Village Theater Construction Thread - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #421 of 437 Old 11-12-2016, 10:54 AM
jimim's Avatar
Quoted: 496 Post(s)
Liked: 143
Thanks man. Good to know. Did u use a Bluetooth keyboard or USB keyboard to set it up? Same for mouse? I really think I'm going to copy you and go this route. I wanted to use his app but I'm all mac in my house and didn't want to invest in a windows machine. I never heard of these USB sticks. I'm going to go this route I think too. I have to still get a panel. I need something real slim too so I can build a frame around it too.
Thanks a lot man. Glad u got ur poop situation taken care of!
jimim is offline
post #422 of 437 Old 11-12-2016, 12:44 PM - Thread Starter
marklabelle870's Avatar
Quoted: 17 Post(s)
Liked: 32
I happened to have a Logitech mouse and keyboard that I had for the theater. I really liked that LG flat panel. I'm an all Penny at my house, but that LG was cheap and a good picture. Let me know if you have any questions.
marklabelle870 is offline
post #423 of 437 Old 11-12-2016, 05:41 PM
brian6751's Avatar
Quoted: 1142 Post(s)
Liked: 1123
Originally Posted by marklabelle870 View Post
I just checked out the Volt's - love the angled 6's. I think I'm going with just 2 of the 6's, but I'm not sure if I want to go angled ported or the atmos flat pack. Not sure where I would place them if I'm going with just the angled 2 with two rows of seating. I was thinking on the outside edges between the first and second row. Thoughts?
Hi Mark. Man, really sorry about the damage but that's great that it will be better than ever. If your only going to do two atmos speakers, I think I would use the angled enclosures so that the back row has a better chance of benefitting.
That's not science! - Cyborg
FOR SALE: nothing at the moment
Rivers Edge Theater
brian6751 is online now
post #424 of 437 Old 11-21-2016, 10:34 AM - Thread Starter
Quoted: 17 Post(s)
Liked: 32
Here's the lastest on the wainscoting. Going well, but still have lots of nails holes to fill and all of the inside picture moulding to complete. I really like to look of the bulkier cap and the smaller inside picture moulding. Nails holes, cleaning, sanding, stain, poly, sanding, poly, sanding, poly..... So much to do!
I also decided to put some vents in the top of the riser. I'm going with a broadband trap with 4x14 vents across the back and 2 on the sides. I hope this makes a difference in taming those DD15's a bit. Can't hurt I imagine....
brian6751 likes this.
post #425 of 437 Old 11-21-2016, 11:07 AM - Thread Starter
Quoted: 17 Post(s)
Liked: 32
Here's a video of the new MoviePoster app and the LG 43" LED panel.
LG Panel: https://www.walmart.com/ip/LG-43LH50...-HDTV/50314333 I got it on sale for $263
Intel Stick: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Runs Window 10
MoviePoster App: http://www.movieposterapp.com/
I'll also have this hooked up to Control4 using a zigbee to IR wireless modules and I've done some creative programming to make sure it comes on when you enter and then when you leave it turns off. It also mutes the trailers when you are watching a movie.
post #426 of 437 Old 11-21-2016, 11:18 AM
brian6751's Avatar
Liked: 1123
looking good! that poster app is pretty cool
Rivers Edge Theater
post #427 of 437 Old 11-22-2016, 08:41 AM - Thread Starter
Quoted: 17 Post(s)
Liked: 32
O.k major issue - now that I have the wainscoting nearly done and the top cap is on, for some reason I decided th dry fit some of the existing acoustic panels that I had in the room. MAJOR ISSUE!!!! They don't fit. I'm about 2 inches off and that is a result of me changing the top cap from what we originally planned. I totally fogot about this and now I'm in a real pickle, as I have about 14 custom panels that don't fit between the crown and the top of the wainscoting. I bought the panels from bpape at GIK and I'm not sure how I can now trim these down and not make them look awful. I love the rounded edges of the panels and I'm not sure I could ever reproduce the professional quality that GIK provided. ARGH! Any ideas anyone?
Picture of panel with new wainscoting and crown:
Panels installed prior to new wainscoting and crown:
post #428 of 437 Old 11-22-2016, 08:52 AM
brian6751's Avatar
Liked: 1123
What does the edge look like? I'm sure you can shorten them pretty easily.
Rivers Edge Theater
post #429 of 437 Old 11-22-2016, 09:03 AM - Thread Starter
Quoted: 17 Post(s)
Liked: 32
The GOM has spray adhesive to the OC703 and peeling it back won't be easy and the edges are all rounded. See picture below.
post #430 of 437 Old 11-22-2016, 10:21 AM
brian6751's Avatar
Liked: 1123
The edge is not a problem. The issue will be peeling the fabric back. If that can be done without damaging the fabric, it will be pretty simple. Peel it back. Run it across a table saw to size. Glue a new end on there. Glue the fabric back down. Trim excess. Done. The edge is just a round-over that can be replicated with a router.
Rivers Edge Theater
post #431 of 437 Old 11-22-2016, 02:42 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 32
Wainscoting Shots, lobby crown and MoviePoster App
Here are the latest shots from the completed wainscoting and crown in the lobby. Also some shots of the MoviePoster App. Love that thing!
post #432 of 437 Old 11-22-2016, 03:47 PM
brian6751's Avatar
Liked: 1123
Looks really nice. Seems like that app only works if your streaming the movies right? I don't have any movies ripped.
Rivers Edge Theater
post #433 of 437 Old 11-22-2016, 03:51 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 32
Nope, it will show the movies that you are showing in the theater if you are using XBMC, Kodi, etc., but I'm not using that feature. It's merely picking movies from IMDB and showing the poster with a link to the trailers. You can pick ANY movie you want though and add them to the rotation. I added Somewhere in Time (really old movie) for my wife and some ones for the kids. You can also create custom lists. It's quite amazing!
post #434 of 437 Old 11-22-2016, 03:59 PM
brian6751's Avatar
Liked: 1123
oh that's really cool. I'll check it out. I like using physical discs and have some stuff on iTunes so I'm not interested in Kodi or the like.
Rivers Edge Theater
post #435 of 437 Old 11-25-2016, 03:31 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 32
Updated pics after stain: General Finishes Mahogany gel stain. https://generalfinishes.com/retail-p...s#.WDjLTrU8KEc
post #436 of 437 Old 12-03-2016, 08:54 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 32
The latest pics with floor vents going in:
post #437 of 437 Old 12-09-2016, 11:57 PM
audiovideoholic's Avatar
Quoted: 654 Post(s)
Liked: 216
Wow! So sorry to hear about the backup! How did it happen so fast if you don't mind reliving it one more time? I own many property buildings for rental units so always like to know things like this as a water heater cost me $15k one time.
But you are most def back at it and doing better than before with HT1.5! Keep it up and keep us posted.
audiovideoholic is offline
