The Cinemar Home Theater Construction Thread - Page 106 - AVS Forum | Home Theater Discussions And Reviews
 58Likes
post #3151 of 3282 Old 12-15-2014, 11:33 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
I had a chance to try some things out this weekend.
I actually ended up leaving my existing M&K SS-150's (Set them up in Dipole mode now) in the side columns and still using them as Top Fronts and Top Rears but also added some Tannoy Di 5DC as Top Fronts and located them in the soffit and bouncing off the ceiling. With just the Tannoy's (before Audyssey calibration) the sound seemed like it was coming from the Tannoy's but with both the M&K and Tannoy's together in different locations, the white noise sound seemed more difficult to localize. So I rolled with this setup (using the pre-amp outputs to power the extra speakers). With just the M&K's on the outside walls it was really nice, but I didn't get the sense that fly overs were actually above me. But with both sets of speakers, I felt surround sounds were wrapping around the room and above me.
With this setup, the Tannoy speakers are barely visible in the soffit. But I'm still curious if the experience will be any different with them point right at the MLP and not bouncing off the ceiling. So I plan to rig something in each corner temporarily to see if I can tell any difference. This would mean the speakers would be visible so I'm hoping I don't notice much of a sound difference so I'm can go back to plan A with them hidden.
I ordered another pair for placement in the soffit for Top Rears. I think this will mostly benefit the front row since it's just in front of the back row. But I think with the current M&K's behind the rear row assigned as Top Rear, they will still enjoy the experience.
mcascio is offline
post #3152 of 3282 Old 12-16-2014, 11:56 AM
Liked: 1
Wanted to throw you a PM Mario, but I'm a pleb here on the forums. Feel free to ax this message once you've read it!
I finally made it through your epic build thread, and I was amazed that it's still active after all this time!
I wanted to thank you for taking the time to put together such an incredible build thread! Your home embodies all of the qualities that I am looking to make for myself and my wife when we purchase a house. I grew up in Marinette WI and will hopefully be moving back from Saint Louis at some point in my life, the people in Wisconsin are just nicer it seems.
I wanted to ask you about your Cinemar software and what language it's programmed in. I'm a computer science major who never got to use any programming once I needed to start earning a living after school. I'm looking to add some skills to my resume, and it would be perfect if they just happened to give me an advantage with your ecosystem for home automation.
Thank you again for being so detailed and congratulations on your home theater. Truly something to be proud of.
-Danimal
cowger likes this.
Danimalx23 is offline
post #3153 of 3282 Old 12-17-2014, 12:44 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Hi Danimal.
Thanks for the compliments. You've got mail.
mcascio is offline
post #3154 of 3282 Old 12-17-2014, 09:55 PM
aakrusen's Avatar
Quoted: 14 Post(s)
Mario,
Did you comment somewhere in your massive thread about doing OSB and drywall vs two layers of drywall? I remember reading something about the OSB and the issues you had with the cutout area in the ceiling, but what about the rest of the room?
aakrusen is offline
post #3155 of 3282 Old 12-17-2014, 09:56 PM
aakrusen's Avatar
Quoted: 14 Post(s)
Edit: Oops, double post.
aakrusen is offline
post #3156 of 3282 Old 12-18-2014, 08:15 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Originally Posted by aakrusen View Post
Mario,
I'd highly recommend using OSB and drywall. Makes it extremely easy for attaching objects to the walls/ceilings since you don't have to look for studs especially for me when I did all the mouldings.
At first I was worried because the OSB in the soffit that cantilevered into the room wasn't straight...but we added some 2x4s to the edges and connected them altogether to fix that.
mcascio is offline
post #3157 of 3282 Old 12-18-2014, 10:29 AM
nickbuol's Avatar
Quoted: 553 Post(s)
Liked: 613
I used OSB for the first layer of my soffits, but 2 layers of drywall for everything else. Putting crown up on the soffits was super easy. Hanging stuff on the walls (in my case my surround speakers and acoustical panels are surface mounted) meant using toggle bolts. They work and hold well, but aren't the most "accurate" since you have to drill a larger than needed hole which can make it a little more difficult to get things level. Not "hard" but it is another step later.
Going back, I would look hard at doing OSB for the first layer. Yes, you can't use a roto-zip for cutting out outlets and such, but being able to put screws in wherever you wanted for the 2nd layer would have been nice (instead of having to make sure that you lined up perfectly with where your 1st layer screwed in to your channel or studs (staggered or double wall).
nickbuol is offline
post #3158 of 3282 Old 12-18-2014, 01:04 PM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
You still need to hit studs or channel for the second/third layers of drywall even if you do OSB as your first. Otherwise you are hanging all those extra layers off one set of screws and they are not meant to handle that much weight.
BllDo is offline
post #3159 of 3282 Old 12-18-2014, 03:33 PM
nickbuol's Avatar
Quoted: 553 Post(s)
Liked: 613
Wait, so it is more trouble to cut holes in OSB for outlets, etc, takes more time to cut sheets to size (have to use a power tool vs. a straight edge and a drywall knife), you still have to hit the studs/channel/whatever for the 2nd layer... How is this better than 2 layers of drywall everywhere?
