Saga of the "Old Vic" - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #241 of 1184 Old 01-14-2010, 02:08 PM
KNKKNK's Avatar
Quoted: 39 Post(s)
Liked: 103
subscribed
As usual, excellent work Moggie!!
Looks like the Fosi system's pretty slick, and sounds like they have good CS support.
Knowing what you know now.. what is the minimum total thickness do you feel a star ceiling could be built in? Do you see any opprotunity to change the mounts or anything to shrink this thickness? smaller.. possibly thinner panels?. etc .... Or is it fairly optimized already..
Id guess you've at least pondered it.. Im curious what your take is on the possibility of getting much panel resonance with the ceiling ... cause it looks like you might have a little bass in that room
Brad
KNKKNK is offline
post #242 of 1184 Old 01-14-2010, 03:20 PM
JeffC's Avatar
Originally Posted by Moggie View Post
The solution: my entry for the ghetto tools contest -- doctor my drywall lift into a star panel lifter. The mushrooms prevented the bending of any of the fibers, which had not yet been cut.
Nice! bout damn time to throw down a little Ghetto!
I am kind of worried about what I had planned now. I was not and can not really have the compression method. I like it very much but won't have access to cinch it tight with my current design How does the seam look now prior to tightening up?
Ht Build
Poker table and bar
JeffC is offline
post #243 of 1184 Old 01-14-2010, 07:32 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 35
Brad, Jeff, Glad you have subscribed again
Jeff, the seams turned out very tight and the compression system worked really really well. Here's a closeup of a seam:
And here are a couple of shots of how it all looks now it's hung (I wasn't going to post this until the fiber is cut and I've given the panels a vacuum, but you twisted my arm
My "Old Vic" Theater Build | Screen Build | HT of the Month | Contest Win
My 8 year old daughter: "are contractors the people that mess up your house for money?"
Moggie is offline
post #244 of 1184 Old 01-14-2010, 07:39 PM
raZorTT's Avatar
Looks great Moggie! well done!
raZorTT is offline
post #245 of 1184 Old 01-14-2010, 07:45 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 35
Originally Posted by KNKKNK View Post
subscribed
Brad
Brad, I like the Fosi system (obviously). It is not as tweakable as the micro controlled LED until but there was a number of reasons I went with it: I think it is more realistic looking; the fiber is all 1mm (dimming effects are by the illuminator) and therefore tough. CS at Fosi is really excellent. Also, to me the star ceiling is a lighting fixture. Once working I don't want to tweak it. The only disadvantage I can see is that the default metal halide lamp cannot be dimmed -- you can dim only by using filters. If I really want this in the future I could always change the lamp in the illuminator.
I think you could get away with 5/8" thick panels using the approach I took but you would have to be very careful with the biscuit jointing. My ceiling only hangs down 2 1/4" using the 3/4 ultralight MDF. Alternatively you could go the popular route of using hardboard and framing. The thing is that hardboard always sags over time and if you look at the picture I just posted you can see this ceiling is totally flat. The bottom line was I trusted the experience at Fosi and their advice after building hundreds of these things.
As for resonance, I hope not Of course any panel will have a resonant frequency. Mine are heavy and pretty well damped -- stuffed insulation behind the panels and vented around the edge. The mounts are also damped with the rubber pipe I put over the hanging clips. We shall see what my little tiny weeny subs can do!
Moggie is offline
post #246 of 1184 Old 01-14-2010, 07:48 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 35
This is the job for tomorrow....
Moggie is offline
post #247 of 1184 Old 01-14-2010, 08:06 PM
Audixium's Avatar
Quoted: 30 Post(s)
With each post you are convincing me to NOT do a star ceiling...I mean, how could I ever feel comfortable with mine when you are posting these precision, machine quality, over the top versions of sugar plums dancing in my head?
Audixium is offline
post #248 of 1184 Old 01-14-2010, 08:37 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 35
Audixium, relax, breathe ... save the compliment for *after* I turn it on Really I'm posting my approach (which is a little different from other techniques I've read) in case it is helpful to to others. One thing I will say is that I severely underestimated the effort involved in such a large ceiling. I've probably put 90+ hours into it so far, but after the hardwood light trays are built I think I'll have a really big smile.
Moggie is offline
post #249 of 1184 Old 01-16-2010, 10:48 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 35
Well, what a marathon that was... but finally the ceiling is operational. I put in a 11h day today to get the thing wired up, trimmed and to shoot some pics.
The main job was to fit every individual fiber (about 1000 of them) into the illuminator box. The unconnected bundle in this picture is my second comet position above the bar in case the original position becomes too obnoxious. I used almost all of the 3 miles of fiber! The shooting stars and comet were especially time consuming due to deciphering my markings to get the order correct.
