Saga of the "Old Vic" - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1171 of 1184 Old 12-25-2015, 11:46 AM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 36
Merry Christmas everyone...
Originally Posted by danwee View Post
Read it once more and got 90% of what you said. Some questions.
1.When you order roller tubes you have to get them from somfy or can you use something cheap from the local hardware store?
2. What do you think using a stepping motor instead of expensive somfy motor.
3.Instead of crossing the bungys at midway channel, why didn't you just swap the channels on the opposite end?
Danwee, there is lots of information (and debate) about the differences between zooming and using and anamorphic lens elsewhere on the forum. With the advent of 4K and bright, high contrast projectors the advantages of going Anamorphic are dwindling but essentially it allows for maximum projector resolution and squeezes some extra brightness out of a projector.
As for your questions:
1. I obtained the rollers from (random) blind dealer on the web. I can't remember the name off the top of my head. All you need is the right size of Aluminium tubing and some strong double sided sticky tape to attach the end of fabric. Make sure you retain at least one wrap minimum to prevent the fabric from pulling off.
2. I was originally going to use a stepper motor and build a control circuit. The decision is one of effort vs reward... the Somfy motors can remember 5 different stops and are simple to automate. The equivalent stepper motor control circuitry/software would be quite complex and probably just as expensive, if not more so. If you want just two positions/aspect ratios (open and closed) then an external sensor to detect the stop position would simplify things. The beauty of the Somfy system is multiple stops/aspect ratios, quick setup and easy programming/control.
3. If I understand what you are saying correctly then this might work so long as you get enough stretch (and recall "pull") out of the short bungy cord. My design was to create a constant pull over the entire range of movement. If the bungy is too short, it wont pull strong enough at the minimum aspect ratio... the longer the bungy the more constant the recall force.
Hope this helps...
My "Old Vic" Theater Build | Screen Build | HT of the Month | Contest Win
My 8 year old daughter: "are contractors the people that mess up your house for money?"
Moggie is offline
post #1172 of 1184 Old 12-27-2015, 09:40 PM
danwee's Avatar
Thanks Moggie.
Regarding the 3rd question, what I wanted to say was something like depicted in the sketch I draw.
Name:	Snap 2015-12-28 at 14.35.24.jpg
danwee is offline
post #1173 of 1184 Old 12-28-2015, 08:20 AM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 36
Thanks Moggie.
Ok, I see what you are saying. Sure this would work but the masks will be at different heights. Be careful, if a mask is too far away from the surface of the screen you will get a shadow and a less than clean edge to the side of the image.
Moggie is offline
post #1174 of 1184 Old 12-31-2015, 05:00 AM
danwee's Avatar
OK. Got it.
Thanks a lot.
danwee is offline
post #1175 of 1184 Old 12-31-2015, 05:00 AM
danwee's Avatar
OK. Got it.
Thanks a lot.
danwee is offline
post #1176 of 1184 Old 01-09-2016, 02:49 PM
texpilot's Avatar
Quoted: 170 Post(s)
Liked: 82
Is there pad on the vertical carpet areas?
Hi @Moggie
Hope you had a Happy New Year, but I'm sure you took barely a breath of relaxation due to the whole house reno you have ongoing ;-)
Quick question: for the vertical parts of your riser that are carpeted, I assume there is no pad there, correct? Just wanted to ask to be sure. I'm going to have a few removable panels in two different areas of my riser to ensure I can access and replace the strip lights in case anything ever fails, and I want to plan for the thickness of the carpeted sides and such.
Thanks again for all the great info from your thread.
-Terry
texpilot is offline
post #1177 of 1184 Old 01-10-2016, 01:49 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 36
Hi Terry, no padding is used in the vertical (riser/step) are of the carpeting, just the horizontal surfaces. If you are planning access panels in the carpet then you want to be careful with fraying at the edges over time. I believe there is a tape/adhesive to help prevent this.
And yes, the whole house remodel is killing me... trying to bend a walnut stair railing at the moment. I'm having to build a wood steamer to be able to bend at the desired radius
Cheers!
Moggie is offline
post #1178 of 1184 Old 12-03-2016, 09:55 AM
starcat's Avatar
Hey Moogie, what kind of material is the black one below the stage, is this some sort of rubber for decoupling it from the OSB bottom?
Wanted: M&K Sound MPS-2510P, S-150P, MPS-2525P, SS-250P
Stereo Integrity HT18 D4 subwoofer drivers
starcat is offline
post #1179 of 1184 Old 12-06-2016, 08:09 PM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
Looks like felt paper.
BllDo is offline
post #1180 of 1184 Old 03-08-2017, 01:13 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 36
Wow, over a year in answering (and a blatant bump).
Yes, it's #30 roofing felt. Good as a vapor barrier and well as having some cushioning ability to help with sealing. It may have some minor isolation value too.
Cheers!
Moggie is offline
post #1181 of 1184 Old 03-08-2017, 03:00 PM
audiovideoholic's Avatar
Quoted: 654 Post(s)
Liked: 216
Cheers!
This is always worth a bump for those new members!
Well done for the umptenth time Moggie!
audiovideoholic is offline
post #1182 of 1184 Old 03-12-2017, 07:20 AM
texpilot's Avatar
Quoted: 170 Post(s)
Liked: 82
I finally have a workable solution for my interior hush box fan. The previous in-line fan was hopeless, so I purchased the quietest bathroom fan I could find (the Panasonic FV08VQ3) and promptly tore it apart. I discarded the metal box, the grill, one mounting plate and the one-way valve and reassembled inside my sealed MDF box. The fan assembly was mounted directly to the original exhaust duct with sheet metal screws (for the square to round hole transition). Then this was suspended using neoprene mounts inside the box. Once the bottom cover was attached the fan creates a vacuum and pulls in air through the 5" intake pipe that leads to my hush box. At about 75% speed it is completely silent. At 100% I can just make out that it is running. My non-scientific test (using my aviation air speed indicator) suggests I can pull up to 75cfm which I believe is sufficient. I'm so glad I didn't have to rework the soffit to fit the fan outside the room.
I wasn't sure this was going to work -- but it did!
All,
I asked Paul in an IM what he used to control the fan speed and trigger the fan on/off. For everyone's benefit, here is his reply:
1. speed control is via a cheap fan speed controller like this one (you will often find them for controlling duct fans / attic fans). I think I found mine on ebay for about $9.
2. Switching on/off is done via a thermostat designed for fans / vents. Like this one. There may well be cheaper ones. I used one in my hush box and another in the rack closet. You set the level so the fan is off at normal room temperatures and switches on as the temp increases via the projector warming.
With my Fantech FG4 fan quite loud mechanically even inside my hush box and dialed way down in speed, I am soooooooo considering going with a Panasonic exhaust fan teardown approach like this!
texpilot is offline
post #1183 of 1184 Old 03-13-2017, 08:28 AM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 36
Indeed... although the Fantech is a great fan it is not at all quiet. Four years on, my "Panasonic experiment" is still working great and was the only option I found given that I had to fit it inside of my theater soffit.
Moggie is offline
post #1184 of 1184 Old 03-21-2017, 01:06 AM
DavidK442's Avatar
Quoted: 622 Post(s)
Liked: 459
Ditto.
DavidK442 is online now
Klipsch Kw 120 Thx Subwoofer , Jvc Dla Rs40u , Dune Hd Smart H1 1080p Media Player , Klipsch , Behringer Europower Ep4000 Professional Amplifier , Outlaw 7500 , Integra , Oppo Bdp 83 Blu Ray Player , Sonos