I guess if your outlets are "surface mounted" to allow for floor to ceiling panels, or are on columns, but for the Joe-Schmoe that doesn't go that far, what is the benefit? I saw it with my soffits. It allowed for super rigidity of my "skeleton" soffit framing, and I could easily drive some nails through with my air nailer to hold my crown molding in place, but maybe I am glad that I didn't do that for my whole theater.
nickbuol is offline
post #3160 of 3282 Old 12-18-2014, 03:55 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
I guess I should clarify. I didn't hang the drywall or the OSB. So it wasn't more difficult for me to do. But yes - you would still have to hit the studs when putting up the drywall layer(s).
I personally only had 1 or 2 outlets/switch that had to be cut in. Every other outlet was built inside the room in columns and or hidden behind the screen. So aside from the extra labor in cutting the OSB, it wasn't much different than hanging the drywall.
I did do all the finish work, which included tons of crown, chair rail, wainscoting trim, baseboard, etc. All that was put up without needing to find studs. And it took an incredible amount of time. Having to find studs for all those would have been painful to say the least.
I personally wouldn't have done it any other way...but again...I didn't have to hang the OSB or drywall.
mcascio is offline
post #3161 of 3282 Old 12-18-2014, 07:22 PM
TMcG's Avatar
Quoted: 1072 Post(s)
Liked: 870
Another big +1 for 5/8" OSB on the first layer, especially if you are doing extensive molding or wainscot. You just can't beat the 'x marks the spot' approach for your finish work where 'x' is anywhere in your entire room. You only give up an inconsequential difference in mass that Ted White has said has no effect on STC ratings vs. 2 layers of 5/8" drywall.
Originally Posted by BllDo View Post
You still need to hit studs or channel for the second/third layers of drywall even if you do OSB as your first. Otherwise you are hanging all those extra layers off one set of screws and they are not meant to handel that much wight. .
Actually, you can increase the screw length to 1.5" - 2.0" length and narrow your screw pattern to 8" spread. I'd recommend using exterior coated deck screws vs. coarse thread drywall screws as the deck screws are significantly stronger in grip strength and sheer. Then you can attach the drywall to the OSB on non-stud locations. If you use just one layer of drywall on top of the OSB, standard 1.25" with Green Glue in the field of the OSB is more than enough. If you go with a third layer (i.e. second layer of drywall), then use 2" screws for the second layer, screwing into the field of the OSB, not the studs.
This approach assumes you are using a decoupled wall assembly and not using clips or channel. If you are using clips and channel, then all layers attach to the channel only, using progressively longer screws.
TMcG is offline
post #3162 of 3282 Old 12-19-2014, 08:27 AM
aakrusen's Avatar
Quoted: 14 Post(s)
Mario,
Thanks for the feedback on the OSB and Drywall (and thank you to everyone else who commented).
Do you have an opinion on your M&K speakers versus others in the same category? More specifically, something like the Klipsch THX line, something for DefTech, or maybe KEF or Paradigm?
I saw a pic of your gear rack way back before the basement was finished, and I've seen the cabinet/rack you built where all your speaker wires meet at the patch panel, but did you ever put up a pic showing where your AV gear is now? Is it in a different room of the house?
I may have missed it, but are you doing an IR repeater or is it all done on the iPad?
aakrusen is offline
post #3163 of 3282 Old 12-19-2014, 08:46 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Mario,
You're welcome.
I love my M&K speakers. I've had them for probably over a decade now and have added more over the years. I really couldn't speak to how they compare to other brands since I personally haven't auditioned any other speakers since owning the M&K's. Someone else may be able to chime in.
I ended up assembling another rack next to the house rack that holds all of the home theater equipment. I don't think I ever posted a picture. This is outside of the theater in a different room.
I do have an IR repeater in the theater that sends everything back to the rack. I have a single IR code that I listen for, that then powers everything on/off using MainLobby. I tend to use a standard physical IR remote for transport controls. I use a wall mounted touch screen outside of the theater usually to pick the movie before I head into the theater. If I happen to be in the theater and want to switch movies, I just pull out my phone. Although an iPad would provide the same functionality.
dragonleepenn likes this.
mcascio is offline
post #3164 of 3282 Old 12-23-2014, 09:59 AM
aakrusen's Avatar
Quoted: 14 Post(s)
Would you be willing to put up a few pics of that rack? Thanks and have a Merry Christmas.
aakrusen is offline
post #3165 of 3282 Old 12-23-2014, 10:15 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Sure. Here are both racks.
BTW, I've got an Onkyo 3008 that I'll probably be listing on the AVS Forum if anyone is interested.
mcascio is offline
post #3166 of 3282 Old 12-23-2014, 10:35 AM
aakrusen's Avatar
Quoted: 14 Post(s)
Crap, I just bought an Onkyo 809 yesterday. Just for the sake of knowing, what are you going to ask for it?