And the carnage:
Then the final step was to trim all the fibers in the ceiling. Fosi recommends using a hot wire so the ends of the fiber mushroom and have a wider angle of light output. I really didn't want to risk burning my fabric panels (hot wire cuts GOM FR701 very well indeed ) so I made another ghetto tool to keep the snip length constant and eliminate the chance of burning the panels.
Then spent another hour on the ladder carefully trimming. My 8yo daughter took this shot so I promised to show it.
The result is that all the fibers end up looking like this which are invisible in even a slightly darkened room:
Then the moment of truth and the results of the past two weeks of labor (I also discovered just how hard it is to photograph with a little snappy camera!)
Here's a couple more.
The second one is of my 8 yo. She thought the ceiling looked so real she disappeared for a few minutes, then came back with blanket, drinks, snacks and a orange glow stick (for a fire).
We both sat under the stars and had a picnic! Totally cool!!
I'm going to bed with a big smile on my face tonight.
nickbuol and linkseo like this.
Moggie is offline
post #250 of 1184 Old 01-16-2010, 11:00 PM
DavidinCT's Avatar
Quoted: 283 Post(s)
Liked: 86
Very cool....
-Dave
MCSE 2003
Windows Media Center specialist - MVP and Certified Home Theater specialist
Avid gamer and home theater junkie..
DavidinCT is offline
post #251 of 1184 Old 01-16-2010, 11:37 PM
raZorTT's Avatar
Wow Moggy, looks awesome!
Thanks again for sharing your construction process and photos, they've been a massive help. We cut and made our first star panel to size today, I hope it comes out as well as yours has.
Cheers,
Simon
raZorTT is offline
post #252 of 1184 Old 01-17-2010, 12:56 AM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 35
Cheers,
Simon
Simon, no worries mate!
The ceiling looks even better in person with the animation. I'm very pleased. Are you using the Fosi system? Hanging panels with clips like mine? (If so, I have a few ideas/tips that I can share).
Cheers.
Moggie is offline
post #253 of 1184 Old 01-17-2010, 01:13 AM
raZorTT's Avatar
I'm going to try and follow as close as possible. Do you think using wooden cleats would be possible instead of the aluminium? my soffit is only 250mm down from the ceiling, so using aluminum would drop the star ceiling lower than I would like.
Would love any tips and tricks you might have though!
Cheers,
Simon
raZorTT is offline
post #254 of 1184 Old 01-17-2010, 05:52 AM
JeffC's Avatar
Moggie Moggie Moggie.......I can't take it, once again simply awesome!
Ht Build
Poker table and bar
JeffC is offline
post #255 of 1184 Old 01-17-2010, 05:56 AM
JeffC's Avatar
Can you share how to build one of these I suspect just a wie shorting out a dimmer?
All the work payed off that big of ceiling is really cool!
Ht Build
Poker table and bar
JeffC is offline
post #256 of 1184 Old 01-17-2010, 06:05 AM
Sokoloff's Avatar
Outrageous! This is yet another "spare no effort" fine touch on your theater. I wish you weren't on the other coast so I could stop by and check it out in all its glory.
Well done Paul!
Sokoloff is offline
post #257 of 1184 Old 01-17-2010, 09:08 AM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 35
Simon (raZorTT), I'll send a PM.
Jeff, the hot wire cutter is actually a loaner from Fosi (I just made the catapolt holder), but it's just a light dimmer and transformer connected to some resistive wire (I believe nichrome is usally used). You can also use a variac instead of the light dimmer. The web is full of DIY plans.
Sokoloff, thank you. Shame about the location, I'd love to show you.
Moggie is offline
post #258 of 1184 Old 01-17-2010, 10:19 AM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
CRAP I had just about convinced myself I was just going to do a fabric ceiling but after seeing the outcome of your star ceiling I am now really torn AAAaAaAaaAAaaaaa the horror of it all
Scott
The CopperFields Cinema
          Current Photo's
W00lly is offline
post #259 of 1184 Old 01-17-2010, 11:19 AM
jdodd64's Avatar
I'm far from building my own home theater but after seeing your ceiling I know I am going to have to put one of those in. The room is looking great.
Jeff
Success is not final, failure is not fatal: it is the courage to continue that counts. -- Winston Churchill
jdodd64 is offline
post #260 of 1184 Old 01-17-2010, 12:20 PM
dchaves's Avatar
That's a seriously good star ceiling. Best I've seen yet.
dchaves is offline
post #261 of 1184 Old 01-17-2010, 01:39 PM
mike2060's Avatar
Very nice job on everything! You make it looks so easy!
In regards to your LCR being partially enclosed in your screen wall, make sure you stuff around the speakers with insulation or something to make sure the cavity doesn't resonate and make your speakers sound boxy and distort their low end.
mike2060 is offline
post #262 of 1184 Old 01-17-2010, 01:59 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 35
I told you to do a star ceiling. Even posted in your thread It was a lot of work but I'm still smiling!
