The Cinemar Home Theater Construction Thread - Page 104 - AVS Forum
 10Likes
post #3091 of 3103 Old 10-20-2014, 11:33 AM - Thread Starter
mcascio's Avatar
Liked: 69
Mario,
Terrific job on the raised garden! So where will the outdoor speakers go?
Funny you should say that. I have to have the lower speakers cranked in order to hear them while I was working on the garden. I may actually split off some of my existing speakers and trench it to the garden so I can mount some nearby.
Has anyone found led ribbons that can connect to low voltage landscape lights? It would be nice to add some lighting on the inside of the garden space underneath the cleats for some accent lighting. Not really functional for gardening at night but would look cool.
mcascio is offline
post #3092 of 3103 Old 10-20-2014, 11:35 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 45 Post(s)
Liked: 60
Originally Posted by mcascio View Post
Thanks. I've thought about one in the past...but really am trying to limit anything that adds maintenance to my life.
just need to clone yourself and then automate him just make sure you create the stay away from the wife "variable" LOL!!!!
mcascio likes this.
snickers1 is offline
post #3093 of 3103 Old Yesterday, 06:10 AM
cw5billwade's Avatar
Quoted: 146 Post(s)
Liked: 119
I would love to do something like that. I stole your theater ideas my as well steall this as well. do you have detailed plans you drew up and a bill of materiels?
cw5billwade is offline
post #3094 of 3103 Old Yesterday, 07:20 AM
Mfusick's Avatar
Quoted: 182 Post(s)
Liked: 927
What did you finish the wood with ?
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is offline
post #3095 of 3103 Old Yesterday, 07:32 AM - Thread Starter
mcascio's Avatar
Liked: 69
I just have the 3d model which doesn't provide any type of printed plan with dimensions.
It's pretty simple though. There are 4 beds that are 4x8 on the corners, then connect them using 10' - 2x6 Cedar.
I used 2x4 for the cleats and 2x6 cedar for the top ledges.
I have about 30 receipts from the project over the course of building it. If I had to guess, it was probably around $2500. Most of that being the Cedar. It probably took a month and a half working a few hours a day and on all day on the weekends.
mcascio is offline
post #3096 of 3103 Old Yesterday, 07:33 AM
cowger's Avatar
Liked: 43
Beautiful work, Mario! Looks like furniture-quality craftsmanship... certainly the nicest gardening beds I've ever seen!
Might need to think about something to scare the deer away. If they're like our "forest rats", they'll likely get pretty bold when they see and smell the delicious things in your garden... Maybe a motion detector that fires off a sprinkler (or something else that's loud and startling) at night...
Mfusick likes this.
cowger is offline
post #3097 of 3103 Old Yesterday, 07:34 AM - Thread Starter
mcascio's Avatar
Liked: 69
I used Thompson's Waterseal Transparent Woodland Cedar stain. It took about 2 gallons using an HVLP sprayer.
http://www.homedepot.com/p/Thompson-...1-16/204804191
mcascio is offline
post #3098 of 3103 Old Yesterday, 07:38 AM - Thread Starter
mcascio's Avatar
Liked: 69
Thanks. It was fun to build. I broke out the Kreg Jig for the 2x6 top ledges and sanded the entire thing down to a smooth finish. So it did feel like I was building furniture.
I may add a bench next year to the center with a flip open seat to store some tools and buckets for transporting the vegetables back into the house.
I like your idea. I could add a motion detector and trigger the sprinklers around the outside of the beds like you suggested if the deer do become an issue.
mcascio is offline
post #3099 of 3103 Old Yesterday, 07:54 AM
Mfusick's Avatar
Quoted: 182 Post(s)
Liked: 927
What sprayer you use? I'm in the market for one that can throw stain and clear on wood...
Mfusick is offline
post #3100 of 3103 Old Yesterday, 08:00 AM - Thread Starter
mcascio's Avatar
Liked: 69
I bought this kit:
http://www.homedepot.com/p/Husky-HVL...00SG/203497812
mcascio is offline
post #3101 of 3103 Old Yesterday, 08:08 AM
Mfusick's Avatar
Quoted: 182 Post(s)
Liked: 927
Like it? Recommend ?
Mfusick is offline
post #3102 of 3103 Old Yesterday, 08:18 AM - Thread Starter
mcascio's Avatar
Liked: 69
I really have nothing to compare it to since it was the first time using it. I did have to get pretty close to the wood or it would just vaporize into the air before hitting the wood.
It also helps if you do it during the day when you can see. Also, my first coat I applied before a chilly night and the next morning the stain hadn't taken yet do to the morning dew. I got nervous and wiped a section with a cloth and it messed it up even more. The lesson is to just leave it and let it dry.
I applied two coats. I noticed it was splotchy until I came back around with the second coat a few days later.
If I had to do it over, I might have just gone with a transparent stain without any color additives to make it seem more natural. Still happy with the results though.
mcascio is offline
post #3103 of 3103 Old Yesterday, 08:33 AM
Mfusick's Avatar
Quoted: 182 Post(s)
Liked: 927
Bright daylight or stupid excessive lights in garage are a must if spraying. Yes. I've used a lot of cheap HVLP guns but I am looking for one that is good for stain and wood clear, The harbor freight ones are cheap.
Ideally I'd like disposable cups I think. That seems nice.
Mfusick is offline
Speaker Systems
User Tag List