Thank you for the pic. Any comments on the racks? Are you happy with them? Would you change anything? Can you list all the gear?
aakrusen is offline
post #3167 of 3282 Old 12-30-2014, 03:34 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Not sure how much to ask for the Onkyo 3008 yet...I'll have to look online to see what they are going for.
I like the Middle Atlantic racks. A bit pricey, but last forever. Mine are on wheels so I can easily pull them out to get in back. Nothing that I can think of that I would change. I'm constantly adding or removing hardware and it's been flexible enough to allow me to do that. Just make sure you have lots of shelves...otherwise you have to pull the hardware on top out to get to the hardware on the bottom if you end up stacking too much.
Most of the gear is listed in my first post.
I don't think I listed all my house equipment though like the (3) Russound Cav's.
mcascio is offline
post #3168 of 3282 Old 01-13-2015, 11:26 AM
Kamikaze13's Avatar
Quoted: 98 Post(s)
Liked: 49
Are the photos missing for everyone in post #569 or just me, The Cinemar Home Theater Construction Thread
Any way to see them?
VIDEO: JVC DLA-RS57U Projector / 122″ EluneVision Reference Studio 4K Cinemascope Screen - Oppo BDP-103 Blu-Ray Player - PlayStation 3 AVR: Anthem MRX-1120 SPEAKERS: Paradigm Monitor 11 Mains - Paradigm Monitor CC-390 Center - Paradigm Monitor ADP-390 Surrounds x 4 - Polk MC60 Atmos Ceiling x 4 SUBWOOFERS: SVS PB2000 / Velodyne DPS-12
Kamikaze13 is online now
post #3169 of 3282 Old 01-13-2015, 11:26 AM
Kamikaze13's Avatar
Quoted: 98 Post(s)
Liked: 49
Are the photos missing for everyone in post #569 or just me?, The Cinemar Home Theater Construction Thread
post #3170 of 3282 Old 01-13-2015, 11:57 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
I was able to fix the links. You should see them now.
mcascio is offline
post #3171 of 3282 Old 01-13-2015, 12:10 PM
Kamikaze13's Avatar
Quoted: 98 Post(s)
Liked: 49
Wow thankyou very much.
Your theater is so awesome it has inspired me to renovate mine, starting with the ceiling.
I'm hoping to steal some of your designs. Who am I kidding, I'm hoping to steal all of your designs lol.
Amazing workmanship.
post #3172 of 3282 Old 01-13-2015, 01:03 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Thanks so much.
Looking forward to following your build thread!
mcascio is offline
post #3173 of 3282 Old 01-25-2015, 05:34 PM
Jeff in Canada's Avatar
Quoted: 167 Post(s)
Liked: 61
Mario, I'm almost done my copy of your theater design. It is not as high nor clearly as nice as yours, but the front is done. My cloth will be more of a light brown / gold color versus the red you had and my carpet is more home carpet versus the theater carpet you have.
Thanks again for telling me it was okay to take your ideas and plans. I really appreciate it.
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
post #3174 of 3282 Old 01-25-2015, 05:35 PM
Quoted: 167 Post(s)
Liked: 61
Theater Build
post #3175 of 3282 Old 01-25-2015, 09:01 PM
Quoted: 93 Post(s)
Liked: 48
Looks great.
Doradoguy is offline
post #3176 of 3282 Old 01-26-2015, 06:51 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Looking great Jeff. Hopefully you will have many years of enjoyment ahead of you like I have in your theater.
mcascio is offline
post #3177 of 3282 Old 02-12-2015, 02:26 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
A bit off topic, but I was looking around for a pool cue rack for the rec room and found one product that I liked but it was no longer available. So I decided to design and build one myself instead to the size I needed.
I think it turned out pretty good. Just need to apply some stain to match the bar and hang it up.
It was made from Poplar.
cuzed2, 24Changer and granroth like this.
mcascio is offline
post #3178 of 3282 Old 02-12-2015, 07:22 PM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 236
Mario,
Looks good. I see you made it from Polar - good choice.
Make sure you use a liberal covering of pre-conditoner just prior to applying the stain, that will give you a smoother less-blotchy result from your stain.
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #3179 of 3282 Old 02-13-2015, 07:38 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Mario,
Thanks for the tip!!
Any recommendations as to what pre-conditioner to use?
mcascio is offline
post #3180 of 3282 Old 02-13-2015, 09:45 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I've used Zinsser and sealcoat /Bullseye on Poplar before with good results. Minwax used to make a pre-stain wood conditioner, but it's not available in some areas (CA I know for sure) due to law changes.
Charles Neil also has a good product that many people swear by. Just search his name and "blotch control"
Take a look at this: https://www.dropbox.com/s/uw8ev824cb...utpdf.pdf?dl=0
Try this, is should help. ^ Drop me a PM or reply here after you grab it so I can kill the download link. I don't want it up forever.
All you need to know.
Mfusick is offline
Speaker Systems
