curtains.
docprego is offline
post #186 of 362 Old 01-09-2009, 05:32 PM
SatelliteGuy's Avatar
Looks great! I'm trying to figure out just how you hung the screen in front of the curtains. I believe you hung the screen on the wall and used long curtains on the sides and short curtains on the top and bottom using a rod at the top and one at the bottom. Is this correct?
Rinker Family Cinema Construction Thread:
http://www.avsforum.com/avs-vb/showt...ghlight=Rinker
SatelliteGuy is offline
post #187 of 362 Old 01-09-2009, 08:05 PM - Thread Starter
docprego's Avatar
Thanks. Here is how I did it.
1.Hung Elite EZ Frame screen at the desired height.
2.Found a curtain rod that could expand to span my entire front wall of 139".
3.Test fit a curtain on the rod to see where the brackets would need to be mounted in order for the curtains to be flush with the ceiling which was my desired look.
4.Once I knew the bracket mounting position I installed all 3 brackets that came with the rod at the same height.
5.Hung all curtains on the rod. I used a 108" panel on the left of the screen and another on the right so that it would go exactly from the celing to the floor, I have 9 foot ceilings.
6.I purchased the shortest matching panels I could for above the screen knowing that I would be cutting them down anyway, these were 84".
7.At this point the entire front wall was concealed in curtains including the screen, the only thing not covered was the area below the 84" panels to the floor.
8.Next I cut the material away from the 84" panels leaving enough to tuck behind the screen. When I started I cut too much away on the far right, it actually does not go behind the screen but rests on top, you can't tell from ground level anyway.
9.Then I used the material I cut away from the top of the screen to tack beneath the screen to complete the effect. Since the cut away portions were the lower ends of curtains I just oriented these pieces as if they were curtains hanging, that is the hemmed part at the bottom of the curtain rests on the floor while the rest is tacked behind the screen.
It was a very tedious but easy job to do. I would recommend it to anyone who wants to add some theater ambiance for not a whole lot of money or effort.
docprego is offline
post #188 of 362 Old 01-09-2009, 08:23 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
Hey man that looks fantastic. I can't believe how the look of your room changed. Very nice. I don't blame you for taking the light stands back. Looking at your setup now I'm thinking they would have looked out of place anyway, and your right why cover those beautiful curtains anyway. Good Work!
RTROSE
RTROSE is offline
post #189 of 362 Old 01-09-2009, 08:45 PM - Thread Starter
docprego's Avatar
RTROSE
Thanks RT! I am a bit sad to lose the light stands, I like them a lot. i am surveying the room right now looking for possible places to put at least one of them.
In other news I am looking at speaker stands, I heard you guys loud and clear-mine are too short. I have really only found one stand I like:
http://www.bello.com/index.php?parti...21&categ_id=43
They will actually cost less for a pair than the pair of lights. Only one issue; there is no matching center stand available (to my amazement), any solutions?
docprego is offline
post #190 of 362 Old 01-10-2009, 02:12 AM - Thread Starter
docprego's Avatar
Spent a good amount of time tonight lining the projector up with the screen. It looks awesome projecting on that huge screen flanked by velvet curtains.
I took some screen shots, in each pair the first is with the lights off and the second photo is with the lights on (so you can see the curtains).
docprego is offline
post #191 of 362 Old 01-10-2009, 11:16 AM - Thread Starter
docprego's Avatar
So my next mini project begins. Today I am focusing on making a pair of masking panels for 2.35:1 movies. I made these for my last DIY screen and they work awesome. This time though is more of a challenge because the screen is wider and the frame is less deep. Last time the panels fit inside the screen frame with a friction fit, it worked perfectly. This time I only have 1/2 inch of frame to work inside, I don't know if friction fit will work this time. I'll figure something out.
docprego is offline
post #192 of 362 Old 01-10-2009, 08:45 PM - Thread Starter
docprego's Avatar
My masks adventure has begun! Please read this post in my new masks thread for all the details:
http://www.avsforum.com/avs-vb/showt...7#post15525357
docprego is offline
post #193 of 362 Old 01-14-2009, 12:58 AM - Thread Starter
docprego's Avatar
I spent my entire afternoon and evening working on the masks.
