Adidas4275's living room home theater 4 day build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 66 Old 08-11-2009, 10:54 PM - Thread Starter
Adidas4275's Avatar
Okay guys my wife and I recently bought our first home and being the [H]ard member that I am I needed to build my own home theater. Our home is a 1900 sqf 4 bed, 2 full bath with a 2 car garage. The living room, dining room and kitchen are all one open space, which is very applealing but really difficult for light control for a projector.
I did my "homework" for about 3 months and came up with my list of equipment, most of it had to be purchase since we came from a 600 sqf 1 bedroom appartment.
Equipment List:
Projector: Epson Home Cinema 720 from Visual Apex (free extra lamp from rebate)
Projector Mount: Visual Apex Universal Projector Mount AV-818U
Speakers: 5.1 (MIA is the sub, still needs to be purchased) All from "The Speaker Company" they had good reviews over at AVSfourm for the price.
Front L R and C are IW-D5 LCR pack $159
Rear 2 are IC-5 - Pair 5.25" $39.99 pair
AVR: Onkyo 605 bought for $200 off of AVS fourm
HTPC:
CPU: AMD X2 BE-2400 45w 2.3GHZ (Friday will be replaced with an X2 245)
Motherboard: Foxconn A7GM-S
RAM: 2GB DDR2 667 2 Sticks
HDD: WD Black 640gb
ODD: LG Blu-Ray reader
PSU: Antec Smartpower
GPU: ATI 4830 Silent (motherboard doesnt do 5.1/7.1 over HDMI)
WHS:
Case: Norco 4020
CPU: Intel Celeron E1400
Motherboard: Biostar G31-M7 TE (CPU and Motherboard were bought for $50 at a Frys)
HDD: 6 750gb WD7500AAKS on Highpoint RR 2300 Raid 5 with 1 as hotspare
2 750gb WD7500AAKS on motherboard as OS and storage pool drive
Drives run at 47*C with ambient at 30*C
4TB of Useable Space with RAID5 and a hotspare
PSU: Antec 650w Earthwatt
STB: Motorola STB HD comcast box (soon to be tapped into for recording via either FireSTB, ATI Cable Card (with hack) or PVR-HD)
All speaker wiring is CL2 in-wall rated 12ga wiring from monoprice, it took 200ft for my install.
HDMI cables are also monoprice: 2 6 ft and 1 25ft
All components are in the closet of the next bedroom, I will either build my own rack or buy a MA rack, depending on the $$ flow soon.....
And I have a logitech 890 RF remote that will be here on friday ( i was looking at the 900, but $400 vs $150 for basically the same function)
Here are some Pics:
ID:	456722   Click image for larger version
ID:	456730   Click image for larger version
ID:	456738   Click image for larger version
ID:	456746   Click image for larger version
ID:	456762   Click image for larger version
ID:	456770   Click image for larger version
ID:	456778   Click image for larger version
ID:	456786   Click image for larger version
ID:	456802   Click image for larger version
ID:	456810   Click image for larger version
ID:	456818   Click image for larger version
ID:	456826   Click image for larger version
ID:	456842   Click image for larger version
ID:	456850   Click image for larger version
ID:	456858   Click image for larger version
ID:	456866   Click image for larger version
ID:	456882   Click image for larger version
ID:	456890   Click image for larger version
ID:	456898   Click image for larger version
ID:	456906   Click image for larger version
ID:	456922   Click image for larger version
ID:	456930   Click image for larger version
ID:	456938   Click image for larger version
ID:	456946   Click image for larger version
Adidas4275 is offline
post #2 of 66 Old 08-12-2009, 12:13 AM
xCHRISx's Avatar
Nice job, very similar to what I'm going to try and accomplish in my basement. I have a giant hole in the wall from the previous owners 60" CRT HDTV so I'm going to put in a built-in shelving unit with an electric screen exactly like you guys did.
Looks good!
xCHRISx is offline
post #3 of 66 Old 08-12-2009, 07:36 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Looks like a proffesional install, very nice job. Awesome HTPC and WHS solution that has been the trend around here lately. At first I thoght that space looked small but you can see the size a little better with the ladder and you folks in front of it. Enjoy.
oman321 is offline
post #4 of 66 Old 08-12-2009, 07:43 AM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Dood...you don't plan to keep your Norco on the CARPET like that, do you?
CD
CDLehner is offline
post #5 of 66 Old 08-12-2009, 01:14 PM
Vcook's Avatar
Great job for the time frame, and I love how dual purpose the room still seems. However your reciever is going to cook your STB.
Vcook is offline
post #6 of 66 Old 08-12-2009, 07:21 PM
TheCableMan's Avatar
What kind off wood did you use?
