My completed Theater with PICS! - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #121 of 144 Old 11-21-2010, 04:29 AM
tony123's Avatar
Liked: 38
Cabo, looks great! I just realized how close our color schemes are. I've got a dark blue ceiling with rope light soffit and I'm not quite getting the effect I was after. Did you have to play with yours any to get it right? any tips? I'm looking for a smoother cast.
The "Twinseltown" Theater
Construction Thread
tony123 is offline
post #122 of 144 Old 11-24-2010, 03:32 PM - Thread Starter
GoCaboNow's Avatar
Quoted: 875 Post(s)
Liked: 765
Thought I'd check put your thread to see how your soffits are but I could not find them in that huge mess of a thread you have. Just kiddin. Very nice room. Love your subs.
Actually, I could not find them so not sure what might be different compared to mine? Mine are pretty basic with drywall painted flat black. The white led rope I use makes it look blue. There is bracing to move the rope up to near the top of the soffit's inner wall and the rope sits about 4" from the outer wall of the soffit. Hope this helps? Either that or it is the layer of dust diffusing the light...
GE84 likes this.
My Dedicated Home Theater Room
GoCaboNow is offline
post #123 of 144 Old 11-24-2010, 03:42 PM - Thread Starter
GoCaboNow's Avatar
Quoted: 875 Post(s)
Liked: 765
Made a few changes to the room. Swapped out the existing side acoustic material and replaced it with 2" oc703. I meant to use this in the original construction but I could not find a good source so I punted and went with a compromise solution. Nothing beats the oc703. But this may be kind of hard to see. What you can see is that I am psychotic. I cut my granite slab off the bar. Then raised the bar 16" and re-attached the granite. I built a mini hush box under the granite for the pj and it is a little more discreet in the room without losing it's retro reflective efficiency with my high power screen. The view from the bar is better too. Has a command central feel to it now.
Old view
wizzack and GE84 like this.
post #124 of 144 Old 03-01-2011, 03:04 PM
fight4yu's Avatar
Liked: 43
Yes. definitely liking the new look.
I always wish I can be that hands-on in building frames, cutting slabs and etc... Your theatre looks absolutely stunning and with that low cost, had to be one of the best price/performance category!
Sometimes, I wonder if any of you DIY would want be willing to do some contract work for a small fee
BTW, I like your idea of keeping the same image size for both 1.78 and 2.35 format. Given I do not see a A-lens in your setup, I assume you will be doing the zoom method.. Now, given your setup is not a CIH, do you have to constantly change the vertical lens shift?
fight4yu is offline
post #125 of 144 Old 03-01-2011, 04:48 PM
edmove's Avatar
Old view
Did you do any before and after room measuring to see if there was any benefit to the 703 upgrade?
edmove is offline
post #126 of 144 Old 03-17-2011, 08:19 AM
stockmonkey2000's Avatar
Liked: 30
Your theater looks great - I cant believe I had not come across yours before - I thought I had searched every thread with an IB for sure. I debated doing an IB array like yours - I really like the look. I noticed your post where you said your house creaks when you crank up the subs - Is there anything that you would have done differently in construction to eliminate this - I'm hoping OSB and double drywall with green glue in between each layer will not squeak.
stockmonkey2000 is offline
post #127 of 144 Old 03-17-2011, 09:39 AM - Thread Starter
GoCaboNow's Avatar
Quoted: 875 Post(s)
Liked: 765
Very good question. Unfortunately, I don't.
Other than what I hear, I can see a drastic difference in how Auddysey sets up my channel levels as these are bumped up 2-3 db.
post #128 of 144 Old 03-17-2011, 09:49 AM - Thread Starter
GoCaboNow's Avatar
Quoted: 875 Post(s)
Liked: 765
Yeah, no lens so I zoom. The RS10 pj has powered zoom and focus. I have hot keyed these into the Harmony RF 890 remote so it is very easy to change aspect and focus. I can get right next to the screen to adjust focus and not have to point the remote at the pj. That said, would be nice if it had memory.
GE84 likes this.
post #129 of 144 Old 03-17-2011, 10:19 AM - Thread Starter
GoCaboNow's Avatar
Quoted: 875 Post(s)
Liked: 765
I tried to do a manifold, but it boiled down that the only spot I had was too close to the side walls so the driver would be right next to a wall - the array was the only option. I have not improved the back wave at all yet. It is still open framing. One of these days I will get around to finishing it with OSB, DD and GG. Fortunately, the back wave is in an isolated part of the house and takes a really special ULF scene to impact the main living areas - or my wife would have made it a priority for me.
GE84 likes this.
post #130 of 144 Old 12-21-2011, 12:35 PM - Thread Starter
GoCaboNow's Avatar
Quoted: 875 Post(s)
Liked: 765
Have not posted for a while but have still been busy working on the room. Seems like you are never truly done - if you don't want to be.
