Spaceman Theater build - Page 42 - AVS | Home Theater Discussions And Reviews
Old 04-30-2014, 03:25 PM
ellisr63's Avatar
Quoted: 324 Post(s)
Liked: 279
Originally Posted by Spaceman View Post
I'm happy with my Insteon setup. It's the only brand I've used for automation, so I can't really comment on other systems. I would still do it the same way, but would probably add the Insteon Hub so I could also control them from a tablet. It's not necessary because I do have control via my universal remote, but it's pretty cool (and relatively cheap).
I am also happy with Insteon... We have replaced almost every switch in our house now with Insteon, and we use the ISY994i for programming in addition to CQC Software. It is nice having 2 ways to control everything.
Denon 4520ci, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, (3) MiniDSP 2x4s, (4) Klipsch HIPs,  PS3, XBox 360, (3) Intel NUCs, Redmere, Monster HTPS7000, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diagonal) scope screen, Darbee Darcet, Yamaha P7000s, (2) Yamaha P2500s, & (3) Topping 25wpch T chip amps.
The Ellis Family Go Big or go Home HT
ellisr63 is online now
Old 05-01-2014, 05:57 AM
joeybutts's Avatar
Space, I have been using your entire thread as a guide and must say it has been an excellent tutorial. Thanks for all the time and effort to post it all.
Quick question since you guys are on the topic of the Insteon. I'm reading the install instructions and trying to prepare for next month when I purchase it and comparing to your pics. Is the wiring as easy as one wire from the keypad to one switch and then a jumper to each or am I missing something? I don't see four additional runs coming out of the keypad to each switch so just want to make sure I am not crazy. smile.gif
Thanks for any help and glad to hear that you are really enjoying the fruits of your labor!
joeybutts is offline
Old 05-01-2014, 07:23 AM
vanice's Avatar
Quoted: 27 Post(s)
Liked: 51
The keypad does not have a physical connection to the switches you control other than maybe if you are jumpering the power from switch to switch. It is wireless control. The keypad and each Insteon switch could be on different circuits and you would still have control once the switches are linked to the keypad.
vanice is offline
Old 05-01-2014, 07:27 AM
joeybutts's Avatar
:face palm: thanks vanice. tongue.gif
Old 06-25-2014, 08:49 AM
kmhvball's Avatar
Quoted: 174 Post(s)
Liked: 63
The front wall looked a little naked with linacoustic but no speakers, so I made that my priority this weekend. I have very little room behind my AT screen, so I'm using in-wall speakers (Atlantic Technology IWCB-727 THX Select closed box). Rather than cut a hole in the drywall and recess the speakers 2" into the linacoustic, I built 3 simple speaker boxes that attached directly to the drywall.
Hi Spaceman, this is one of your many good ideas I am planning to use in my theater. Question on the L& R front speakers... Did you consider at all 'toeing' them in? I have seen posts about one downside of in-wall speakers is they 'face straight forward'.
My thought was if I made the left side of the left speaker with say a 2x4 & a 1/2" plywood strip attached between it & the wall, and the right side with just a 2x4, then this would 'angle' the speaker in towards the center a little bit. (doing effectively the same with the right)
Just curious if you had thought about that and discarded it, didn't think it was needed, etc. My theater may be a little wider, with my L&R speakers being 10-11' apart, so that might be a slight difference.
Kevin
kmhvball is online now
Old 06-25-2014, 09:38 AM - Thread Starter
Spaceman's Avatar
Quoted: 28 Post(s)
Liked: 113
Hey Kevin-I did consider toeing them in, but wasn't really sure how much of an adjustment would be necessary so I decided to keep it simple. Like you, I thought about making the "outside" edge a little deeper. I also thought about constructing the "box" so it "floated" free of the wall and pivoted on a central dowel, but it seemed like more trouble than it was worth, at least for my narrow room.