Always Up for a Good Zombie Flick
TheCableMan is offline
post #7 of 66 Old 08-12-2009, 07:24 PM - Thread Starter
Adidas4275's Avatar
The Built in is 118"x80"
screen is a 100" Vmax2 Elite screen
CD
No i do not, I am hoping that I am able to build a temp wood rack for my stuff this weekend and then eventually buy a nice MA rack....
my closet is too small to mount the rack perpindicular to the space so I will be making some sort of custom rack.... I was dreaming of having a slide out rotating MA rack.... but that might just be dreaming...
Yeah my STB is hot! with that Onkyo 605, it is hotter than my WHS and my HTPC put together.... it will be taken care of by a temp wood rack with lots of fans
i bought stain grade 20" deep birch from Lowes.... it is glulam.
Then I primed all the wood, prior to building, and then painted with a semi-gloss white...... it's the paint we have on our baseboards in our home. We will be framing in all the windows in the house with the same trime that the media cabinet was trimed in and also installed crown molding over winter break.
post #8 of 66 Old 08-14-2009, 05:49 PM - Thread Starter
Adidas4275's Avatar
post #9 of 66 Old 08-20-2009, 11:09 AM
spivonious's Avatar
That looks really great! I like how the screen is completely hidden when raised.
What's behind the wall? Was the recessed space already there?
spivonious is offline
post #10 of 66 Old 08-20-2009, 11:20 AM
pocoloco's Avatar
Very nice work! Are you planning to eventually put a flat screen where the picture is? It's perfect made for that.
pocoloco is offline
post #11 of 66 Old 08-20-2009, 11:22 AM
Johnsteph10's Avatar
Quoted: 31 Post(s)
That is incredibly sharp and what a cool idea for a multi-use space.
During the day -- looks like built-in shelves with display pieces....at night...the dark side comes out and the screen comes down.
John
Johnsteph10 is offline
post #12 of 66 Old 08-20-2009, 12:44 PM
Smitty2k1's Avatar
Looks fantastic! Innovative and sharp!
Smitty2k1 is offline
post #13 of 66 Old 08-20-2009, 07:03 PM - Thread Starter
Adidas4275's Avatar
yeah the recess was there and the cabinet company that did the rest of the house wanted close to $6,000 to build something that was 10'x6' to fit in there. it cost us about $500 for the cabinet. (so far)
Yeah, when i designed it I used a 52" pioneer plasma as a reference. So it will fit a wall mounted 52" TV in there. There is already cat6, HDMI, RG6 and power to the area. right now its all behind plywood, but if we ever wanted to add a TV we could.
Right now we dont watch enough TV to justify it. The Epson 720 and Screen was only $1300 for both, so it was a "in stead of" purchase at this point.
Thank, it took me a while to draw out all the plans to make sure everything fit and looked how I wanted it to. Then it was just up to me actually build it.
honestly the WAF was so high on this project it was great. My wife loves that the TV is not the center of attention when people come over.... well until we want it to be.... then it is not just the center of attention but everone stops what they were doing to watch.
the first 5 mins of Fast and the Furrious 3 is great to watch in 5.1 on a 100" HD screen
post #14 of 66 Old 08-20-2009, 08:07 PM
rboster's Avatar
Quoted: 883 Post(s)
Liked: 741
Job well done. Really clean well incorporated build as a livingroom HT.
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is offline
post #15 of 66 Old 08-20-2009, 10:12 PM
kezug's Avatar
Very nice job! I love the clean look and it has the appearance of being done professionally. To bad, you could not hide the projector somehow for a totally clean install.
Question: why did you bother painting that cubby hole in the first place... ? I have to laugh, because I completely mudded and tapped my front wall when I was going to put up a permanent screen on it anyway...still scratching my head why I bothered to do that.
kezug is offline
post #16 of 66 Old 08-20-2009, 11:40 PM - Thread Starter
Adidas4275's Avatar
Thanks, comming from a mod that it cool
Thanks... as for the paint... my little sister needed something to do and we were not sure if we wanted a wood backing or the wall to show through. So we painted it, knowing that if we stuck with the wood backing your wouldnt see it anyways. Also we knew we wanted to paint the bullnose so there is clean paint line between the trim molding and the wall.
yeah it was extra paint but that is okay
post #17 of 66 Old 08-23-2009, 07:57 PM
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
landshark1 is offline
post #18 of 66 Old 08-23-2009, 11:25 PM - Thread Starter
Adidas4275's Avatar
Originally Posted by landshark1 View Post
really professional like job!! and great design too!!
it would be even better with a flat screen on the shelf!! really, the cool factor is well worth it!!
it is setup for a LCD, LED or plasma 52" on the shelf. So if day time viewing isnt up to par with it being a living room and not really light controlled then i will buy a TV
we just got blinds today so will will post some new pics tomorrow with a real camera of the image with the blind open and closed.
post #19 of 66 Old 08-24-2009, 07:08 AM
Bin.cue's Avatar
Congratulations on a well executed project. This is exactly the setup I'm looking to implement and it's nice to get some great ideas from your work. Good job!
