Soffit bass traps - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #31 of 42 Old 02-17-2009, 10:21 PM
68sting's Avatar
68sting is online now
post #32 of 42 Old 03-07-2009, 08:16 AM
edfowler's Avatar
Quoted: 152 Post(s)
Liked: 83
Originally Posted by 68sting View Post
I have a platform thats half the width of my room and I was hoping to turn it in to a bass trap. After reading your comments above I'm wondering how it will impact its effectiveness being only half the room size. Also all I need to do is add a couple registers in the rear floor area to turn in to a bass trap? That sounds too easy. Thanks in advance
I have the same situation and was wondering the same thing
edfowler is offline
post #33 of 42 Old 03-07-2009, 03:58 PM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 100
For a platform to be used as an effective bass trap it must be to both side walls and the rear wall.
nandkisham likes this.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #34 of 42 Old 03-07-2009, 05:23 PM
edfowler's Avatar
Quoted: 152 Post(s)
Liked: 83
thanks for the reply Dennis, appreciate it.
edfowler is offline
post #35 of 42 Old 03-30-2009, 07:48 AM
sonicninja's Avatar
Im kind of newbie to all of this so please forgive my rookie question but how did you get such a clean edge on your vertical GOM fabric covers on your soffit? does anyone know of a link that shows all the installation tricks of using GOM.
sonicninja is offline
post #36 of 42 Old 03-30-2009, 09:41 AM
LHD21's Avatar
Why is that?
Also, what is the relationship between the floor register opening and the frequencies damped? Is a single 10"x4" register sufficient for most bass frequencies or would a 8"x2' register work significantly better?
Originally Posted by vasyachkin
Even i, the genius, only vaguely understand what i am saying here.
LHD21 is offline
post #37 of 42 Old 03-30-2009, 09:58 AM
Quoted: 64 Post(s)
Liked: 100
If the platform extends the width of the room and goes to the rear wall, the platform is positioned to be within the areas where modal frequencies are peaking (low velocity/high pressure). With proper design of the seating platform, 4x24, 4x36 floor registers (bar diffusors) can be used. By properly designed I mean the following has been accounted for in the construction of the platform:
1. Fiberglass insulation has been installed in the cavities of the platform;
2. The areas (very near the wall) under the platform have been framed with sufficient volume to do some good.
post #38 of 42 Old 07-15-2009, 09:28 PM
edfowler's Avatar
Quoted: 152 Post(s)
Liked: 83
Dennis I am taking your advice and building my platform wall to wall and all the way to the back wall.
I will have enough opening along the back and was thinking about putting registers along the side walls as well. Do you think that this would be a benefit to the room?
edfowler is offline
post #39 of 42 Old 07-15-2009, 09:28 PM
edfowler's Avatar
Quoted: 152 Post(s)
Liked: 83
I was also thinking about opening the front of the platform as well if this would help.
edfowler is offline
post #40 of 42 Old 10-07-2009, 10:30 PM
storman's Avatar
Not trying to hijack this thread, but I'd like to know how I could put some leftover R19 unfaced pink insulation bats to good use as bass traps. I have 2' of depth behind my screen wall, so size and looks aren't necessarily an issue. If I did something floor to ceiling in both corners, I would have 4 tri-corners trapped. My room dimensions are roughly 19'x14.5'x8'. If I left the insulation in it's plastic bag (about 20" in diam, 4' tall) and positioned in the corner, would it effectively trap bass ?
Bill
storman is offline
post #41 of 42 Old 10-08-2009, 10:41 AM
CJO
CJO's Avatar
Bill
That's exactly what I did in my theater, which was based off of one of the audio experts recommendation (can't remember which one at the moment).
CJ
coneilliv at aol dot com
The Dark Knight Theater
(a bunch of good reference links and material in first 15 posts)
CJO is offline
post #42 of 42 Old 10-21-2015, 03:58 PM
Quoted: 31 Post(s)
Liked: 2
Hello Dennis,
Thanks for all the contributions.
Can the first riser (both side walls and rear wall) be built on a 4 inch stud and then a 6' X 9' feet platform built on top for seating away from rear wall by 3.5'?
can this design be planned to act as an effective bass strap?
regards,
NJ
nandkisham is offline
