Spaceman Theater build - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 27Likes
post #811 of 1279 Old 12-04-2012, 07:53 PM
tbraden32's Avatar
If you can't find black ones tighten them in place then use a black sharpie. Should notice being on the ceiling and high up.
tbraden32 is offline
post #812 of 1279 Old 12-04-2012, 08:09 PM
Holiday121's Avatar
Quoted: 539 Post(s)
Liked: 147
Can't wait for you to mount that bad boy already
Holiday121 is offline
post #813 of 1279 Old 12-04-2012, 09:07 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Originally Posted by Spaceman View Post
Have you guys found black lag screws to use with your mounting hardware or did you paint them black? I need (4) 5/16" x 2-1/2" lag screws to secure the plate to the blocking in my ceiling. Ideally, I'd like to find screws already finished in black so I don't have to paint the heads. Painting is easy enough, but I think the paint would chip off as I ratchet them into the ceiling. Anyone know if black ones can easily be found at HD or Lowe's or should I start looking at some of the specialty fastener places online? I was also thinking of placing a flat washer between the screw head and plate, depending on the size of the hex head. If anyone has a good source for black lag screws, I'd appreciate it. It would save me from running all over town.
You'll be better off painting them IMO. And I recommend washers so you won't rip the powder coat on the ceiling splat.. Home depot carries SPAX which are better than normal lag screws. They will be easier to paint than a zinc coated lag anyway. If you found black it would be black steel or black oxide. Black steel will eventually rust. Paint with Home Depot's cheap black paint (goes on thin, grayish can), let dry, install, touch-up with artist brush or mask and respray. That paint has about the same luster as the chief parts.
GetGray is offline
post #814 of 1279 Old 12-04-2012, 09:27 PM - Thread Starter
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
Thanks for the tips, fellas. I'll check out the SPAX and touch up after install.
Spaceman is offline
post #815 of 1279 Old 12-04-2012, 09:28 PM - Thread Starter
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
Spaceman is offline
post #816 of 1279 Old 12-04-2012, 09:36 PM
Holiday121's Avatar
Quoted: 539 Post(s)
Liked: 147
Lol it's been a long journey I remember when we both were trying to figure out projectors and screens.
My room is not nearly as good as yours I want that damn celing.
post #817 of 1279 Old 12-04-2012, 10:01 PM - Thread Starter
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
Well, that damn ceiling is why I don't have a projector hanging in my room yet. We have this love-hate relationship going.
I just hope I don't have to wait too long for carpet. Getting anxious.
Spaceman is offline
post #818 of 1279 Old 12-04-2012, 10:06 PM
Holiday121's Avatar
Quoted: 539 Post(s)
Liked: 147
I would give a month delay to have that ceiling haha
post #819 of 1279 Old 12-05-2012, 08:23 AM - Thread Starter
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
I saw these rubber bushings used in KnoxVegas' thread. Is this something commonly used in most pj installs or more to address specific vibration problems.
Spaceman is offline
post #820 of 1279 Old 12-05-2012, 08:36 AM
Brad Horstkotte's Avatar
Liked: 68
Never seen that before
Brad Horstkotte is offline
post #821 of 1279 Old 12-05-2012, 08:40 AM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
As installed, they would not do anything but act as a washer. If installed as true isolation dampers they would only help typically with high frequency sound transmission, like might come from a motor, not the very low frequency vibrations a PJ mounted to a ceiling membrane might experience.
GetGray is offline
post #822 of 1279 Old 12-05-2012, 09:06 PM
erichoya's Avatar
Spaceman, your theater is coming along great. I signed up for this forum just to write this post after reading through this entire thread. Our house had about 50 X10 switches and keypads when we moved in. I have been migrating to insteon and been very happy. You will probably want to create scenes so you can press a single keypad button and have the lights adjust accordingly. These may include all on, all off, movie, etc. I don't recall how many switches you want to hide but may want a specific keypad button for each. If 8 buttons is not enough, then maybe you will need two keypads. I use Houselinc to set up scenes, very easy, and a smartlinc so I can control lights with the iPhone app. I probably should have gone with the isy controller. Check out the smarthome.com/forum for help if needed.
I have been playing with xbmc for a month and tried mayhem. I was able to use my mce remote to send commands to my htpc to be able to control insteon lights. Very crude and no scene control, but at least I can dim and brighten the lights from the remote. I am considering trying the insteon ir linc, but revies are to good.
