Please design my home theater - I have no idea what i'm doing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 03-28-2009, 04:42 PM - Thread Starter
imblind's Avatar
Hi all,
I have no idea how to set this up and would really appreciate some help.
The basement room is 11'x20' and the ceiling is 7'5" high. Viewing distance is 14'
I'd like to mount the projector on the ceiling, what mount should I use for my HD1000U?
Where is the optimal location for the bookshelf speakers? Floor, Stand, Ceiling? Distance from viewer?
How should I go about sound insulating this basement room?
Where should I place the speaker connection wall plates? Floor or ceiling?
Basically I need to know all the supplies I will need to wire everything up.
imblind is offline
post #2 of 20 Old 03-28-2009, 04:55 PM
Quoted: 3255 Post(s)
Liked: 2743
You have an excellent space to work with.
You could have a spectacular theater.
You could do 2 rows of seating with back row on risers.
So far I see only three strategic errors.
Putting the screen on the wall near the entrance limits your potential to build a really great front end and is already making you think you shouldn't center up the screen in the room. It might work better on the other end.
I see the beginnings of a drop ceiling which I hope is in the process of being removed rather than going in. It will kill your hopes of containing the sound.
Thinking the first row needs to be at 14 ft.
post #3 of 20 Old 03-28-2009, 05:03 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Step 1: clean up your space. Seriously; things will come more into focus.
CD
CDLehner is offline
post #4 of 20 Old 03-28-2009, 05:13 PM - Thread Starter
imblind's Avatar
Thanks for the reply!
The entrance from the stairs is pretty tight so I thought having the seating on the other side would provide more maneuverability.
I'm currently tearing the basement up, taking off the crappy wood walls and drop ceilings
I have no idea where the seating should be, I am all ears
imblind is offline
post #5 of 20 Old 03-28-2009, 05:52 PM
srizvi's Avatar
A really neat utility I found for calculating about where to place your seating was on the Projector Central website. Its their projection calculator pro. Its just a quick online utility. You define your screen dimensions, your projector, how the projector is mounted etc and it gives you rough estimates on the ranges of where your seating should go and how far your projector needs to be from the wall to achieve your desired image size.
srizvi is offline
post #6 of 20 Old 03-28-2009, 06:47 PM - Thread Starter
imblind's Avatar
BIG, could you give some pointers on what materials I need to buy? Where should I put the receiver and cable box?
imblind is offline
post #7 of 20 Old 03-28-2009, 08:13 PM
Liked: 2743
You shouldn't be buying anything yet. Nor would I recommend anything.
I want to see the space cleaned up, Pictures of all the utilities and HVAC in the ceiling and adjacent spaces.
A measured floor plan posted so that we can see what you are working with
A tentative idea of what projector, screen size, speakers and seating type you are planning. Or at least a budget of what you are willing to spend.
Demonstrated knowledge of the 4 principles of sound containment as documented in the library of articles on the www.soundproofingcompany.com website.
Then we can begin the design process and help you with material choices..
post #8 of 20 Old 03-28-2009, 08:30 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
BIG, he tried to play Mom against Dad. No comment on which of us is which.
CD
CDLehner is offline
post #9 of 20 Old 03-28-2009, 09:55 PM - Thread Starter
imblind's Avatar
Aw man, looks like I gotta clean my room
imblind is offline
post #10 of 20 Old 03-29-2009, 12:28 AM
ScruffyHT's Avatar
While you are cleaning up do a detailed drawing as suggested so that the design process can continue
ScruffyHT is offline
post #11 of 20 Old 03-29-2009, 06:52 AM
Cathan's Avatar
And spend a month or two reading all of the large construction thread from beginning to end. In other words, clean your room and then do your homework.
Cathan is offline
post #12 of 20 Old 03-29-2009, 07:21 AM
dc_pilgrim's Avatar
I linked Big's starting point post in my sig. Read that - but measured floor plan with utilities and obstructions is a crucial first step.
dc_pilgrim is offline
post #13 of 20 Old 03-29-2009, 07:46 AM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Well-played; we crack ourselves up at this guy's expense, don't we.
CD
CDLehner is offline
post #14 of 20 Old 03-29-2009, 08:38 AM
kjlewie's Avatar
Quoted: 69 Post(s)
Liked: 88
+1
In the parlance of cleaning your room and doing your homework, clicking the suggested link is like getting the study notes (OK, cheatsheet) from an honors student. Do it...and all the other stuff suggested as well.
Audio: Marantz AV7702mkII / Marantz MM8077 / Emotiva UPA-7 for 7.2.4 Atmos/DTS:X - Video: Sony VPL-VW600ES & SI Black Diamond 133" 2.35:1 CIH for 4K UHD - Sources: Oppo BDP-103D, Mede8er 600d with Synology ds716 NAS (28tb), PS4, DirecTV - 7. Paradigm Studio 20 v5 (L, R, FW), Studio CC-590 v5 (C), Sonance VP63 (SS); 2. DIYSG Dayton HO 18" (4); PSA S3000i (3); 4! Infinity Entra One (FH), Sonance VP65R (TR)
kjlewie is offline
post #15 of 20 Old 03-29-2009, 10:38 AM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Originally Posted by kjlewie View Post
+1
Poor guy; I imagine he's long gone by now. As GC would say, it's like we're "beboppin' and scattin' all over him".
CD
CDLehner is offline
post #16 of 20 Old 03-29-2009, 10:47 AM
Cathan's Avatar
I hope not as he's local and we are trying to help.
Cathan is offline
post #17 of 20 Old 03-29-2009, 03:23 PM - Thread Starter
imblind's Avatar
You cant get rid of me that easy!
imblind is offline
post #18 of 20 Old 03-29-2009, 03:42 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Nah, please know that we're just having some fun. As BIG said earlier, your space has great potential; it should turn out just fine. All the kidding and puns aside, get it cleaned up, post some new pics and plans, read through the other build threads to get ideas, and the group will get you where you want to go.
CD
CDLehner is offline
post #19 of 20 Old 03-29-2009, 03:59 PM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
And instead of those little click photo's put up some full size pics that we don't have to click on Cuz we are a lazy bunch here and the eaiser you make it for us the more imput you will get
Scott
The CopperFields Cinema
          Current Photo's
W00lly is offline
post #20 of 20 Old 03-29-2009, 04:46 PM
Liked: 2743
stick with us and we will help you have something like this:
