Acoustic isolation from concrete foundation wall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 02-03-2009, 05:58 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 36
Hi Acoustic Gurus!
I'm well underway with my 28'x15'x9'6" dedicated home theater construction. I promise I'll start a thread to document the process soon ;-) The space I'm utilizing is a former crawl space under the house. I've excavated out and built a retrofit basement by extending the original stem/foundation walls downward. The result is a partial concrete bunker with the original 2x6 mud sill and framing starting from a floor height of between 2' and 10' (on a hill hence the variation around the room). I will be building a room within a room with an emphasis on sound isolation from the rest of the house but still want to maximize the room width. Just how close to the concrete walls should I frame the room? I've read everything I can and yet cannot decide if a 1" air gap is sufficient in my case. I know that 4" or more is a rule of thumb but builds utilizing this rule don't seem to have the air space I will have from the upper walls venting to above the ceiling (the joists from the floor above are over 11' high!
So am I likely to suffer low frequency coupling with the following construction:
Double DW + GW ; 2x4 framing attached to floor only ; 1" airgap ; 8-14" concrete foundation with existing house framing build on top approximately midway up the wall?
My "Old Vic" Theater Build | Screen Build | HT of the Month | Contest Win
My 8 year old daughter: "are contractors the people that mess up your house for money?"
Moggie is offline
post #2 of 19 Old 02-04-2009, 06:37 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
What a digging project. Holy smokes. Some pics of that would be great.
The walls you described are considered decoupled. A double wall. Outer wall is foundation. Inner wall is wood frame. Simple R19 in the walls will be great. Make the walls as heavy as possible. Include as large an air gap as possible.
These factors will directly affect your wall / ceiling's ability to attenuate low frequencies.
__________________
Ted
The Soundproofing Company
Ted White is offline
post #3 of 19 Old 02-04-2009, 07:49 AM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 36
Thanks Ted, yes this is an unusual starting space for a theater build but I was determined :-) The excavation is done and it is quite amazing what the removal of well over 100 yards of dirt from under the house looks like!
Back on the isolation question. From what I understand, the air gap will form a spring between the mass of the theater room wall and the concrete foundation -- the larger the gap the better the low frequency isolation. But, given that the air gap in the upper part of the wall is larger and it continues into the space between the theater rooms separate ceiling and the joists of the floor above, is a 1" separation sufficient or do I have to make it larger (4" seems to be the rule of thumb). Note that the whole purpose of going to the effort of building this retofit basement is isolation from the house so I want to make sure I'm getting this part of the design correct.
Cheers.
Moggie is offline
post #4 of 19 Old 02-04-2009, 08:47 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
More air = bigger spring = lower resonant frequency. So you make the distance as big as you can deal with, and the walls as heavy as you can deal with.
Think of it this way. Even if you use 4 sheets of drywall and a 12" air cavity, you will still hear bass in very low frequencies. You just cannot build a facility in a house that will stop 20Hz soundwaves.
So make the walls as deep and heavy as is practical for you.
__________________
Ted
post #5 of 19 Old 02-04-2009, 09:34 AM
Johnsteph10's Avatar
Quoted: 31 Post(s)
Liked: 24
The design of my basement:
Concrete foundation to 6 feet tall on 3 of the 4 walls
2x6 16 inch OC studded walls on top of the wall to the joists above
I added a decoupled 2x4 16 OC inner wall that varies from 1.5 inches to 2 inches from the concrete/2x6 wall. The 2x4s are staggered differently from the 2x6s. The 2x4 wall is decoupled from the original wall and the joists above.
It adds some insulation expense, as well, as I have to fill the 2x6 cavity as well.
In the end, it will be worth it!
John
Johnsteph10 is offline
post #6 of 19 Old 02-04-2009, 10:00 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
Sounds perfect. You could put R13 in those 2x6 walls and be OK, by the way.
__________________
Ted
post #7 of 19 Old 02-04-2009, 01:00 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 36
Excellent info. John, your build sounds very similar to mine. So all I think I'm missing in my original design is a bit of R13/R19 insulation. Time to start that construction thread, but until then, here is a taster of the excavation...
Moggie is offline
post #8 of 19 Old 02-04-2009, 02:35 PM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 111
Now that everyone has been focused on the walls, what are you going to do about the floor?
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Chairman
www.erskine-group.com
Dennis Erskine is offline
post #9 of 19 Old 02-04-2009, 03:08 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 36
Well, I'll be starting with a 4" concrete pad that is being poured between the new foundation. I intend the frame the room anchored only to the floor. The layout (I'm preparing the pics for a construction thread now) will have a sand filled stage, staged seating for the second row that may/could extend all the way back to the back of the room. I was thinking of installing drycore on the concrete within the perimeter of the room and building on top of that.
I guess the room framing could be built on top of the drycore but it will still be anchored to the concrete floor.
Is there anything I should be doing differently?
- Paul.
Moggie is offline
post #10 of 19 Old 02-04-2009, 06:30 PM
Quoted: 31 Post(s)
Liked: 24
Holy Monkeys, that's a LOT of excavating!
John
post #11 of 19 Old 02-04-2009, 06:30 PM
Quoted: 31 Post(s)
Liked: 24
I was hoping I could do that. The differences in insulation price are rather extreme.
John
post #12 of 19 Old 02-04-2009, 07:34 PM
want2beyounger's Avatar
Does anyone use closed cell sprayed foam insulation to help isolate sound? If not, why?
want2beyounger is offline
post #13 of 19 Old 02-04-2009, 09:05 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 36
Um, ah, yes! 105 yards / 37 F650 dump truck loads! Whilst I'll be doing the rest of the work on the theater myself, I realized I met my match with that kind of digging... although, how big was the tunnel in the Great Escape?
Moggie is offline
post #14 of 19 Old 02-05-2009, 05:26 AM
budk's Avatar
I may have missed it but what about the ceiling? Also, what about the utilities, lighting, hvac, etc.... they all need to be planned for and how you do them will have a large impact on your acoustic isolation or lack there of.
Bud
There is a solution to every problem.
2nd Run Cinema - A fabric frame theater
budk is offline
post #15 of 19 Old 02-05-2009, 05:29 AM
Quoted: 64 Post(s)
Liked: 111
Closed cell foam is a transmitter, not absorber of sound (great for thermal applications). Foam insulation (open or closed cell) which contacts both sides of a barrier defeats mechanical isolation and provides a direct flanking path. Closed cell (and most open cell) foam insulation materials do little to slow down the movement of air molecules. If you look at the mechanics of fiberglass insulation, the air molecule strikes the fiber causing the fiber to move. The kinetic energy of the air molecule is reduced.
The concrete slab is a flanking path for LF and HF energy from the structure of the house (it's mass notwithstanding).
CEDIA Chairman
post #16 of 19 Old 02-05-2009, 07:21 AM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 36
You haven't missed it. I'm going to start a construction thread today with all the details. The ceiling joists are not shared and I don't anticipate any problems there.
Moggie is offline
post #17 of 19 Old 02-05-2009, 03:33 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 36
Construction thread started:
http://www.avsforum.com/avs-vb/showthread.php?t=1117148
Moggie is offline
post #18 of 19 Old 02-05-2009, 08:39 PM
Thank you.
post #19 of 19 Old 02-05-2009, 08:44 PM
Quoted: 31 Post(s)
Liked: 24
..not to mention that the closed cell spray foam is like 3-4x the cost of regular insulation batts.
John