I just received a bunch of lag bolt covers today which I ordered to cover the bolts for mHy epson 5010 that I installed 5 days ago in our movie room. Unfortunately they sent me someone else's order, so they are black instead of white. Got them from here.
http://www.pro-dec.com/hex-caps-bolt-covers-bolt-caps
I'll keep reading and enjoying and unfortunately getting inspired to gut our movie room.
E
Epson 5010 with 110" Accuscreen. Yamaha rx-v773, HTPC with XBMC.
erichoya is offline
post #823 of 1279 Old 12-05-2012, 09:44 PM - Thread Starter
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
Thanks for stopping by, Eric. I hope to have the Insteon switches installed in the next few weeks. Those hex caps are pretty cool. For some reason, they don't have ones for 5/16" hex heads. I painted mine today and will see what they look like once installed.
Welcome to the forum. You'll find lots of inspirational builds on here.
Spaceman is offline
post #824 of 1279 Old 12-05-2012, 10:17 PM
Moggie's Avatar
Quoted: 23 Post(s)
Liked: 33
Spaceman, just viewed the pics of you ceiling. I love the lights out picture with the coffers separating the panels. Very very nice job!
My "Old Vic" Theater Build | Screen Build | HT of the Month | Contest Win
My 8 year old daughter: "are contractors the people that mess up your house for money?"
Moggie is offline
post #825 of 1279 Old 12-06-2012, 08:25 AM - Thread Starter
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
Thanks, Moggie.
Hope your theater is staying nice and dry with all the rain you guys have been getting. My parents still live in the Bay Area and they had some standing water in their garage. Not too bad.
Spaceman is offline
post #826 of 1279 Old 12-06-2012, 08:32 AM
stockmonkey2000's Avatar
The ceiling is looking great. Looks like you'll be done in no time.
stockmonkey2000 is offline
post #827 of 1279 Old 12-06-2012, 09:11 AM
andymo's Avatar
Wow - I love love your ceiling.
Even the wife wanted to do star ceiling, but time and money ... time and money ... (especially the time!!)
Real nice.
andymo is offline
post #828 of 1279 Old 12-06-2012, 09:28 AM - Thread Starter
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
I'm getting there, but my to-do list is fairly long with lots of little items. As with most projects, it's the last 10% that's a killer. That's when you need to button up all the little details.
Real nice.
The stars in my room took more money than time, but compared to a fiber optic ceiling, it didn't take a whole lot of money either. Jeff painted my entire ceiling in 5 hours. My only time investment was building the light trays to hold the black lights. If you planned it right, you could have Jeff in and out while your wife was at work and surprise her with a star ceiling when she got home.
My wife has been excited about the project from the beginning, but she really got on board when stars became part of the project. We had originally planned on doing fiber optics, and as the budget was put together, that part of the project kind of fell off the table. I could tell she was disappointed, so fortunately we were able to make it work by going with a mural. As a bonus, we both like it more than the fiber optic ceilings we've seen.
Figuring out how to incorporate the black lights is the hardest part. Once you do that, you can really add a painted mural at any time.
Spaceman is offline
post #829 of 1279 Old 12-06-2012, 05:46 PM
Moggie's Avatar
Quoted: 23 Post(s)
Liked: 33
Thanks, Moggie.
Dry as a bone. Thankfully!
Moggie is offline
post #830 of 1279 Old 12-07-2012, 09:34 PM - Thread Starter
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
So Jeff just finished his sky mural marathon of Texas and Oklahoma, starting and finishing in Houston. On his way back through town, he contacted me to make sure I was still happy with the work he had done last week. I told him everything still looked great. My only comment was that if we could do it again, I'd like the Milky Way to stand out a little more, but that it wasn't a big deal because the ceiling really looked awesome. He immediately offered to swing by that night and get it just how I wanted, even though it was 9:30 at night and he had just driven 4 hours from Dallas.
I know everyone here is pretty familiar with his work and I don't really need to sing his praises, but when it's well deserved I have no problem letting other people know. Thanks again, Jeff.