One of the things I just added was fabric posters to the side walls. My wife likes the fabric look better than paper posters and there is zero reflection off them. The frames are velvet wrapped as well so really disappear during a movie.
Thanks again to this thread for clueing me in to these fabric posters.
http://www.avsforum.com/avs-vb/showt...ical+movie]DYI Movie Poster Acoustical Panels[/url]
[URL="http://www.avsforum.com/avs-vb/showthread.php?p=20815913#post20815913
GE84 likes this.
post #131 of 144 Old 12-21-2011, 01:12 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
Very slick, I really like the look of those posters. Well done.
RTROSE
RTROSE is offline
post #132 of 144 Old 12-22-2011, 09:18 AM
b_scott's Avatar
Quoted: 46 Post(s)
Thor and Puss in Boots....? :P
b_scott is online now
post #133 of 144 Old 12-22-2011, 09:50 AM - Thread Starter
GoCaboNow's Avatar
Quoted: 875 Post(s)
Liked: 765
I know, classics.
Actually, Thor is the god of thunder which is appropriate for a theater with an IB set up.
The posters are more for my kids and as they grow older maybe the posters will change? The posters are really pretty cheap and easy to change out. Depending how you format your file the posters are $14-19 each landed. So pretty painless to swap them out on a whim or as something new comes out.
GE84 likes this.
post #134 of 144 Old 12-22-2011, 09:55 AM
b_scott's Avatar
Quoted: 46 Post(s)
haha fair enough. Sad what the kids grow up with these days in comparison to me in the 80s. Of course, rose colored glasses and such. But still, Labyrinth!
post #135 of 144 Old 12-22-2011, 10:44 AM
J_P_A's Avatar
Quoted: 642 Post(s)
Liked: 477
I used to love the Labyrinth! Now, I'm afraid to watch it again for fear it will ruin my childhood. I mean, what's up with David Bowie's hair..... Oh wait, I remember. The 80's are when White Rain could print money!
The Plains Theater Has Begun
J_P_A is offline
post #136 of 144 Old 08-12-2012, 09:44 AM
erhurd's Avatar
Location: Buckeye, Arizona (Phoenix); USA; Planet Earth
Quoted: 62 Post(s)
Liked: 53
Great project documentation! Enjoyed viewing your project photos and captions.
Edwin R. Hurd
AVS Forums Lurker-In-Training!
My Tight-space A/V Setup
erhurd is online now
post #137 of 144 Old 06-21-2013, 09:41 AM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 413
When I first saw your theater pics, I thought you had Altec Lansing model 19s. Looks great!
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #138 of 144 Old 09-09-2013, 04:20 PM
wizzack's Avatar
Quoted: 104 Post(s)
Liked: 242
Beautiful. Building the PJ into the bar is a classy touch. Love the framed out posters too. This HT must look and sound amazing. Well done sir!
GoCaboNow likes this.
The above post is 100% medically accurate
31 Days of Horror: 2014 2013 2012 2011 2010 2009 2008
wizzack is offline
post #139 of 144 Old 09-19-2013, 08:40 PM - Thread Starter
GoCaboNow's Avatar
Quoted: 875 Post(s)
Liked: 765
GE84 likes this.
post #140 of 144 Old 09-20-2013, 03:45 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 961
Wow............we are close neighbors.........................
Would be interesting to hear your IB set up?
doublewing11 is offline
post #141 of 144 Old 09-27-2013, 05:33 PM
Quoted: 229 Post(s)
Liked: 961
post #142 of 144 Old 09-27-2013, 10:10 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 413
I like your fabric posters... Gives me a idea for in wall surround speakers with a fabric poster front...
ellisr63 is offline
post #143 of 144 Old 09-28-2013, 07:52 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 767
GoCaboNow - what a great looking home theatre!
I see you used what looks like these for your front mains, four pi kit, which look approx 24" tall judging on a 15" woofer.
With them sitting on your stage another 8" above floor, those horn tweeter then 30"-32" relative to ground floor level, did you angle them upward slightly to point at sitting ear level 1st/2nd row?
Or do those horn characteristics have wider up/down desperation?
mtbdudex is online now
post #144 of 144 Old 10-23-2013, 08:16 AM - Thread Starter
GoCaboNow's Avatar
Quoted: 875 Post(s)
Liked: 765
Eh, guess I am not subscribed to my own thread anymore?
MT, if you see this, yes they are 4pi design. Hard to tell from the pic but I have them angled up about an inch off the floor. Not sure if it really makes that much of a difference as I had them flat for a week or so and it wasn't a relevation. smile.gif
It's been a few years since I built them, IIRC, there is some dispersion benefit to the horn design and I'm sure it is easily found on Wayne Parnham's site or in the DIY thread. All three rows can see the horn, and they have a better penetration into the room than before when I ran basic MTM's. (Aperion 6C's for LCR)
GE84 likes this.
