Johnsteph10's HT 3.0 Build Thread - Page 25 - AVS Forum
post #721 of 889 Old 02-12-2010, 03:50 PM - Thread Starter
Johnsteph10's Avatar
Ok, a little progress!
I've got the bathroom floor tiled. I used 6x6 inch porcelain tiles...however, I used a new mastic compound I've never used before (Mapei from Lowes). In the past, I've always just used thinset morter but I just didn't feel like mixing up the relatively small amount it would take for the bathroom.
It is literally taking forever to set! Thinset dries in a few hours and boom...done!
So, I'm in a holding pattern waiting for the tile to set before I can:
1. grout
2. put in door casing/base molding
3. put in the toilet/vanity
4. Finish the plumbing.
I did however, get the anamorphic lens in...and setup.
Just as a side note...we are actually getting snow in mid-GA! I came from NY so no big deal...but it is like the world is ending here!
I'll get some pics up in a bit.
John
Loganed...finally. 6/6/08
My 3.0 HT Build Thread
Johnsteph10 is offline
post #722 of 889 Old 02-12-2010, 08:23 PM
misugrad's Avatar
John - I just went through your thread...i'm subscribed! Looking great!
Question on the window wood shutter blinds you've got - how is light leak from those? You doing something else w/ the window?
I ask, as i'm planning, I have a walk out as well and a large window for the HT space.
Mike
Started the build...Theater With A View
misugrad is offline
post #723 of 889 Old 02-13-2010, 06:18 AM - Thread Starter
Yeah, light leaks through fairly substantially during the day. I plan on putting up a set of heavy curtains...between the 2, it should do just fine.
Thanks for reading! Sometimes it seems that I'm talking to myself in here!
John
post #724 of 889 Old 02-13-2010, 07:24 AM
tlogan6797's Avatar
Liked: 35
OK, waiting on tiling pics!
I'm at the point of replacing my dricore and need to decide if I should dricore the bathroom as I did originally or just go ahead and tile. I'm thinking that if I use Ditra it should put the tile at the same level as the dricore.
Tom Logan
Need motivation? Get LOGANED
An as-yet un-named theater designed by Big-WarrenP-BritInVA
tlogan6797 is offline
post #725 of 889 Old 02-13-2010, 09:05 PM
misugrad's Avatar
Yea, I think lots listen, but are either not sure what to say/ask. At first it's a bit intimidating on the site, w/ all the knowledge here. But everyone is super inviting and willing to offer help.
Unfortunately, my window will be next to screen and would throw off the theme, let alone light. I'm getting more towards to the realization to do a proper HT this window will need to be closed up. That's why I got a SI Blackdiamond screen, in case I don't block off the window and just do like you've got...so many choices.
Mike
misugrad is offline
post #726 of 889 Old 02-14-2010, 08:32 AM - Thread Starter
In your case, then, I would make a window plug. Just do a search on this forum for "window plug" -- I also believe that Ted White (www.thesoundproofingcompany.com has a "how-to" guide on making/installing them.
John
post #727 of 889 Old 02-14-2010, 08:35 AM - Thread Starter
Still no tiling pics for Logan (I just haven't felt like taking pics of the bathroom floor, yet!). I did buy sanded grout, however.
I work a lot the next couple of days so not much progress will be made.
Here's some important pics of the twins before they get their hardware installed!
Terraform XLs (final shot of the cabinets)
John
post #728 of 889 Old 02-21-2010, 10:29 AM
bukiwhitey's Avatar
John,
Do you have any idea on when you will receive the TXL's?
David
bukiwhitey is offline
post #729 of 889 Old 02-21-2010, 05:15 PM
SDean's Avatar
Definitely not talking to yourself. Great thread, love the photos.
SDean is offline
post #730 of 889 Old 02-21-2010, 05:30 PM - Thread Starter
Originally Posted by bukiwhitey View Post
John,
David
Per Mark, they are sitting now in his warehouse awaiting final assembly/testing.
EDIT: Here's a pic he just sent me after they were delivered to his warehouse for final assembly/testing!
Should be soon!
John
post #731 of 889 Old 02-21-2010, 05:46 PM - Thread Starter
I am have made absolutely no progress on the basement...except to watch movies and drink Yuengling.
In case anyone is wondering, an anamorphic lens really does make quite a notable improvement in PQ/brightness for scope (2.35 to 2.40) movies.
Let's make a list!
BATHROOM:
Finish tiling the bathroom (2 more tiles to cut)
Clean bathroom/tile
Grout
Door Casing/Moldings
Wire Switch
Wire GFCI outlet
Plumbing -- finish shower/tub enclosure, toilet, vanity/faucet, install sump pump
Install vanity
Install mirror
Install vanity light
Figure out how to hang a door
Install closet door
Wet Bar:
Install Faucet/Drain
Finish Painting
Tile Backsplash
Outlet Covers
Overhead lighting
Stage/Screen Wall:
Take down screen wall
Install subwoofers (when available)
Painting all wood black
Make/fabricate screenwall framing/fabric
Make the baffle wall
Install bass traps
Install floor molding/Can light trim in equipment room
Figure out how to make the electrical panel (100amp subpanel) look nice.
Trim up the security box
Tidy up the rack
Back Wall:
Hang Black Out curtains
Clean/repaint the exterior white door
Walls:
Figure out sconces vs. posters vs....what?
Figure out design/pattern for walls
Install Fabricmate track
Firring strips around all of the relevant outlets/lights/HVAC return
Install fabric.
