Blog on soundproofing DIY project - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-19-2009, 08:58 AM - Thread Starter
darb66's Avatar
cheapsoundproofing.blogspot.com
I used this forum to help in my decisions and wanted to pay back a little. Here's a short blog on my project.
Hope someone finds it helpful!
darb66 is offline
post #2 of 7 Old 08-20-2009, 06:15 AM
jelloslug's Avatar
jelloslug is offline
post #3 of 7 Old 08-20-2009, 06:51 AM
Quoted: 3267 Post(s)
Liked: 2751
http://cheapsoundproofing.blogspot.com/
Interesting reading, couldn't help but laugh when you said you pushed it out with a stick.
post #4 of 7 Old 08-20-2009, 07:14 AM - Thread Starter
darb66's Avatar
Thanks guys!
darb66 is offline
post #5 of 7 Old 08-20-2009, 10:24 AM
Cathan's Avatar
In your blog you mentioned using GG around the seal of your door. I wouldn't. Just use caulk instead.
Cathan is offline
post #6 of 7 Old 08-20-2009, 11:16 AM
Riblet's Avatar
"Oh! I should also add that I didn't have a gun to squirt it out, I just used a stick to push in the back and that worked fine."
Just like BigMouth, I got a good laugh about that. You might think you will never need a caulk-gun, but they can come in real handy. A cheap one at the big box stores are only $3-5. Thanks for sharing the blog, and I am glad it works as well as you hoped!
Riblet is offline
post #7 of 7 Old 08-20-2009, 01:06 PM - Thread Starter
darb66's Avatar
Caulk it will be, thanks!
Glad you got a kick out of the stick comment. I just plain forgot to pick one up when I bought the drywall and was too impatient to go back.
darb66 is offline