Spaceman is offline
post #831 of 1279 Old 12-08-2012, 08:44 AM
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
landshark1 is offline
post #832 of 1279 Old 12-08-2012, 09:02 AM
mn_hokie's Avatar
Liked: 27
mn_hokie is offline
post #833 of 1279 Old 12-08-2012, 09:04 AM
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
post #834 of 1279 Old 12-12-2012, 09:29 AM - Thread Starter
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
If you don't like carpet pics, you came to the wrong post. wink.gif My photography skills are pretty poor, so the color seems to change from one photo to the next, but you'll just have to trust me when I say "It looks better in person". The patterned carpet is the same one Mario used in the Cinemar Theater (Masland Quadrate Times Square #18404). The stage is Masland Signet Black #287. It took 3 guys 4 hours to install. (Please ignore the temporary OSB threshold at the entry door. That is just a place holder until I find a better solution).
I also supplied them with a piece of our original carpet, which they installed in the new media closet.
The fabric on the back wall is fire-rated Rose Brand "Black Speaker Cloth". It sits on top of the acoustic treatments but behind the fabric panels to keep the shiny facing of the acoustic treatments from showing through the outer fabric. You'll also see the vents along the back wall as a half-hearted attempt to get the riser to act as a bass trap. No professional input on their size or placement. I just put one in every joist bay. Before placing the register over the carpet, I put a scrap of the Rose Brand speaker cloth inside each hole to lay on top of the pink fiberglass. Keeps the fibers inside the riser and looks cleaner.
I also just ordered one of these for my wife to put under the tree (URC R40).
Spaceman is offline
post #835 of 1279 Old 12-12-2012, 09:44 AM
Mr.Tim's Avatar
Quoted: 277 Post(s)
Liked: 180
Nice job!
You mean, you bought it for her to put under the tree.. with your name on it? biggrin.gif
Mr.Tim is offline
post #836 of 1279 Old 12-12-2012, 09:51 AM
design1stcode2nd's Avatar
Quoted: 31 Post(s)
Liked: 44
Looking sharp, seems the cat likes it as well.
Play like a Raven
design1stcode2nd is offline
post #837 of 1279 Old 12-12-2012, 09:52 AM
vanice's Avatar
Quoted: 32 Post(s)
Liked: 53
Looks really good Spaceman! From the pictures it appears like they did a really good job with the install. I hope my install this Friday goes as well. Any words of advice, things I should look out for, while they are installing?
vanice is offline
post #838 of 1279 Old 12-12-2012, 09:59 AM - Thread Starter
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
Exactly! And since she has been so understanding during the build, she deserves something really special. I think she would love one of these. I mean, what woman wouldn't?
Spaceman is offline
post #839 of 1279 Old 12-12-2012, 10:04 AM
TMcG's Avatar
Quoted: 1072 Post(s)
Liked: 870
I hear your wife wants a new subwoofer and an ISCO III anamorphic lens for Christmas as well! biggrin.gif
The room looks great! I am sure this has lifted your spirits a bit that the project is starting to truly come to a close.
Has your projector box been talking to you? biggrin.gif:D
TMcG is offline
post #840 of 1279 Old 12-12-2012, 10:16 AM - Thread Starter
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
I included that for aaustin, although I guess I should really move it to the pet pic thread.smile.gif
1. Give them some kind of threshold to work against at the door, even if it's temporary.
2. Can't remember if you have baseboards up, but if you do, expect them to get thrashed. I expected this, and have quite a bit of touch up to do.
3. They weren't as careful about staple placement on the face of each riser on the stage. They put a row along the floor and instead of putting a row just under the lip, they kind of just threw some in half way up the face of the riser. I'll probably be the only one that sees them, but it's something you might want to look for/discuss beforehand.
4. Check carefully around the base of your columns or any other areas that require cutting. Mine look great except for one spot that was miscut. They had to put a small scrap in the gap. I didn't notice it during my initial inspection, but found it later. It's too small to worry about but you should definitely check areas like that in case your guys do something similar.
5. Once I checked their rolls to make sure I was getting what I paid for and made sure they understood where everything needed to go, I pretty much left them alone. My invoice made it very clear where everything needed to go, so I figured if they screwed it up, they would have to fix it.
I'm very happy with how it came out. Hope yours goes as well. I know you must be excited. It's almost as big a step as completing drywall (as far as transforming the room).
Spaceman is offline
Speaker Systems , Displays