Thanks very much guys.
The power and illusion of the web, that's all
Mike, good point. I was planning to do this. The speaker are in place for some baseline room measurements before treatment. The speakers are recessed about half way, not because of a short room but because I couldn't seem to avoid having the front row of seats at the 50% point. Recessing the speakers helps move the row 18" from the mid point. I did consult the audio forum and klipsch forum and both confirm that these speakers should be fine in this configuration. I guess it is do to with the front radiation pattern of the horn design?
Moggie is offline
post #263 of 1184 Old 01-18-2010, 06:36 AM
In2Photos's Avatar
Very nice Moggie! And the pic of your daughter is priceless!!! Mine would want to have a "camp out".
Mike
In2Photos is offline
post #264 of 1184 Old 01-18-2010, 06:39 AM
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 123
[Subscribed]
Fantastic job Moggie. Great inspiration while I plan out my theater.
mcascio is offline
post #265 of 1184 Old 01-18-2010, 10:00 AM
KNKKNK's Avatar
Quoted: 39 Post(s)
Liked: 103
+1
First Class workmanship all the way, outstanding results...
I think W00lly said it better than I could....AAAaAaAaaAAaaaaa
I had seriously waffeled on a ceiling originally, but wrote it off.. (becasue of Laziness). But you've convinced me to at least make provisions for one. Particullarly since it looks like it can be accomplished in ~2-3" of height.
Brad
P.S. Mega cool picture of the daughter under the stars
KNKKNK is offline
post #266 of 1184 Old 01-18-2010, 06:40 PM
raZorTT's Avatar
Thanks again for sharing Moggie!
I was able to start my first panel last night
Map projected onto panel
Countersinking for fibre/glue
When ants attack
Cheers,
Simon
raZorTT is offline
post #267 of 1184 Old 01-18-2010, 06:46 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 35
Brad, I appreciate the thumbs up. One thing I find very inspirational about this forum is the camaraderie and continued pushing to go that extra mile. I know my theater will be better as a result of it. I wonder how many people there are out there thinking about how to incorporate lions into their theater designs, LOL.
Whilst I've been busy on the ceiling, a bunch of packages arrived from bpape (the bulk of the acoustic treatment).
I started cutting the corner traps today but before fitting I wanted to take some baseline measurements, so....
I spent a good part of the day learning REW (Room EQ Wizard) and lugging down some equipment into the theater, then...
Despite reports of seismic activity on the west coast it is really nothing to worry about, I was just running some test tone sweeps through these babies
I purchased these Klipsch subs as part of a package on eBay before deciding on a IB sub up front. Rather than waste them, and after bpape's advice to make provision for a rear sub "just in case" I naturally took the next step and designed in rear subs. I also purchased a SVS EQ1 sub equalizer which is unique in being able to automatically integrate two subs. I plan to periodically take measurements (both with and without the EQ1) as I build the acoustic treatment since I'm curious to understand the benefit of each component. The problem is that after just a couple of minutes of use my USB sound card gave up. I should have a replacement later this week and will continue measurements then
In addition to the subs I also got the LCR's wired up and plugged in a spare Sonos zone player to enjoy some tunes.
The only music that I bare to listen to in such a bare room were live albums so I sat for a while with glass of Chianti and listened to Pink Floyd "Delicate Sound of Thunder" with outrageous uncontrolled base.
Moggie is offline
post #268 of 1184 Old 01-18-2010, 06:51 PM - Thread Starter
Moggie's Avatar
Quoted: 25 Post(s)
Liked: 35
When ants attack
Cheers,
Simon
LOL. This last photo is funny! Looks like the surface of the moon. In case anyone is wondering Simon had a great idea of counter sinking the rear side of the fiber holes to aid the bending of the fibers and to serve as a pot for glue.
Given that you are down under is that the southern hemisphere star field?
Moggie is offline
post #269 of 1184 Old 01-18-2010, 07:01 PM
carboranadum's Avatar
Quoted: 22 Post(s)
Liked: 26
The star ceiling looks GREAT! Thanks for the write up.
CJ
carboranadum is offline
post #270 of 1184 Old 01-19-2010, 07:32 PM
raZorTT's Avatar
Hi Moggie,
Spot on! It's a map of the southern sky that I found on http://www.starfinders.com/
I've been meaning to do some measurements with REW in my room before and after treatments. Did you get any where with the software before your sound card gave up?
Cheers,
Simon
raZorTT is offline
Klipsch Kw 120 Thx Subwoofer , Jvc Dla Rs40u , Dune Hd Smart H1 1080p Media Player , Klipsch , Behringer Europower Ep4000 Professional Amplifier , Outlaw 7500 , Integra , Oppo Bdp 83 Blu Ray Player , Sonos
