Will "Great Stuff" expanding foam provide any sound blocking? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-30-2009, 12:17 AM - Thread Starter
accts4mjs's Avatar
Hello acoustic experts,
I bought a can of "Great Stuff" expanding foam spray tonight to use in some holes I had to drill in my ceiling joists to run speaker wire for a 7.1 setup. I thought I might try to spray some of it into the outlet boxes in my daughter's room next door to try and get a better acoustical seal between her room and my theater. Will this provide any benefit or am I just wasting my time? If it does provide benefit will it be noticeable or should I still spend the money and get a decent acoustic caulk instead?
Mike
accts4mjs is offline
post #2 of 7 Old 04-30-2009, 05:15 AM
Cathan's Avatar
Well it would make it "air tight" but it is also a closed cell rigid foam so adds to coupling. I used the stuff around my door frame, but nowhere else since it's never been recommended over the alternative (caulk and/or putty pads).
Cathan is offline
post #3 of 7 Old 04-30-2009, 07:31 AM
Quoted: 3255 Post(s)
Liked: 2743
If you have access to the rear of the boxes putty pads are a better alternative.
I would be very leery about filling an electrical box with that foam. It expands to fill every nook and cranny. If you have to do any further work in the box or even just replace the cover you will have a big mess on your hands.
post #4 of 7 Old 04-30-2009, 07:37 AM - Thread Starter
accts4mjs's Avatar
Thanks guys, I think I'll just fill the ceiling joist holes I cut and leave it at that.
Mike
post #5 of 7 Old 04-30-2009, 07:52 AM
CJO
CJO's Avatar
Also, you can get acoustic caulk for fairly cheap. May as well use what's best.
CJ
coneilliv at aol dot com
The Dark Knight Theater
(a bunch of good reference links and material in first 15 posts)
CJO is offline
post #6 of 7 Old 04-30-2009, 08:54 AM
kjlewie's Avatar
Quoted: 69 Post(s)
Liked: 88
I also used it around a couple of doors where my poor rotozip skills cut too much of my second layer of drywall, but I added acoustic caulk at the first layer of drywall. As mentioned, it really expands. I wouldn't think it would be a good idea for outlet boxes.
Good luck.
Audio: Marantz AV7702mkII / Marantz MM8077 / Emotiva UPA-7 for 7.2.4 Atmos/DTS:X - Video: Sony VPL-VW600ES & SI Black Diamond 133" 2.35:1 CIH for 4K UHD - Sources: Oppo BDP-103D, Mede8er 600d with Synology ds716 NAS (28tb), PS4, DirecTV - 7. Paradigm Studio 20 v5 (L, R, FW), Studio CC-590 v5 (C), Sonance VP63 (SS); 2. DIYSG Dayton HO 18" (4); PSA S3000i (3); 4! Infinity Entra One (FH), Sonance VP65R (TR)
kjlewie is online now
post #7 of 7 Old 04-30-2009, 09:46 AM
Weasel9992's Avatar
Completely, totally agree.
Frank
Frank Oesterheld
Weasel9992 is offline
