Dust-proof rack/enclosure for wood shop? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-03-2009, 12:48 PM - Thread Starter
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
Anyone have any suggestions for keeping dust out of my equipment?
I'm setting up some woodworking tools in my basement, and want to put 2 channel audio in the workshop. Even though I have a dust collection system (1.5HP Delta 12 CFM ducted + ceiling mounted 850 CFM unit for secondary dust), I'd like to put 1-2 components in the shop.
Also, my whole-house audio equipment is going into the basement.
Basically 2 problems:
1. Cabinet for 1-2 components.
2. Rack enclosure.
Any/all suggestions/comments appreciated.
I'm thinking that whatever option(s) I choose, I'm going to end up with a filters on intake vents.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #2 of 10 Old 04-03-2009, 07:01 PM
dododge's Avatar
2. Rack enclosure.
You can certainly get sealed/filtered enclosures for placing computer gear in hazardous environments, and with appropriate shelves these can be used for just about any sort of electronics. The problem is that this is likely to be a high-end item with industrial certifications and corresponding high-end prices. For example the Black Box ClimateCab is about two feet high, wall-mountable, and has an integrated air conditioner -- but lists for around $2700.
dododge is offline
post #3 of 10 Old 04-05-2009, 02:24 AM - Thread Starter
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
$27.00 - that's just MSRP. I can shave at least 10% off that...
Oh, wait.
What?
Hey, yeah, dododge, thanks for that.
Neurorad is offline
post #4 of 10 Old 04-05-2009, 02:38 AM - Thread Starter
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
$2700, includes air conditioner.
$1000, NEMA 12 rated enclosure only, includes fan.
So the secret phrase is "NEMA 12", for dust control.
Neurorad is offline
post #5 of 10 Old 04-05-2009, 04:44 AM
localnet's Avatar
I would set it up in a closet or another room in your basement, and use an IR repeater off of your whole house audio gear or one of those pyramid IR/RF units. I hope you are separating your gear and whole house equipment away from the dust in another room.
localnet is offline
post #6 of 10 Old 04-05-2009, 05:34 AM
Quoted: 3908 Post(s)
Liked: 3338
I have had receivers/boom-boxes in my very dusty wood shop for years, I do not have a dust control system and everything is covered in dust. I do not have a hermetically sealed space for the receiver. I just vacuum it off once and awhile.
Buy a cheep receiver off of Craig's list and forget about it.
post #7 of 10 Old 04-06-2009, 07:30 AM - Thread Starter
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
BIG, you're awesome.
This is what I wanted to hear.
This is the perfect solution...until I install the whole-house audio system.
Which, unfortunately, is going in the basement.
I think I'll need to consult and HVAC specialist, eventually, to keep the dust out of the rest of the basement. Currently, the only return is in the kids playroom, so all dust will be heading that way.
I did some sanding with the random orbital last night, hooked up to the 1200 CFM 110v collector. The amount of dust is significantly reduced, compared with no collector, but it will definately be a problem. I haven't installed the ceiling-mounted unit yet, but that should help a little too.
Maybe I can get away with delaying the HVAC return revision for 6 years, at which time the playroom becomes a media room.
Neurorad is offline
post #8 of 10 Old 04-06-2009, 07:40 AM - Thread Starter
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
BIG, or anyone else, what furnace filter should I use? Tell me your favorite make/model. I need to buy a box, for the HVAC return.
There are several 'vents/grills' in the walls in the basement (I forget the correct name for them, I think BIG mentioned the name in another thread) that allow air to pass from room to room, to get back to the main return duct opening. I bet if I add filtration to a couple of them, it will help.
Eventually, I'll have to add a dedicated return from the workshop, with some good filtering, to avoid dust in the rest of the basement.
Neurorad is offline
post #9 of 10 Old 04-06-2009, 08:57 AM
Liked: 3338
If you find that dust migrates out of your workshop you should think about installing a simple exhaust fan that sends the air in the workshop outside. Hook it up like a bathroom exhaust fan and use a Dryer vent cover on the outside. Leave it on while you are doing your wood working and it will create a negative pressure in the shop compared to the other rooms. That means all drafts with be into the workshop and the dust will not migrate to other rooms. You could even get a delay shut off wall switch that leave is on a little bit after you leave.
post #10 of 10 Old 04-06-2009, 11:06 AM - Thread Starter
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
Thanks, Big. I'm trying to avoid venting to the outside - I already have that problem in the basement bathroom. Currently not 'to code', I believe.
Any tip on furnace filters? Good model or rec'd material/design?
HEPA vs. pleated? Electrostatic?
Neurorad is offline