Stairwell:
Paint white trim
Touch up ceiling
Re-install handrail
Hang up pictures/posters/whatever
Misc:
Mount flat panel mounts in bar area/back area
John
post #732 of 889 Old 03-12-2010, 05:32 AM
RTROSE's Avatar
Liked: 45
Any updates?
RTROSE
RTROSE is offline
post #733 of 889 Old 03-16-2010, 07:54 PM - Thread Starter
Any updates?
RTROSE
Wow, I suck. Over 3 weeks and I have done almost nothing to the basement!
Finished tiling the bathroom (last 2 tiles required multiple wet saw cuts).
I'm off work tomorrow and I plan on getting some stuff going again.
Beer + PJ + Screen = Bad. (as in....Logan...bad....).
I'll get some pics up of the new toys, as well!
John
post #734 of 889 Old 03-17-2010, 03:20 AM
fotto's Avatar
Boy, those must have been some hairy tile cuts, 3 weeks and all
fotto is online now
post #735 of 889 Old 03-17-2010, 07:27 AM
RTROSE's Avatar
Liked: 45
I have found that Beer + Anything = Bad. The first time I had any experience with a major move my buddy bribed me and many others with free beer and pizza for our help. I learned from that experience that you should only supply the free beer AFTER the move is done. Seven drunk people moving furniture might be funny to watch, but does not lend itself to having your furniture arrive in your new place all in one piece!
Live and learn.
RTROSE
Oh, and you can redeem yourself by posting pics.
RTROSE is offline
post #736 of 889 Old 03-17-2010, 09:53 AM - Thread Starter
Shuddup!
1 tile cut ~ 10 days isn't so bad, is it?
John
post #737 of 889 Old 03-22-2010, 07:40 AM - Thread Starter
Some pics of the Twins:
Mark Seaton standing next to 'em for size comparison:
Next to a Submersive:
I know I've posted these in my Terraform XL thread...but they belong here.
John
post #738 of 889 Old 03-22-2010, 08:10 AM
audioguy's Avatar
Quoted: 27 Post(s)
Liked: 83
I'm ready to drive down from Atlanta, once you get it running, and have a listen. I'm not really in the market for subs since I have four SubMersives but am VERY interested in hearing your Catalysts for two channel.
I certainly hope I don't like your Terraform XL's (very much). They are not in the budget
audioguy is online now
post #739 of 889 Old 03-22-2010, 09:42 AM
hanesian's Avatar
HO! LY! CRAP!!
We're going to need a bigger boat!
The Un-Theater Un-Build
hanesian is online now
post #740 of 889 Old 04-05-2010, 08:43 AM
bukiwhitey's Avatar
Any updates on your Subs?
You are a very patient man.
post #741 of 889 Old 04-10-2010, 08:26 AM - Thread Starter
I am very patient...plus everything is taking forever anyway so it isn't too bad! They should be here within 2 weeks or so.
Some recent pics from Mark Seaton:
John
post #742 of 889 Old 04-10-2010, 08:32 AM - Thread Starter
Ok, some updated pics showing mild progress!
Bathroom floor tiled/grouted/cleaned/sealed. El-cheapo molding painted/installed! Still have to touch up the nail holes...
Some pics of the anamorphic lens setup/sled installed. Thanks to GetGrey! It really is an absolutely cool setup and throws an amazing anamorphic picture!
John
post #743 of 889 Old 04-10-2010, 08:43 AM - Thread Starter
Early next week I plan on:
- finishing plumbing for bar faucet/shutoffs/drain and install the faucet
- clean up the bathroom tub
- install showerhead
- install vanity
- install vanity light
- install toilet
- install bathroom faucet/cutoffs
I should then be done with plumbing in the basement HT! Exciting, I know! Hanes, where are you with an exciting picture?
John
post #744 of 889 Old 04-10-2010, 10:59 AM
RPh Drew's Avatar
I have followed your thread all along but how did I miss the banter on using the galvonized to hang the projector... I have a similar set up for doing pull-ups in the basement bedroom (not that it has seen much use lately).
Do you get any questions asking if your projector is liquid cooled?
2010 - The year of the Shed
RPh Drew is offline
post #745 of 889 Old 04-10-2010, 01:27 PM
mjaudio's Avatar
Liked: 30
Wow!
Glad I stumbled onto this thread, what an outstanding build. A killer home theater, kegerator, and bathroom, you may forget what the rest of your house looks like after it's done
"Half the world is looking for Jesus, and the other half is looking for more bass..."
mjaudio is offline
post #746 of 889 Old 04-10-2010, 05:08 PM
hanesian's Avatar
Just a little hung up at the moment. But I'll be back ...
post #747 of 889 Old 04-10-2010, 06:38 PM
RTROSE's Avatar
Liked: 45
Those subs are starting to take shape. Looking good. I did not realize how much bigger than a submersive they were. I missed it if you posted but what is the wattage for the subs?
The lens setup looks pretty slick as well.
RTROSE
RTROSE is offline
post #748 of 889 Old 04-10-2010, 07:46 PM
In2Photos's Avatar
Mark appears younger than I expected, but your subs look great!
Mike
Where am I with my HT build?
Still Dreaming! But I built a shed!
In2Photos is offline
post #749 of 889 Old 04-10-2010, 09:47 PM
SharpOne's Avatar
Those subs are huuuge! I hope you have earthquake insurance.
SharpOne is offline
post #750 of 889 Old 04-11-2010, 01:58 PM - Thread Starter
They are the major reason why I have gone to such lengths to decouple the room from the rest of the house. Sound proofing requires a huge amount of work! (and $$$)
John
User Tag List