Spaceman is offline
Old 07-30-2014, 05:19 PM - Thread Starter
Spaceman's Avatar
Quoted: 28 Post(s)
Liked: 113
If anyone in the Houston area is looking for duct liner for their acoustic panels or front wall treatment (Linacoustic or similar), I'm selling the last 32' left from my build. I have it listed in the AVS classifieds.
sathyakamaraj likes this.
Spaceman is offline
Old 09-19-2014, 05:53 PM - Thread Starter
Spaceman's Avatar
Quoted: 28 Post(s)
Liked: 113
Due to other obligations, I don't get on AVS as often as I used to. I did want to stop in and give a quick shout out to Monoprice, though. I know they are already highly regarded around here, but I wanted to share an experience I had with them today.
Earlier in the week, I wasn't able to get a video signal to the projector. Just a blue flashing screen regardless of the video source. Thoughts of fried ports on the receiver or pj caused some worry, as did thoughts of a family member mistakenly changing some buried setting that would take 3 days to find. Fortunately, after some troubleshooting, I determined it was just a bad HDMI cable. I had been using a 40' UltraSlim Redmere HDMI cable from Monoprice since December of 2012. I called them to see if there were other reported problems with this cable and they said no, but quickly offered to send me a replacement. Hope to be back up and running soon.
avtexan and 24Changer like this.
Spaceman is offline
Old 09-21-2014, 02:57 AM
Larry M's Avatar
Quoted: 28 Post(s)
Liked: 44
I better not have any issues with my Redmere cables, they're buried in walls and can't get out
Larry M is offline
Old 09-22-2014, 10:23 AM
GPowers's Avatar
Quoted: 27 Post(s)
Liked: 32
Conduit is your best friend.
GPowers is offline
Old 09-22-2014, 10:42 AM
kmhvball's Avatar
Quoted: 174 Post(s)
Liked: 63
Despite reading several places... "make sure to run Conduit"... in my rush to get stuff ready for the Drywall guy coming, I missed out on this step. I have two Redmere cables and 4 Cat-6 cables running to my projector.. I hope not to regret this for several years at least!! My set up is such that although not ideal, I could probably figure out a relatively low pain way to run a new wire. My fall back plan, is to consider some sort of sound treatment on the ceiling, and running wire under that sound treatment...
Reading this post though, certainly is making me second guess my small time savings :-(
Old 09-22-2014, 12:10 PM
ellisr63's Avatar
Quoted: 324 Post(s)
Liked: 279
We ran as much as we could in our soffits.
Old 09-22-2014, 01:24 PM
Larry M's Avatar
Quoted: 28 Post(s)
Liked: 44
I have conduit running all around my theater to equipment room. However, this is a direct shot to the projector so I only needed 25'. If I travel the path of the conduit, I'll likely need 40+ feet.
Not a horrible scenario, but Redmere cables are expensive and I really don't want to push the limits of a cable. As a backup, I do have another Redmere cable run parallel as well as a pair of CAT6 cables.
Larry M is offline
Old 09-22-2014, 02:51 PM - Thread Starter
Spaceman's Avatar
Quoted: 28 Post(s)
Liked: 113
Many folks suggest installing empty conduit for future needs and running your initial cables in the wall or ceiling. I never really bought into this school of thought. I figured if I have conduit, why not use it. If a cable goes bad, simply pull it out and put in another. Since Monoprice requires that you send back the damaged cable before they send out a replacement, I would have been out of luck had I opted to leave the conduit empty and installed the original cable in the wall. Something to think about when deciding whether or not to leave your conduit empty. I also found it easier to schedule things like drywall without having to worry about whether I had all the correct cables ordered and installed. As long as the conduit was in, I knew I could pull what I needed to at a later date.
ellisr63 and BllDo like this.
