The Cinemar Home Theater Construction Thread - Page 100 - AVS Forum | Home Theater Discussions And Reviews
 61Likes
Old 03-12-2014, 08:02 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
Originally Posted by FortKnUX View Post
I am trying to find the grill fabric for the columns but I don't think they make FR703 any longer, they are all sound absorbing panel fabrics (including FR701) and FR703 is no longer in the list:
http://www.fabricmatestore.com/c-203-guilford-of-maine.aspx
Anyone has any other leads where one can get the FR703 equivalent fabric?
FR703? i think he used this http://www.fabricmatestore.com/p-407-fr701-black.aspx it is used allot for false walls and is acoustically transparent , i know i have and others have used it in our columns.
snickers1 is offline
Old 03-12-2014, 08:42 AM
FortKnUX's Avatar
Thanks snickers1, I saw that fabric but my impression was 701 series is more into sound absorbancy rather than transparency, but I guess I am mistaken.  Mario does have on his first post FR703 listed for speaker frames' fabric, is that a typo?
FABRIC
* Red Walls - FR701 GOM Claret Accent
* Speaker Frames - FR703 GOM Black Fabric
FortKnUX is offline
Old 03-12-2014, 08:48 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
FABRIC
Sorry about that. I corrected the typo on the first page of this thread.
snickers1 likes this.
mcascio is offline
Old 03-13-2014, 04:57 PM
FortKnUX's Avatar
Mario, did you buy the denim online?  If so, do you happen to have the link by any chance?  I am too having less than an inch clearance for the fabric depth and all I can find is over 1" of thickness.
Also, have you ever found an optimal positioning for your subs?  I heard people try to put them back to back centered behind the screen shooting to the sides, that supposedly equally fills the room with the sound given you installed the traps on all 4 corners.
thanks!
FortKnUX is offline
Old 03-14-2014, 07:34 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
thanks!
I bought the recycled denim through http://www.vyron.com/ (Brookfield, Wi Branch) - ask for Tim Barham.
It's their Ecosheild Titus product I believe.
Although, I would check a local Menards. I thought they started carrying a similar product.
Note, the specs on the denim says that it is 1", but in fact in my case, it was actually 3/4".
Every room will perform different with the subs and their locations, but there are some recommendations posted on the web. In my case, I have them all up front. I have yet to officially test turning them in or rotating them to see how that affects the room. It would probably be a good test. The HSU is a real bear though to move in and out so I haven't worked up the energy to move it since initially setting it into the upper corner cabinet.
mcascio is offline
Old 03-14-2014, 09:00 AM
BrentTHX's Avatar
Mario with your black lights around tray, did you have to have continues lights? Or are only a couple of 4 footers needed in each side?
BrentTHX is offline
Old 03-14-2014, 09:08 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
I have 2 four footers in each section spaced evenly. So a total of 8 are up there.
mcascio is offline
Old 03-14-2014, 09:27 AM
BrentTHX's Avatar
Thanks for the fast reply!! And what an amazing job you have done!! I will be giving you call about your control system you make!
BrentTHX is offline
Old 03-14-2014, 09:41 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
You're very welcome and thank you. You might double check on the black lights...I know there was talk of some newer more efficient models becoming available in the Night Sky Mural thread.
Looking forward to talking to you about the Cinemar control software as well. It's always great to talk shop and business in the same call. smile.gif
mcascio is offline
Old 03-14-2014, 10:41 AM
FortKnUX's Avatar
thanks Mario, I will try Vyron.  Closest Menards is about 500miles from me :)
FortKnUX is offline
Old 03-16-2014, 06:02 PM
BrentTHX's Avatar
Sorry for all the questions!! With your LED lighting did you go with 5050 2 watt a foot or 4 watt per foot ? Want to get lighting ordered tomorrow.
BrentTHX is offline
Old 03-18-2014, 08:33 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
Here's a link to the post where I have a link to the HitLight Led's I used along with some other information you may find helpful:
http://www.avsforum.com/t/1208912/the-cinemar-home-theater-construction-thread/2160#post_22275015
mcascio is offline
Old 03-18-2014, 08:43 AM
BrentTHX's Avatar
My bad!! I had read that already , missed in my question if you went with the 4 watt ( 300 led) on the stair nosing also. If I remember correctly somewhere I seen that you had to dim stage lighting and stairs down during movies quite a bit? If that's correct would I be better with the 2 watt ( 150 LED) strips?
