Microsoft Visio Home Theater Templates and Shapes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 09-24-2009, 01:01 PM - Thread Starter
jmuma's Avatar
Hello,
I have been looking for a while for templates or shapes to use in Microsoft Visio. This program provides you the ability to create excellent flow diagrams from networking, sales, webpage design, electrical, etc. However it lacks any built in support for home theater. I have just started to create my own set of shapes to use within Visio. You can download if you want. I will try and keep increasing the library as time permits.
http://www.bedlamcreations.com/upload/Home_Theater.zip
Josh
jmuma is offline
post #2 of 13 Old 09-25-2009, 11:16 AM
Ethan Winer's Avatar
Quoted: 267 Post(s)
Liked: 363
I was really looking forward to seeing your templates because I use and love Visio. Alas, my Visio 2002 Pro won't open the file. I'm probably not the only one using an older version. Is there an option for you to save in a Visio format that's backwards compatible?
--Ethan
Ethan Winer is offline
post #3 of 13 Old 09-25-2009, 05:41 PM
Speedskater's Avatar
Quoted: 36 Post(s)
I only have Visio 2000.
Kevin
Speedskater is offline
post #4 of 13 Old 09-25-2009, 09:09 PM - Thread Starter
jmuma's Avatar
I have been using Visio 2003. I checked and there is no option to save as an order version. However there are different file types, I will try and save a few different file types and reup the .zip file. If all else fails I will zip up the .png files so that you can import them into Visio and create your own template/stencil, it is not difficult once you have the graphic.
jmuma is offline
post #5 of 13 Old 09-27-2009, 11:26 AM
Quoted: 267 Post(s)
Liked: 363
post #6 of 13 Old 01-28-2010, 08:59 PM
Shan's Avatar
These are awesome! Wondered if you had any updates?
Shan
Shan is offline
post #7 of 13 Old 01-28-2010, 09:27 PM
Beemer533's Avatar
Just stumbled across this, nice job!
I use Visio at work a lot, but I find it is very useful for design work around the house as well....
Whiskey Tango Foxtrot, Over.....
Beemer533 is offline
post #8 of 13 Old 01-28-2010, 09:30 PM
dlinsley's Avatar
Quoted: 193 Post(s)
Liked: 116
I don't know about earlier versions, but I'm using the beta of 2010 and it has objects for projection screens, speakers and a projector under Office Equipment. I love being able to quickly build out a floorplan, add items then remove that layer to only show walls and electrical etc.
dlinsley is offline
post #9 of 13 Old 02-18-2010, 08:45 AM
BigGeek's Avatar
This was precisely what I've been looking for! Can't wait to see an update to possibly include XBox 360 and perhaps some set-top boxes. For now definitely works for my needs. Just modified some item descriptions to emulate other types of devices.
Thanks Josh for such a helpful shapes template!
BigGeek is offline
post #10 of 13 Old 02-20-2013, 01:54 PM
FrantzM's Avatar
Very, very late a great thanks to the OP !! A great gift to the enthusiast and maybe pro HT community.
Thanks again
Frantz
Frantz
FrantzM is offline
post #11 of 13 Old 10-03-2014, 08:11 AM
Liked: 0
I created an account especially to say "thank you". Brilliant work, came in very handy.
JohnDD is offline
post #12 of 13 Old 05-11-2015, 05:43 AM
Liked: 0
Thanks alot for your work! I appreciate it.
P.Albrecht is offline
post #13 of 13 Old 05-13-2015, 05:13 PM
NWCgrad's Avatar
Quoted: 1270 Post(s)
Liked: 1310
Hmmm I bought Visio through a work program (along with office). Have never actually used but looks like it could be useful.
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
