Small private HT room - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 40 Old 09-16-2013, 08:32 PM
Mike Garrett's Avatar
Quoted: 6700 Post(s)
Liked: 4388
Originally Posted by Nick****achi View Post
You need to swap the polarity on your tweeter or woofer.
I went to active, several months ago and have not been using the crossover. Then my MiniDSP 10x10HD tore up a couple months ago, forcing me to go back to passive. I reversed the polarity then. Got my MiniDSP back last week.
mjgarrett100@gmail.com
Mike Garrett is online now
post #32 of 40 Old 10-22-2013, 08:10 AM
Liked: 4388
Making a few changes. Have added two sealed TD18H+ drivers for mid-bass subs. Will play around with different settings. Thinking about running them from 60hz to 120hz. Also adding a masking system to my curved screen. Right now I have everything pulled off my front wall and trying to find time to get everything built back with the masking system. Also going to a 9.2 system. Adding a pair of JBL 8340's to the back for rear surrounds and a pair of JBL 8340's for front height speakers. Here is a pic of the masking system pieces.
Will take some pics once I have masking system in place.
post #33 of 40 Old 10-27-2013, 10:33 AM
Liked: 4388
Started putting things back. Here is a pic of the front wall before screen and masking system. Subs are not in place in thispicture.
The unpainted shelves do not show. They are just below (flush with top edge of frame) the screen frame.
post #34 of 40 Old 10-27-2013, 12:28 PM
Liked: 4388
Looks like I am stopped. Found a crushed capacitor on one of the boards for the masking system. frown.gif
post #35 of 40 Old 11-17-2013, 06:27 PM
Liked: 4388
Masking system in place.
Also rebuilt new box for the SI-18's since the boxes up front that the SI-18's were in now contain TD18H + drivers. The SI-18's are dual opposed in 8.0 CF sealed.
Still have some wire to pull in for the rear surrounds. Figure out how to install the front height speakers and install the slide for the A-lens. The front subs are two TD18H + drivers and one MalX-18. Behind the seating I have two SI-18's and two 12" TC Sounds drivers. Pictures were taken with lights on in the room and using flash. That is why the AT masking panels do not look very dark. Right now, I will just temporary install the lens slide, since I will need to rework everything when I get my new Sony VW600ES. smile.gif
post #36 of 40 Old 11-17-2013, 06:43 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 962
Woooohooo! 4k!!!!
doublewing11 is offline
post #37 of 40 Old 04-22-2016, 10:52 AM
Liked: 4388
Have not updated in awhile. Put in a baffle wall system about 20 months ago. Did a thread on the baffle wall build here.
Baffle wall build using Beyma TPL-150H
Was using a Sony VW600ES projector, but now using a JVC RS600.
post #38 of 40 Old 05-01-2017, 11:39 AM
Liked: 4388
Have moved to a JVC RS4500. Changed my mounting system to one that has much more flexibility. Got tired of building new mounting plates for my A-lens. Installed a rail system with independent mounting for projector and lens. New mounting system allows me freedom to move projector forward, back, right and left. Same goes for the A-lens. Picture of front wall. Other than screen, the rest of the wall is either black velvet or black speaker cloth. I also installed a powered dead vent and a remote thermostat sensor. Room used to get too cold in the summer time, when closed off, but now that I have the sensor in the room, the temperature can stay constant.
ID:	2112257   Click image for larger version
Name:	New mounting system.jpg
ID:	2112265   Click image for larger version
Tedd likes this.
post #39 of 40 Old 05-12-2017, 11:06 AM
jjcook's Avatar
Quoted: 356 Post(s)
Liked: 148
Mike, I'm planning on duplicating your mounting rail system; did you look into the correct paint (and surface prep) for the strut? I picked up Superstruct channel with Gold Trivalent Chromium Finish (over the zinc galvanization layer) and its unclear if it has the same paint restriction as zinc galvanized steel (i.e., alkyld-based spray paints will saponify and peel).
For Sale: Triad RackAmp 350 DSP v2 || Navitar 0.65x conversion lens
Σ Info: Δ 8.5' viewing distance AT screen fabrics comparison
Σ Builds:
Δ HT 2.0 renovation with acoustic coffered ceiling (in progress, 10% completed)
Δ Variable-aspect screen with motorized masking (on hold, have parts)
jjcook is offline
post #40 of 40 Old 05-12-2017, 11:20 AM
Liked: 4388
I used the same. From what I read, there is no special prep needed for painting. I just sprayed mine flat black. If it was hot dipped galvanized, then it would require special paint prep.
