The Cinemar Home Theater Construction Thread - Page 103 - AVS Forum | Home Theater Discussions And Reviews
 61Likes
post #3061 of 3284 Old 05-29-2014, 03:37 PM
TMcG's Avatar
Quoted: 1129 Post(s)
Liked: 962
Originally Posted by mcascio View Post
I distribute all the video over a single cat5 and use component video baluns. This has worked out great over the years.
Have you noticed any issues with certain source components, like cable boxes, "de-res" the component video output from full 1080p down to 480p due to the AACS?
TMcG is offline
post #3062 of 3284 Old 05-30-2014, 05:55 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
No. I've never noticed it.
mcascio is offline
post #3063 of 3284 Old 06-26-2014, 12:40 PM
sshivaraman's Avatar
Audio panel thickness..
Hi mcascio ,
Its a great build, very inspirational. I'm doing a HT build right now & using 1/2 MDF for the base (wainscoting). How much thickness is your audio panels above? Does it project outside than the wainscoting? I coudnt able to find any OC703 in 1/2 inch thickness. Will it look ok if upper part of the wall protrudes out than the wainscot?
SS
sshivaraman is offline
post #3064 of 3284 Old 06-26-2014, 01:09 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
Originally Posted by sshivaraman View Post
Hi mcascio ,
SS
I used 3/4" MDF for the lower portion of the wall. The fabric panels were also 3/4" thick so it worked out perfect for me. Any reason not to go with 3/4" MDF? I think it'll make life easier if you are building fabric frames for the upper portion. 1/2" panels may be flimsy and hard to get them straight.
If your upper wall does protrude and you are doing a chair rail, just add a 1/4" filler behind your chair rail. I don't think anyone would notice.
Hope that helps.
ellisr63 likes this.
mcascio is offline
post #3065 of 3284 Old 06-26-2014, 01:36 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 413
Hope that helps.
Is that thick enough to do acoustic panels on the walls, or just for fabric only panels?
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #3066 of 3284 Old 06-26-2014, 01:43 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
I used denim on my walls instead of OC703. The denim was labeled as 1" thick but was actually 3/4". I believe, but you'll want to double check, that if you go with 1" OC703 that it may actually be 1". So I think others have to plan for that and build it out using furring strips.
mcascio is offline
post #3067 of 3284 Old 06-30-2014, 11:18 AM
Thank you for your reply. Where did you get the denim from?
post #3068 of 3284 Old 07-31-2014, 07:32 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
Sorry for the late reply. I can't recall the name of the company off the top of my head, but I think if you search this thread for the word denim, you'll probably find the company name since I mentioned it here to others.
mcascio is offline
post #3069 of 3284 Old 07-31-2014, 08:09 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
i hate to say but i know this thread to well
Quote:Originally Posted by FortKnUX
Mario, did you buy the denim online?  If so, do you happen to have the link by any chance?  I am too having less than an inch clearance for the fabric depth and all I can find is over 1" of thickness.
Also, have you ever found an optimal positioning for your subs?  I heard people try to put them back to back centered behind the screen shooting to the sides, that supposedly equally fills the room with the sound given you installed the traps on all 4 corners.
thanks!
I bought the recycled denim through http://www.vyron.com/ (Brookfield, Wi Branch) - ask for Tim Barham.
It's their Ecosheild Titus product I believe.
Although, I would check a local Menards. I thought they started carrying a similar product.
Note, the specs on the denim says that it is 1", but in fact in my case, it was actually 3/4".
Every room will perform different with the subs and their locations, but there are some recommendations posted on the web. In my case, I have them all up front. I have yet to officially test turning them in or rotating them to see how that affects the room. It would probably be a good test. The HSU is a real bear though to move in and out so I haven't worked up the energy to move it since initially setting it into the upper corner cabinet.
snickers1 is offline
post #3070 of 3284 Old 07-31-2014, 08:57 AM
24Changer's Avatar
Quoted: 116 Post(s)
Liked: 124
Mario, looking at your columns on Post #1578 , did you use any primer or another type of filler for the rough cut ends of your MDF corners?
Creekside Stone Cinema
24Changer is offline
post #3071 of 3284 Old 07-31-2014, 09:04 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
No foul there.
Thanks for tracking the information down.
snickers1 likes this.
mcascio is offline
post #3072 of 3284 Old 07-31-2014, 09:08 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
Yes - I'm pretty sure I walked through the steps in the thread somewhere...Snickers probably knows exactly where.
But essentially I used MH Ready Patch, Bin Zinnser Primer and various grits of sand paper.
mcascio is offline
post #3073 of 3284 Old 07-31-2014, 09:15 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
LOL!!! I don't have to look that one up i lived it first hand .... i followed the same steps except i used i think something called sand and sealer ... mdf is so very easy to sand and round the rough edges
just make sure to wear a mask that stuff is nasty
post #3074 of 3284 Old 07-31-2014, 09:51 AM
24Changer's Avatar
Quoted: 116 Post(s)
Liked: 124
Snickers, that's hilarious. Thanks Fellas!
post #3075 of 3284 Old 07-31-2014, 12:47 PM
Jeff in Canada's Avatar
Quoted: 167 Post(s)
Liked: 61
I've very blatantly copied off of Mario's work. His subs, his theater (thought I've clearly copied Snickers stage and other items as well)
I appreciate you guys leading the trail for us. I'm going to be putting up the exact same telescope velvet that Mario used on my ceiling above the screen and along my screen wall. I just need to put a plaque with Cinemar with a line through it and my theater name up somewhere.