The 2 completed but uncovered masks:
A single mask getting ready to be covered in velvet. Note the electrical tape on the metal and foam. I put this there to ensure that the metal would not separate from the foam. It was entirely unnecessary as the metal is such a perfect fit I could barely pull it off anyway when I needed to make an adjustment.
A single completed and covered mask:
You can't really see it in this photo (which is great) but the lower mask is installed.
A test fit I did to see if the masks would stay suspended by friction alone. Have a look to see the result:
A close up of the construction of the mask. The metal is a custom fit over the foam. Once assembled these masks are extremely rigid and relatively lightweight. Several of my complaints about version 1 of my masks are addressed by these new masks. Specifically they have a nice sharp edge due to the metal, my last masks relied on my foam cutting skills for a sharp edge. Also they are much more rigid once assembled then the blue foam ones I made were. This allows them to sit flush against the screen with no bowing or sagging.
The second mask is drying now, I will have them both installed tomorrow. I am going to project a 2.40:1 movie right away and I'll take before and after photos. I am expecting a dramatic improvement.
docprego is offline
post #194 of 362 Old 01-14-2009, 06:20 PM - Thread Starter
docprego's Avatar
V2 of the masks are finished and a complete success! They work exactly like the first version did, completely friction fit. I made the upper mask fit tight enough that no Velcro or any other supports were necessary, it stays in place perfectly on friction alone. These masks are an improvement over my originals because of the metal reinforcement I used. It made the masks super rigid which allows them to lie totally flat against the screen, no bowing or sagging at all. The metal also gives the edges of the mask above and below the picture a very sharp edge.
I am 100% satisfied with these. Sitting in my HT with these installed and a 2.35:1 movie playing on my 120" screen, it just doesn't get any better than that.
Here is the screen with both masks installed:
Here are a couple of photos showing the masks uninstalled and standing up against the wall:
Here is a screenshot, lights out with the masks installed:
Here is the same shot lights out with the masks uninstalled:
And the same shot with the lights on, masks uninstalled:
And some more screen shots, all lights out with the masks installed:
docprego is offline
post #195 of 362 Old 01-14-2009, 07:54 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
Impressive! I'm speechless! I'm going to (eventually) your detailed mask thread and educate myself!
RTROSE
RTROSE is offline
post #196 of 362 Old 01-14-2009, 08:17 PM - Thread Starter
docprego's Avatar
Thank you! I have been at this mask game as long as I have been into home theater. Made em on all 3 screens I have owned. They make a huge difference in the picture quality and to me more importantly in the cinematic immersion. It is an effect that is greater in person than it would seem it would be.
I have to say I was within inches of giving up on these yesterday. I was going crazy trying to devise a way to keep the top mask in position. I should have just tried my standard friction fit, it worked like a charm (I didn't think it would).
I encourage anyone who dislikes gray bars or just wants to improve their experience to implement some form of masking.
docprego is offline
post #197 of 362 Old 01-15-2009, 11:00 AM
HDGTX's Avatar
Hey docprego,
Did you use two curtain panels per side, since they were only 50" (wide per the description on the BBB web page) ?
Your curtain rod was 139" long, so two panels would have been only 100" wide.
How did you attach the horiz curtain panels above the screen & under the screen ?
Sorry If I missed where you has previously addressed this.
John
HDGTX is offline
post #198 of 362 Old 01-15-2009, 01:37 PM - Thread Starter
docprego's Avatar
Originally Posted by HDGTX View Post
Hey docprego,
John
I actually used 6 panels in total. (1) 108" on each side and then (4) 84" (shortest available) over the screen. I needed that many to make it look full enough. That 50" width does not actually cover 50" of wall when a pleated look is desired. Since my left and right sides next to the screen were only 14" wide the 50" panel width was just right. The rule of thumb is that you should use 2-3x the curtain width as wall width. So I used 50" of curtain for my 14" sides and 4 panels which is 200" for above the screen where the width iis 109". I attached the lower curtains with flat head thumbtacks behind the lower border of the screen frame. In this area I did not want a pleated look, instead I laid the material on the curtain wall flat.
docprego is offline
post #199 of 362 Old 01-15-2009, 03:56 PM
spectramr2's Avatar
Would you consider making me a pair of these masks and shipping them to me? If so, how much? Im a Cisco VOIP Engineer and travel a lot and have no time at all to make these. Let me know, thanks!
