On-wall conduit? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-11-2009, 08:11 PM - Thread Starter
mflaster's Avatar
I have an existing finished room that I'm trying to turn into a theater. I want to ceiling mount the projector. What do most people do?
Assuming I don't want to go inside the wall, is there an easy way to run the wire on the outside of ceiling / wall? Obviously it will be visible, but I can live with that. Is there something that I can buy that's easy to mount to the ceiling, that I can run cables through? I will need to run an HDMI cable, a component cable, and power.
Mike
mflaster is offline
post #2 of 10 Old 01-11-2009, 08:46 PM
MetalMike's Avatar
i'd run wiremold. just make sure the power and signal cables are ran in different wireways or seperated by a divider.
MetalMike is offline
post #3 of 10 Old 01-11-2009, 09:51 PM
GPowers's Avatar
Quoted: 43 Post(s)
Liked: 49
you can also dress up the wiremold with some wood trim.
GPowers is offline
post #4 of 10 Old 01-11-2009, 10:04 PM - Thread Starter
mflaster's Avatar
Are you talking about Raceway products?
Is this (or a similar brand) something I can pick up in Home Depot? Can it be attached to the ceiling too?
mflaster is offline
post #5 of 10 Old 01-11-2009, 10:17 PM - Thread Starter
mflaster's Avatar
I just found this:
http://www.mbelectronics.com/view.aspx?id=405
I guess those are 2-piece raceways, so you can pop them out and put in new cables later? And they already have adhesive attached, so you just glue them to your wall / ceiling?
Seems pretty easy...
Another question - is it better to get metal or non-metal raceways? I imagine non-metal?
mflaster is offline
post #6 of 10 Old 01-12-2009, 11:26 AM
GPowers's Avatar
Quoted: 43 Post(s)
Liked: 49
GPowers is offline
post #7 of 10 Old 02-26-2009, 03:42 PM
Eyeball Chambers's Avatar
I'm just curious, why do you say that? Does one interfere with the other?
I'm looking to run a power cable, coax and possibly a Wii power cable through one raceway. Would I need one with a divider, too?
Eyeball Chambers is offline
post #8 of 10 Old 02-26-2009, 04:20 PM
Quoted: 3255 Post(s)
Liked: 2743
Why? are you renting? is the ceiling concrete?
The techniques aren't much different than installing a ceiling fan.
We can walk you through it.
post #9 of 10 Old 02-26-2009, 05:49 PM - Thread Starter
mflaster's Avatar
So what I ended up doing was hiring a guy that ran the wires for the projector through the ceiling. That's definitely something I wouldn't want to do myself... He had to punch a bunch of holes in the ceiling, as it's a vaulted ceiling with no attic.
For speaker wires to the front of the room, well, I took the high tech solution of just putting them on the ground by the wall.
mflaster is offline
post #10 of 10 Old 02-26-2009, 08:58 PM
queendvd2's Avatar
You can just get use some trim work on the floor to hide the wires.
queendvd2 is offline
