Electrical Boxes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 04-13-2009, 05:33 PM - Thread Starter
olson2334's Avatar
Hello,
I am going through now to try and apply the face plates to my outlets that were put in. I noticed that I have about 6 boxes that are protruding from the sheetrock by about 1/8 inch or so. When I try and apply a faceplate now i see that the faceplate does not sit against the wall due to this. Can I grind the plastic down on these boxes so that it sits flush with the sheetrock and get these face plates to look nice or do you have any other ideas?
Thanks for the help.
olson2334 is offline
post #2 of 29 Old 04-13-2009, 06:03 PM
Quoted: 3257 Post(s)
Liked: 2743
I've had some success in the past by placing a scrap of 2x4 over the box and giving it a whack.
post #3 of 29 Old 04-13-2009, 06:49 PM
mbec's Avatar
If you used plastic boxes, you could shave them flush to the wall surface, in doing so, you will violate the UL listing and as a result NEC 110.3b. That being said, yes it will work just fine (though you may need to use shorter 6x32s.)
rob
Marks Brothers Electrical Contractors LLC.
mbec is offline
post #4 of 29 Old 04-13-2009, 07:16 PM - Thread Starter
olson2334's Avatar
Thanks for the replies.
I have tried that trick as well with limited luck this go around but unfortunately these are being stubborn and did not take to the 2x beating.
Does it make a difference if they were the deeper box as far as violating the ul rating?
Also, would one just use a grinder do you think to grind them down or would there be something better to limit dinging the walls around them up?
post #5 of 29 Old 04-13-2009, 07:29 PM
Steve Smith's Avatar
Quoted: 72 Post(s)
Liked: 27
I took a sawzall, wedged it between the edge of the box and stud then cut the 2 nails holding the box to the stud. After it's loose reposition it where you want it and use a couple of screws to secure it to the stud.
Steve Smith is offline
post #6 of 29 Old 04-13-2009, 07:33 PM
mbec's Avatar
It doesn't.
One should make this decision based upon One's particular skill level with various tools. If it were me, I would use a rotozip. You might feel more comfortable with a grinder or dremel with cutoff wheel. Any number of tools are capable of getting the job done.
Remember to stuff the wires to the back of the box and to wedge a couple of layers of cardboard in front of them.
A little painters tape on the wall around the box will help prevent getting the wall soiled.
rob
mbec is offline
post #7 of 29 Old 04-13-2009, 07:42 PM
MauneyM's Avatar
Quoted: 78 Post(s)
Liked: 38
No - changing the dimensions invalidates the UL listing, as it is a field modification. However, the depth (volume) of the box is what determines how many wires and connections it can legally hold, per NEC. If you aren't at or near the limit, you won't really cause a problem by grinding it down. That said, the electrical inspector would be well within his rights to deny you the final permit based on that sort of "mod". You might be best served to let the boxes protrude a bit until after the inspector has signed off on the project.
Dremel or RotoZip.
MauneyM is offline
post #8 of 29 Old 04-14-2009, 10:21 AM
Allan Jayne's Avatar
I do not like the idea of whacking the box with a 2x4.
1. You could crack the brackets holding the nails or screws already in use to hold the box on the stud.
2. You could loosen the nails or screws holding the box on the stud and in the future someone tugging on a cord and plug might make the box come loose.
3. You could crumble the drywall where its nails or screws hold it to the stud (particularly if a seam is at the same stud the box is at.
Video hints: http://www.cockam.com/theater.htm
Remember when lines and logos burned the TV screen? I was at a concert where a musical selection made extremely heavy use of about four of the keys of the piano.
Allan Jayne is offline
post #9 of 29 Old 04-14-2009, 11:25 AM
jdholmes's Avatar
Use some caulking to close the gap...much easier than all this mess.
jdholmes is offline
post #10 of 29 Old 04-14-2009, 01:52 PM - Thread Starter
olson2334's Avatar
I figured I would try Steve's suggestion and cut the box with a sawzal and see how that goes. Will just have to be extra careful to not nick the wires behind there.
post #11 of 29 Old 04-14-2009, 03:18 PM
MauneyM's Avatar
Quoted: 78 Post(s)
Liked: 38
Please, please, please - turn off the breaker feeding that box before you start with the sawzall...
MauneyM is offline
post #12 of 29 Old 04-14-2009, 03:31 PM
Speedskater's Avatar
Quoted: 20 Post(s)
Technically under UL/NEC rules, you can't modify any electrical devices. All units must be used only for the purpose's that it was designed and listed for.
Kevin
Speedskater is offline
post #13 of 29 Old 04-15-2009, 07:05 AM
jdholmes's Avatar
He's not modifying an electrical device. A box holds no current. Nor is he using for any other purpose than originally intended.
jdholmes is offline
post #14 of 29 Old 04-15-2009, 09:44 AM
rgroves's Avatar
If SpeedSkater's concern about modifying an electrical box then here's a solution...Cut the new work box out and replace it with an old work box.
