Getting Started w/ HT - Some questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-28-2009, 01:34 PM - Thread Starter
GregStarling's Avatar
I'm moving into a house that has a home theater room.
A few questions. The room is 9' 9" wide, 16' 9" long and 10' tall. The door is at what would be the back of the theater.
Do I have room for:
A false front
A stage
2 rows of seating (riser)
soffits with recessed lights
I've been reading this forum on and off for years waiting for this day. Wish I was in on the initial construction as I've always had a dream HT in mind, but I'm excited to be working with this one. Any help is greatly appreciated. Once I get going, I'll start a build thread. I've really enjoyed reading many of yours.
GregStarling is offline
post #2 of 8 Old 05-28-2009, 01:59 PM
Quoted: 3903 Post(s)
Liked: 3336
you can do a false front OR 2 rows with riser not both.
If you do two rows of fully reclining Berkline chairs it will be nearly impossible. The riser needs to be 6 1/2 feet deep.
The best way to fit the maximum seating in such a space is to get some used real theater seats. Or at least non reclining seats for the back row.
See seatsandchairs.com
You can do a false wall with the screen very near the front wall (see britinVA build thread) and not require any additional space.
post #3 of 8 Old 05-28-2009, 02:04 PM
jamis's Avatar
I would say that you could possibly get two rows of berkline style recliner seats with a riser... but not with a false wall (unless you compromise on the screen size).
If you went with 'theater style' seats (smaller) in at least one row, you might be able to do a false wall as well.
In either case, a stage would be doable and any potential false wall would have to be fairly shallow. Instead of a false wall you could also go for in-wall speakers and hang an acoustically transparent screen over them.
jamis is offline
post #4 of 8 Old 05-28-2009, 02:05 PM
jamis's Avatar
Curses.... foiled again!
*shaking fist*
jamis is offline
post #5 of 8 Old 05-28-2009, 02:10 PM - Thread Starter
thanks for the quick responses.
if i didn't do a false front, where would you typically put the sub?
post #6 of 8 Old 05-28-2009, 02:17 PM
jamis's Avatar
Typical placement is usually along the front wall (usually in one of the corners to start).
Other options include next to or behind seating, under cofee/end tables, or anywhere else they will fit.
jamis is offline
post #7 of 8 Old 05-28-2009, 02:33 PM
Liked: 3336
See Brit's build.
summarized here:
http://www.avsforum.com/avs-vb/showt...light=britinva
post #8 of 8 Old 05-28-2009, 06:48 PM
CDLehner's Avatar
Quoted: 773 Post(s)
Liked: 1151
Yeah, I agree with everyone else; you don't seem to have room for both a false front and 2 rows. OTOH, at only 9'9" wide, I would go AT to maximize the screen size. I'm with Jamis; if sound isolation isn't a huge concern for you, maybe go with some of the better in-walls across the front, and an AT screen.
CD
CDLehner is offline