Spaceman is offline
Old 09-29-2014, 05:31 AM
iamjason's Avatar
Quoted: 22 Post(s)
i agree that some sort of tube to run the cables is the way to go - not even thinking about failure but, which is a concern as space pointed out, but what about for upgrades? my last house had an ht when i moved in using component cables that ran into the attic - when it was time to upgrade to a hdmi pj i had to crawl around it the fl heat to swap them - not fun and glad i will not have to do that again -
as for the cost of the red cables they are actually quite inexpensive - space recommended this to me and saved me about $50 over the Blue Jean one was was looking at - to make the run i needed across the room and have a good gauge for the heat -
iamjason is offline
Old 11-26-2014, 08:21 AM - Thread Starter
Spaceman's Avatar
Quoted: 28 Post(s)
Liked: 113
I'm trying to help someone find a specific post in my build thread and tried using the links I created on the first page of my thread. I know they used to work, but they now seem to bring me to random pages within my thread. For example, the link to my riser construction used to bring me to post 152 on page 6. It now dumps me on the top of page 16. Could someone try one of the links from my build timeline & index (halfway down the first post of my thread) and tell me if it brings you to the right post? I'd like to know if it is something AVS might have changed that caused the broken links or if it's something on my end. If you used links to other posts in your thread, do they still work? Thanks.
Spaceman is offline
Old 11-26-2014, 08:54 AM
24Changer's Avatar
Quoted: 78 Post(s)
Liked: 88
your False Wall link brings me to post 1201
tried 3 more, they all bring me to post 1201
Creekside Stone Cinema
24Changer is offline
Old 11-26-2014, 09:08 AM - Thread Starter
Spaceman's Avatar
Quoted: 28 Post(s)
Liked: 113
Well, that's not good. Can I ask what browser you are using? I'm going to have to follow up with AVS cust. support to see what is going on.
FYI-Your build is looking great. I just went through it earlier today. Lots of progress since I last checked in.
Spaceman is offline
Old 11-26-2014, 09:11 AM
24Changer's Avatar
Quoted: 78 Post(s)
Liked: 88
Using IE 11.0
Old 11-26-2014, 10:09 AM
jautor's Avatar
Quoted: 532 Post(s)
Liked: 477
Using Chrome here, and if I click on the links in your first post many of them redirect to the same post page (post 1231), but if I right-click "open in new tab", some of the links seemed to work correctly, but now I'm not sure...
The links in my build thread are working - I don't remember if I re-did those when the site software changed or not. But it appears there's something going on with the site-side redirection. I do notice that your links have a very different URL format than mine do...
Jeff
jautor is online now
Old 11-26-2014, 10:24 AM - Thread Starter
Spaceman's Avatar
Quoted: 28 Post(s)
Liked: 113
I did get some feedback from an admin who suggested a reformat the links. I don't recall exactly how I created them the first time but apparently, they no longer work under the new site software. Not really excited to redo 40 links. but I'll see if I can get to it this weekend. Thanks for checking.
Spaceman is offline
Old 11-26-2014, 10:31 AM
kmhvball's Avatar
Quoted: 174 Post(s)
Liked: 63
I tried a week ago or so, and links had same issue... fortunately, you have dates listed, so was still fairly easy to find what I needed! I know the Cinemar thread links are broken for me too.
Old 11-26-2014, 10:46 AM
rms8's Avatar
Quoted: 201 Post(s)
Liked: 117
Same with FF v33....
*DIY ConcreteBunker Rustic Dream Build w/11' screen, 11.2chnl, 8x18" IB subs, 28.8KW*
GR Research LS-9 + LS-C | Denon AVR-4520 11.2 | Sony VPL-HW55ES | DaLite 11' screen | Sanway FP-14000 & FP-10000Q | Sherbourn PA 7-350 | Behringer iNuke NU1000DSP | 8x IB318's | Buttkicker Original(2x), LFE(2x), MiniLFE(8x) | MinDSP 2x4 | 21'W x 27'L x 10'H | MiniSplit
Supercharged 10 second II
rms8 is offline
Old 11-29-2014, 11:45 AM
granroth's Avatar
Quoted: 470 Post(s)
Liked: 264
Fixing them via editing is actually pretty straightforward. Say you have a link like so:
Code:
[ URL="http://www.avsforum.com/t/1202525/spaceman-theater-build/780#post_22647668"]star ceiling[/URL]
Change it to this:
Code:
[ POST="22647668"]star ceiling[/POST]
(Obviously with no space -- that's so it doesn't auto-format. The key is the post id, since that's the one element that hasn't changed between Huddler and VBulletin.