So..if you are watching tv in regular 16x9 mode..you take the masks off?
spectramr2 is offline
post #200 of 362 Old 01-15-2009, 06:57 PM - Thread Starter
docprego's Avatar
I leave the masks off at all times. When a movie is 2.35:1 or 2.40:1 I put them on. After the movie I take them off again.
Thanks for the inquiry but I don't have the time myself to make these for other people. Besides they would be practically impossible to ship.
docprego is offline
post #201 of 362 Old 01-15-2009, 09:01 PM
HDGTX's Avatar
Hey docprego,
John
Thanks, docprego !
HDGTX is offline
post #202 of 362 Old 01-16-2009, 11:51 AM
Greg_B100's Avatar
The great thing about those curtains is that you can hide your masking strips by leaning them against the bottom of the wall along the floor and drop your curtains over them. Instant storage! Very cool idea, thanks for sharing your masking techniques. Your room is looking great.
PS, can you get those speaker stands individually, or do you have to buy them in pairs? If you could get just one it might work for your center since the center is sitting in a horizontal position.
Greg_B100 is offline
post #203 of 362 Old 01-16-2009, 02:45 PM
spectramr2's Avatar
Could you pm me a list of what i need to purchase then? Im sorry, im new to the masking game and i have a 106" screen which i would like to mask for 2:35 to 1 movies.
Thanks a bunch.
post #204 of 362 Old 01-16-2009, 03:28 PM
Iusteve's Avatar
You could get really crazy and recover your screen frame in burgundy velvet
XBOX Live: Zz NiNj4 D4D zZ
Iusteve is offline
post #205 of 362 Old 01-16-2009, 11:04 PM - Thread Starter
docprego's Avatar
Great suggestion, never thought of that. I could just order 2 sets and have an extra stand. The only issue is that those stands only come in 24", 30", or 36". The 24" is too tall for my center because my screen is 24" off the floor. So unfortunately I cannot make that plan work.
Thanks a bunch.
I would suggest reading through both of these threads completely:
http://www.avsforum.com/avs-vb/showthread.php?t=1008446
But the black velvet frame looks great against the burgundy velvet curtains. Also a black frame absorbs light that hits it resulting in a nice sharp edge to your image.
docprego is offline
post #206 of 362 Old 01-18-2009, 01:15 AM - Thread Starter
docprego's Avatar
Some screenshots:
2.40:1 with masks installed:
The next 4 are the same shot, the 1st with masks installed and lights off:
The 2nd with the masks installed and the lights on:
The 3rd of the masks uninstalled and the lights off:
The 4th of the masks uninstalled and the lights on:
Finally some shots of a 1.78:1 movie, this was cool because no masks were needed and the entire screen was filled. It was awesome:
I'm actually standing in this shot, you can see the image projecting on my shirt. I did this to give you some scale to see how big this picture is.
docprego is offline
post #207 of 362 Old 01-18-2009, 11:13 AM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
Looks fantastic. Just keeps getting better!
RTROSE
RTROSE is offline
post #208 of 362 Old 01-18-2009, 11:51 AM - Thread Starter
docprego's Avatar
RTROSE
Thank you very much!
Of all the changes I made over the last couple of weeks the best by far was lowering the screen, it made everything just feel right. Prior to that I would spend the whole time analysing the wall and not really enjoying what was on screen.
docprego is offline
post #209 of 362 Old 01-18-2009, 07:02 PM
MarkH's Avatar
doc,
Any pics of the ends of your masks? Im interested to see how tidy youve finished them, not that its a problem on mine as once you mount them in a dark room the imperfections.
MY THEATRE ROOM, LIVING ROOM and BEDROOM SYSTEMS THREAD
http://www.avsforum.com/avs-vb/showthread.php?t=1105927
MarkH is offline
post #210 of 362 Old 01-18-2009, 08:05 PM - Thread Starter
docprego's Avatar
Originally Posted by MarkH View Post
doc,
I don't have any at the moment. But as you alluded to, this is the least important aspect of the masks for me. They fit so tight within the frame it is impossible to see the ends anyway, combine that with lights out and it's a non issue.
I do have to admit looking at them to make sure they look good anyway, which they do. :-)
docprego is offline