I'M FORMAT NEUTRAL
13 HD and no more
10 BR
300+ SD
rgroves is offline
post #15 of 29 Old 04-15-2009, 11:33 AM
sknyfs's Avatar
Thats why I always buy the 4x4 boxes that sit flush with the studs and then buy either 1/4,1/2 or 5/8 offset brackets
Loganed - A long time ago.
My DVD Collection
My Build Thread - "under construction"
PSN: AtsymSknyfs
sknyfs is offline
post #16 of 29 Old 04-15-2009, 12:27 PM
DMF
DMF's Avatar
Or use adjustable-depth boxen.
No matter where you go. ... There you are.
DMF is offline
post #17 of 29 Old 04-15-2009, 07:11 PM
ctviggen's Avatar
Quoted: 116 Post(s)
Liked: 32
I've seen these for one outlet, but where do you get them for multiple outlets?
Bob
ctviggen is offline
post #18 of 29 Old 04-16-2009, 05:58 AM
Liked: 2743
they come in single or double.
post #19 of 29 Old 04-16-2009, 06:11 AM
jdholmes's Avatar
I've never been able to find those yet - of course I can't seem to find the regular plastic boxes either...maybe they don't bring them to eastern Canada?
jdholmes is offline
post #20 of 29 Old 04-16-2009, 02:09 PM
Kensmith48's Avatar
Quoted: 53 Post(s)
Try Arlington Electrical. Go to the "What's New" section they have single, double, 3 and 4 gang + the octogon shape for sconces. You have to e-mail them and ask for a distributor or store though.
Kensmith48 is offline
post #21 of 29 Old 04-16-2009, 08:04 PM
MauneyM's Avatar
Quoted: 78 Post(s)
Liked: 38
Tell that to the inspector. The box is a UL listed product approved for certain uses in residential electrical applications, and cannot be modified without invalidating the listing. It doesn't matter that it seems to be "common sense".
You could make the same argument about ANY electrical equipment enclosure, and I guarantee you it won't fly.
MauneyM is offline
post #22 of 29 Old 04-17-2009, 08:59 AM
tbain's Avatar
tbain is offline
post #23 of 29 Old 04-19-2009, 01:18 AM
dododge's Avatar
Is there enough flex that you can you make the box flush by simply pushing on it without too much pressure? If so, pick up a set of metal old work box mounts:
You want the DS12A style. I have found them (not sure it was this exact brand) at Home Depot or Lowes but I had to hunt around the electrical section a bit. These are intended for old work metal boxes: the box has flanges that sit on the face of the drywall and these pull the box tight against the wall from the back side, clamping it in place. If however you use them on a new work box with no flanges, they have the effect of pulling the box into the wall to a set depth. Basically you can insert them into the wall, push the box flush by hand, bend the tabs, and they will keep the box from popping back out.
I have no idea if using these on a plastic box for this purpose is a code violation, but you don't have to modify the box to try it and you can take them back out if it becomes a concern.
dododge is offline
post #24 of 29 Old 04-19-2009, 07:57 AM
mbec's Avatar
If he's replacing a plastic single gang box with a jem box, there will not be any drywall for the jem box ears to grab.
He could move the ears to the side position and madison hanger top and bottom, but then he will need to use an oversized coverplate to conceal the jem box ears.
mbec is offline
post #25 of 29 Old 04-19-2009, 08:33 AM
dododge's Avatar
I wasn't talking about replacing the box; but rather just using the hangers to push his existing plastic boxes flush with the wall surface. In this scenario there is no need for ears on the outside of the drywall because the box is already attached to the framing.
dododge is offline
post #26 of 29 Old 04-19-2009, 09:08 AM
mbec's Avatar
Gotcha, I misunderstood.
How would you go about bonding the madison hangers on a plastic box?
mbec is offline
post #27 of 29 Old 04-19-2009, 04:35 PM
dododge's Avatar
Why would you have to bond them? The force of the box against the back side of the wall (because it was mounted too far outward on the stud) should keep them in place. The only time I've ever encountered them in their original purpose, they weren't bonded to the metal box, either.
dododge is offline
post #28 of 29 Old 04-19-2009, 05:03 PM
mbec's Avatar
They would need to be bonded because they are conductive, likely to become energized, and not grounded. You could likely have 120 volts wrapping around the face of the box and back behind the drywall unprotected. Shock hazard, arc fault, etc... In fact, if someone put a metal coverplate on an isolated ground duplex in this installation, the plate itself could easily become energized at 120volts and kill someone.
On a metal jem box, the hangers are electrically continuous with the metal jem box which is bonded to the equipment grounding conductor. So when a hot wire contacts them, the fault current travels through the madison hangers, then the box, then the equipment grounding conductor back to the bonded panel, turning off the breaker hopefully before any damage is done.
That being said, I very seriously doubt they are listed for use with plastic boxes just for the above reason.
rob
mbec is offline
post #29 of 29 Old 04-19-2009, 05:14 PM
dododge's Avatar
Whoops, by "bonding" I was thinking physically rather than electrically.
I agree that the issue of them becoming energized is why this approach is probably out of code. I suppose you could solder/clamp/screw a grounding pigtail to one of the tabs, but that might raise even more eyebrows at inspection time.
dododge is offline