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
post #3076 of 3284 Old 07-31-2014, 02:56 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
Be sure to let me know if you see a difference with the black material above above the screen. I've contemplated doing it, but I'd have to get creative with mounting it so it looks decent with the lights on.
mcascio is offline
post #3077 of 3284 Old 08-01-2014, 02:50 PM
Quoted: 167 Post(s)
Liked: 61
Mario, did you put the crushed velvet everywhere up front or did you use a mixture of the Telescope material and the velvet? Which did you like better? Is one better at 90 degrees to the screen and another better line line with the screen?
Theater Build
post #3078 of 3284 Old 08-01-2014, 03:05 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
Hi Jeff,
I put the triple plush black velvet on the area behind the screen.
I used the telescope material on the area below the screen that happens to also be the top for the cabinet and the sides of the cabinet that go floor to ceiling.
Oddly enough, the triple plush black velvet looks much blacker with the lights on than the telescope material. But to my advantage, the telescope material looks like the same color as my black paint. So it worked out perfectly.
It's been a while since I looked, but I believe the telescope material absorbs the light a little better than the triple plush velvet when turn out the lights and the projector is on reflecting off the screen.
mcascio is offline
post #3079 of 3284 Old 08-10-2014, 05:54 AM
Quoted: 167 Post(s)
Liked: 61
Mario, where did you get the cleats for your screen? Menards? How many did you use and how long were they?
Theater Build
post #3080 of 3284 Old 08-10-2014, 11:26 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
The hangman cleats came with the Seymour screen. I believe they looked like something you could pick up at Menard's or Lowes though. It's been a while, but I think there were 2 cleats about 18" long each.
mcascio is offline
post #3081 of 3284 Old 08-10-2014, 05:24 PM
Quoted: 167 Post(s)
Liked: 61
Thanks Mario
Theater Build
post #3082 of 3284 Old 09-03-2014, 05:36 AM
mry110's Avatar
Quoted: 133 Post(s)
Liked: 52
Alright Mario since your theater will more than likely be the inspiration for my theater in the house I am about to build, how are you planning to add Atmos (if you are)?
mry110 is offline
post #3083 of 3284 Old 09-03-2014, 07:37 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
I haven't done any extensive research into Atmos. But I believe it utilizes ceiling speakers....this certainly poses a problem for those of us who want isolated rooms with the fewest breaches in the ceiling.
I guess you'd have to build potential backer boxes for any places you think ceiling speakers could be located. In my case, my only option might be the cat5 cable I have sitting up in the soffit to be used as speaker cable. I don't think Atmos was being discussed when I was building....otherwise I probably would have planned for some more extensive options there.
Perhaps I'm way off base though and side speakers can be used instead of the ceiling speakers. Summer is coming to an end and I start to watch more movies, so I'm sure I'll want to dig into the latest technology.
My first step though would be to see whether Atmos is even worth pursuing before finding out if I could make it work. If the results are only marginally different than what I have now, it's probably better to leave things as they are.
Any reviews posted about Atmos in the forums worth reading?
dmarcink likes this.
mcascio is offline
post #3084 of 3284 Old 09-03-2014, 09:27 AM
mry110's Avatar
Quoted: 133 Post(s)
Liked: 52
Here you go.
Dolby Demos Atmos for Cinema and Home
There is also two reviews from an avs member, but I can't find it right now. He says it's pretty amazing, even with just the up firing speakers. I'm guessing those will not work with a barrel ceiling though.
mry110 is offline
post #3085 of 3284 Old 10-20-2014, 09:08 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
Hi everyone.
I got the itch to take on a wood working project and thought I'd post it here...sorry...a bit off topic.
I finished up a couple weeks ago a raised garden bed. It's about 20' x 20' x 2' tall. It's sunken in to a hill. So I purchased a rotary laser level and took measurements at each corner point where the beds where going to be placed. This allowed me to plug it into my 3D model and figure out exactly how far down I needed to dig a trench to set the beds into and keep everything nice and level. I wanted the inside area to be sunken into the sloping hill. So there is a step down into the raised bed garden on one side, but then a walk out at the bottom of the slope at ground level. Everything within the center rubber mulched area of the raised bed garden was carved out so it's 2' all around and optimal height for gardening. I was able to convert a sprinkler zone specifically to the garden area. So it will be easy to automate the watering on a timed schedule. It was my first time also using a HPLV spray gun. Looking forward to planting season next year.
BllDo likes this.
mcascio is offline
post #3086 of 3284 Old 10-20-2014, 09:26 AM
Quoted: 3454 Post(s)
Liked: 2921
Beautiful project. How is the deer population in your area? I've seen some raised bed gardens mowed down in my area.
post #3087 of 3284 Old 10-20-2014, 09:36 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
Beautiful work!!! , that yard is screaming for a nice big Koi pond
post #3088 of 3284 Old 10-20-2014, 09:36 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
Thanks. I've actually seen a few deer this year going through our yard. I think they may be even bedding down under our neighbors tree. They usually walk through our yard about 400 feet away from the house. The garden is pretty close to our house, so I'm not sure they will venture that close. I guess time will tell.
mcascio is offline
post #3089 of 3284 Old 10-20-2014, 10:56 AM
cuzed2's Avatar
Quoted: 197 Post(s)
Liked: 254
Mario,
Terrific job on the raised garden! So where will the outdoor speakers go?
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #3090 of 3284 Old 10-20-2014, 11:29 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 109
Thanks. I've thought about one in the past...but really am trying to limit anything that adds maintenance to my life.
mcascio is offline
Speaker Systems
