What is the best microfiber dust wiping cloth for Home Theater equipments? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 12-17-2009, 12:54 AM - Thread Starter
Furious Knight's Avatar
To wipe off dust from receiver, TV stand, subwoofer, speakers, game consoles, dvd player etc...
Furious Knight is offline
post #2 of 16 Old 12-17-2009, 04:08 AM
Cathan's Avatar
Any of them?
Cathan is offline
post #3 of 16 Old 12-17-2009, 05:36 AM
dhewie's Avatar
Go to a source with car waxing microfibers such as Autogeek.com. They have really soft ones that will not scratch the surfaces. If you don't care about microscratches, just buy something at Walmart.
dhewie is offline
post #4 of 16 Old 12-17-2009, 06:28 AM
ziptiecowboy's Avatar
I use a Swiffer Duster for all my electronic equipment. You can get 'em anywhere...Walmart etc.
ziptiecowboy is offline
post #5 of 16 Old 12-17-2009, 07:08 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
I use the Pledge the dust wipes, I've used them to wipe down my RP LCD, and bedroom flat panel for a number of years now and an issue. If I am wiping the screen I start there though so I don't pick nothing up along the way beforehand.
oman321 is offline
post #6 of 16 Old 12-17-2009, 07:48 AM
mike2060's Avatar
Love my Photodon microfibre cloths!
http://www.photodon.com/
mike2060 is offline
post #7 of 16 Old 12-17-2009, 01:52 PM - Thread Starter
Yes I want to prevent microscratches, lint and streaks. So could you give me the link to these soft car waxing microfibers, please? I am really interested, but I can't find them on the site.
These ones? http://www.pledge.com/grab-it/
post #8 of 16 Old 12-17-2009, 02:47 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
The dry ones of course, but yes those or they have some orange scented ones the Mrs. likes to buy which have always been fine as well.
oman321 is offline
post #9 of 16 Old 12-17-2009, 03:33 PM
thebland's Avatar
Quoted: 1493 Post(s)
Liked: 846
I use Microfibers from Murray's / O'Reilly's Auto Stores. $2.99. If it is good enough for my prized Porsche Carrera 4S paint, it would do good for your HT Equipment. Good idea. I have 20-30 of them. I'll have to grab one for my theater room!
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
post #10 of 16 Old 12-17-2009, 04:36 PM - Thread Starter
Are the Cobra brand towel/Cloths good? I am asking because I see that they are made in China/Korea...
post #11 of 16 Old 12-17-2009, 05:07 PM
dhewie's Avatar
I sent you a link: www.danase.com. They have great towels.
I actually had the other one wrong. It's www.autogeek.net. They have good ones too. But I have them from the other site for my cars and they are great.
The test for quality microfiber is to take it and wipe a CD with it while dry.
dhewie is offline
post #12 of 16 Old 12-17-2009, 05:37 PM - Thread Starter
Thanks! Which one should I get though? There is the Danase Phat Towel, the Danase Buff Microfiber Towel and the Danase Extreme Plush Towel.
post #13 of 16 Old 12-17-2009, 07:03 PM
dhewie's Avatar
Since they are so close in price, really any of them would be good. The Phat has long fibers, the Buff is short, and the Extreme has long on one side and short on the other. Long fibers are best for wiping away dirt without scratching, so if you are using it on dusty surfaces, the Phat would probably be a good choice. Or the Extreme so you have both.
dhewie is offline
post #14 of 16 Old 12-17-2009, 07:51 PM - Thread Starter
Thanks, I'll get the Phat. One last question though, since you seem to know these fairly well, I wondering if they suffer from the same problem that plagues the Cobra Shamrock microfibers towels as seen here:
Originally Posted by unclestu View Post
When I placed a very large order ($1500.00) this summer among the things that I ordered were the Shamrock m/f towels. I have not had the pleasure of using them until recently and found them to shed. No problem, I thought , they just need to be washed to knock out any loose fibers. Well after three or four washings with the microfiber rejuvenating detergent I find that they are still shedding & dusting. I am using FK425 as a QD specifically for its dust repelling quality and I have been very satisfied with it. When ever I have the dis-pleasure using these shamrock m/f towels to QD my beautiful black Porsche it looks as if it has been visited by a leprechaun. These shamrocks leave a trail of green dust all over the car.
Is there anyone else having similar problems with their shamrocks or am I the only one not feeling the LUCK OF THE IRISH
Originally Posted by 02blackout View Post
I AGREE!
When I got my shamrocks from the BOGO, I loved them when they came out of the box. But after a wash with the MF cleaning detergent, they lead HUNDREDS of little green hairs on the paint wherever you wipe.Trust us, we love our black cars. We can see every tiny spec of dust or SHAMROCK HAIR that gets on the paint. Only solution that somewhat worked was QD with another quality MF wherever the shamrock hairs are. Overall, I like the shamrock but its a P-I-T-A!
Since both the Cobra Shamrock and the Danase Phat use the same design of long fluff fibers, did you face similar problem with the Danase Phat Towel?
post #15 of 16 Old 12-17-2009, 08:08 PM
Leesrt's Avatar
First, there's way to much thought going into this question. Lol
I use a small California mop. The larger ones are used on cars. They have the long handles with red colored mop strands that are treated with a polish that attracts dust.
You want to use a new one for a while to wear off the polish residue. Otherwise the first few times you use it you'll leave some polish streaks behind.
They last forever and every now and then you just bang it out outside.
Leesrt is offline
post #16 of 16 Old 12-18-2009, 05:43 AM
dhewie's Avatar
I haven't had any problem with shedding/linting on quality microfibers like these. Maybe a couple stray fibers the first time you use it, but that's it. Maybe the Cobras mentioned were a knock off.
dhewie is offline