Bin.cue is offline
post #20 of 66 Old 08-24-2009, 05:15 PM - Thread Starter
Adidas4275's Avatar
thanks, thats why i posted.... be sure to post pics of your build... i got a lot of my ideas from othre posts on here and hardforum
post #21 of 66 Old 08-25-2009, 11:52 AM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 236
Adidas,
Very nice - well done "multipurpose screen wall" - very clean !
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #22 of 66 Old 08-26-2009, 04:12 PM - Thread Starter
Adidas4275's Avatar
I am using a harmony 890 and everytime I switch from TV to HTPC it tells the screen to go down.... which it already is, so i think that over time will stress the motor and cause it to burn out..
I was thinking a 12v wire from the PJ to the screen would be better...
ah... back into the attic at 100*C outside
also I ordered a IR power switch for my HTPC so that I could actually turn the HTPC on and off and no sleep states...
http://www.simerec.com/
we will see how well it works, I am still trying to get my WAF higher..
post #23 of 66 Old 08-27-2009, 08:54 AM
Vcook's Avatar
Remove the "screen down" function from all your macros and make it a separate function soft button within each activity. Sure you'll have an extra button to push when starting things up initially but it's a simple fix for your problem.
Vcook is offline
post #24 of 66 Old 08-27-2009, 12:30 PM - Thread Starter
Adidas4275's Avatar
yeah, not waht i am looking for.... i am trying to prolong the longevity of my equipment and increase WAF.... that only increases longevity... it definately does not make it easier to operate...
I think I am going to run a 12v on swtich from the PJ to the Screen..... I got mono 1/4" jack extenders to extend the 890 IR blasters to the PJ so you dont have to point the remote at the PJ anymore.... i just need to get the energy to go up in the attic.... living in the Fresno,CA sucks for attic work
post #25 of 66 Old 08-27-2009, 12:47 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
That's strange really, the harmony should know the screen is down and that it need not send the command again. Something seems to be off in the settings.
What does it do when you go from HTPC to TV?
oman321 is offline
post #26 of 66 Old 08-27-2009, 01:17 PM - Thread Starter
Adidas4275's Avatar
it doesnt know, it send the signal again... I can hear the motor click on.
also even though my Epson PJ is on HDMI it changes the input to HDMI again.... it takes around 1.5 sec to get the signal again when switching....
I sent a tech request to logitech and they reconfigured my settings for the PJ.....
I had to manually add the screen command to the activies as well... should it automatically know to put the screen down or up?
post #27 of 66 Old 11-10-2009, 12:22 AM - Thread Starter
Adidas4275's Avatar
recently built a temp "rack" and added a tripplite UPS (not pictured)
and I just got a Dell Keyboard, Trackball, 15" LCD 1U console from ebay for $99 shipped that I will be installing soon
also added the IR switch i linked above and it works great... the harmony remote can now power on (from full off state) and off the HTPC and with that 640gb back drive its boot is fast enough to save the WAF.... a SSD would be better
here is my review on that IR switch
http://www.missingremote.com/index.p...=4113&Itemid=1
post #28 of 66 Old 11-10-2009, 07:31 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Hey Adidas, I never saw your reply to my post just above. Have you sorted out the Harmony issues with the screen?
You mentioned you had to manually add the screen to the activities? You should have made the screen a Generic Device add all its commands and then make the device part of the appropiate activities. The smart state should then know when that device is on (screen down) and leave it as such when switching to another activity using the same device.
If you've worked it out, never mind
oman321 is offline
post #29 of 66 Old 11-11-2009, 04:12 PM - Thread Starter
Adidas4275's Avatar
havent done anything with it yet. I will be climbing into the actic soon to run ir blasters to the screen and PJ so that the remote will work with RF for the 2 devices.... then i dont have to point it at the screen.
when i do I will redo the screen programming. I think i added it as an applicance since it showed up with the manufacturer and product under that category.
Ill post my results when i update it..... thanksgiving break probably...
thanks
post #30 of 66 Old 11-11-2009, 07:27 PM
ragged's Avatar
Wow, one of the best true "still a living room" installs I've seen.
ragged is offline