The way I do it manually (when not editing) is to just open the link in the browser and let VBulletin reformat most of it. In my case, that original link looks like this after I let Chrome open it:
Code:
http://www.avsforum.com/forum/19-dedicated-theater-design-construction/1202525-spaceman-theater-build-13.html#post_22647668
It changes the base URL up until the anchor. The anchor is very slightly wrong, though. Remove the underscore from it and it works. That is, change "post_22647668" to "post22647668". and click the Refresh Page button. After that, AVS will do another refresh or two and finally come to the correct post:
Code:
http://www.avsforum.com/forum/19-dedicated-theater-design-construction/1202525-spaceman-theater-build-8.html#post22647668
The manual work isn't as labor intensive as it sounds. It's just three quick steps: 1. Right-click to open in new tab 2. Erase underscore 3. Hit Return/Enter 4. Click Refresh
But yeah, if you're editing the page, then using the [POST] command is the way to go.
Addition: I'd be remiss if I didn't mention at least two other ways of translating the the post id to a new URL. Two other URLs follow this format:
Code:
http://www.avsforum.com/forum/showthread.php?p=POSTID
and
Code:
http://.../1202525-spaceman-theater-build-postPOSTID.html
The same above example would translate to these two URLs:
Code:
http://www.avsforum.com/forum/showthread.php?p=22647668
http://www.avsforum.com/forum/19-dedicated-theater-design-construction/1202525-spaceman-theater-build-post22647668.html
Addition 2: Completely forgot about the earliest variation that I found, back when the switchover first happened:
Code:
http://www.avsforum.com/forum/post/POSTID
The above example translates to:
Code:
http://www.avsforum.com/forum/post/22647668
Spaceman and K2sno311 like this.
granroth is online now
Old 11-29-2014, 11:59 AM
granroth's Avatar
Quoted: 470 Post(s)
Liked: 264
Oh, and just to note -- I discovered a couple of those URL manipulation methods very specifically because of your build thread! It's one of my three most top referenced threads and the fact that the links didn't resolve were killing me. So I did a bunch of research and experimentation and found a way to get the the pages I needed.
K2sno311 likes this.
Old 11-30-2014, 07:05 PM - Thread Starter
Spaceman's Avatar
Quoted: 28 Post(s)
Liked: 113
Thanks for taking the time to figure out how to fix the broken links. I think I have them all working again. If someone finds one that isn't working, let me know and I'll get it fixed.
Spaceman is offline
Old 03-22-2015, 09:11 AM - Thread Starter
Spaceman's Avatar
Quoted: 28 Post(s)
Liked: 113
Spaceman is offline
Old 03-22-2015, 09:20 AM
Mr.Tim's Avatar
Quoted: 134 Post(s)
Liked: 106
Talking
Testing upgrades today.
hahaha you win the internet for today. Guess I'll have to scroll back a few pages to see what you're pushing
Tim
Mr.Tim is online now
Old 03-22-2015, 09:33 AM - Thread Starter
Spaceman's Avatar
Quoted: 28 Post(s)
Liked: 113
I can't take credit for dancing SpongeBob. I just came across the video this morning and thought everyone here would enjoy it.
Spaceman is offline
Old 03-22-2015, 09:35 AM
Mr.Tim's Avatar
Quoted: 134 Post(s)
Liked: 106
I wasn't gonna say anything about the questionable fit and finish in your nice room
Tim
Speaker Systems , Displays