BrentTHX is offline
Old 03-18-2014, 08:48 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
No problem. Hard to find unless you knew to search for HitLights.
I ended up using the same LED lights on the stairs. You can dim them down to your liking. In there brightest settings they really light up the stairs and in their dimmest setting, it's perfect to just be visible enough to show the step in the dark.
mcascio is offline
Old 03-18-2014, 08:54 AM
BrentTHX's Avatar
Thanks for the fast reply, I've looked at your build thread a million times, your work and ideas are nothing short of amazing!!
BrentTHX is offline
Old 03-18-2014, 09:04 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
You are very welcome. Glad I could contribute back to the community!
DavidinCT likes this.
mcascio is offline
Old 03-23-2014, 10:18 AM
jimmyk36's Avatar
Quoted: 80 Post(s)
Liked: 35
Hi Larry,
Here's a diagram showing the moulding I'm going with.
What did you use for the crown moulding? Great info! Thanks!
jimmyk36 is offline
Old 03-24-2014, 08:16 PM
awilcox's Avatar
Did you follow the speaker placement you detailed earlier in your thread? I have 2 rows of seating and one surround speaker at 90-100 degrees to 1st row.
awilcox is offline
Old 03-25-2014, 02:16 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
I ended up putting the side surrounds just behind the front row...so 90-100.
mcascio is offline
Old 03-25-2014, 02:17 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
I'll have to see if I can find a profile for you on the crown moulding and get back to you on that.
mcascio is offline
Old 03-26-2014, 04:28 PM
FortKnUX's Avatar
Mario, just curious why did you go with 36" door. I believe you were planning for a 32" door in the beginning. Were you concerned for the seats or screen fitting through the doorway?
FortKnUX is offline
Old 03-27-2014, 09:12 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
Here's an updated image that includes the crown. Hope that helps.
mcascio is offline
Old 03-30-2014, 06:36 PM
jimmyk36's Avatar
Quoted: 80 Post(s)
Liked: 35
Cool - Thanks!
jimmyk36 is offline
Old 04-02-2014, 09:51 AM
Jeff in Canada's Avatar
Quoted: 167 Post(s)
Liked: 61
Mario, did you purchase your shelves for your surrounds at Menard's? Do you recall the make?
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
Old 04-02-2014, 09:58 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
Hi Jeff.
Yes - I did buy them at Menard's.
http://www.menards.com/main/shelving-visualizer/garage-basement/12-x-48-pre-finished-shelf/p-1482172-c-13051.htm
I cut them to the proper depth to fit my columns.
mcascio is offline
Old 04-02-2014, 11:20 AM
Quoted: 167 Post(s)
Liked: 61
Thanks Mario.
What brackets did you use?
Theater Build
Old 04-02-2014, 11:26 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
Thanks Mario.
They look like these ones:
http://www.menards.com/main/storage-organization/closet-organization/shelving-hardware-brackets/7-in-dual-track-wood-shelf-bracket-black/p-1656400-c-13009.htm
I bought the size to match the depth of the shelf though. They come in a variety of sizes.
mcascio is offline
Old 04-02-2014, 03:23 PM
Quoted: 167 Post(s)
Liked: 61
Thanks again Mario. I appreciate it.
Theater Build
Old 04-02-2014, 06:14 PM
Quoted: 167 Post(s)
Liked: 61
Another question. You have rolls of insulation next to your subs in the front in a picture. Do you still have them in place? R30 roll? Did you take the plastic off of the sides but leave the cylinder wrapped in the original plastic? Is it compressed alot?
Theater Build
Old 04-03-2014, 01:30 PM
awilcox's Avatar
Mario,
Yet another question! I just spoke with Night Sky Murals and a questions about the soffit design surfaced. Since I am "borrowing" your design, I thought I would ask the expert.
Your soffit moulding concept shows a 7 3/4 opening from top of 2x4 to ceiling, did you keep this dimension? It is suggested I have a 10"-12" opening to allow black light to energize the ceiling. My ceiling areas are 7'3" x 9'9" and 11'2" x 9'9", which are smaller than yours.
Secondly, which lighting fixtures did you use and how did you mount them?
Adrian
awilcox is offline
Speaker Systems
