The Cinemar Home Theater Construction Thread - Page 108 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #3211 of 3222 Old 03-06-2015, 12:13 PM
Mfusick's Avatar
Quoted: 510 Post(s)
Liked: 1998
Originally Posted by cw5billwade View Post
Don't hold out on us I have been considering this myself.
Well we talked a little about it here: DIY Tool Talk
I'm going to do something and add a router table to my new table saw fence I just upgrade. I have about 3 feet by 28.5" between the rails to play with. Fence is 50" with a 42" rip. A kreg drop in top is a possibility. As was Incra. Or I could use a cheap one like this $99 RYOBI I have from HD, and just take the legs off it.
I kind of made a DIY table back in Bryan's thread when I first played with raising panels.
All you need is a hole in some MDF for the router to poke through and you have a router table.
It's the fence system, adjustments, featherboards, miter gauges and all the fun stuff that is a pain if you DIY. If you want a proper one better to buy it IMO. But a make shift router table is pretty easy.
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is offline
post #3212 of 3222 Old 03-09-2015, 06:25 AM
cw5billwade's Avatar
Quoted: 308 Post(s)
Liked: 171
Thanks you are the best.
cw5billwade is offline
post #3213 of 3222 Old 03-12-2015, 08:22 AM
Quoted: 53 Post(s)
Mario,
I wanted to thank you again for your hospitality the other night. It was great meeting you and experiencing your theater was an absolute thrill. Although, I have to admit it was bad experiencing some of your extra treats, ie d-box. All that did was cost me money!! Your entire basement is awesome and I appreciate you sharing it with us.
Jeff
jlcichocki is offline
post #3214 of 3222 Old 03-12-2015, 08:27 AM - Thread Starter
mcascio's Avatar
Quoted: 56 Post(s)
Liked: 89
You bet Jeff.
It was great to talk shop with you and James. Thanks for the bottle of wine!
BTW, I noticed my Darbee had been turned all the way down (Perhaps when I unplugged it a while back), so the picture got even better after I reset that back up to the levels I initially had it at.
Also, I'd probably recommend you and James go with the Dune Base 3D for playback over the other models I suggested.
Let me know if you end up going with the M&K speakers.
Hopefully you don't need a visit to the chiropractor after experiencing the D-Box. That Flight of the Pheonix is pretty violent. I noticed it had moved James' chair over about 6" even with him in it.
mcascio is offline
post #3215 of 3222 Old 03-12-2015, 10:50 AM
Quoted: 53 Post(s)
Originally Posted by mcascio View Post
You bet Jeff.
Hope the wine is to your liking, consider it thanks and prepayment for future guidance
I'm interested in the Dune. Wondering if it will be compatible with 4k?
Interesting about the Darbee. I thought picture was already great!
I am between Triad and M&K. Planning a Triad demo soon. I'll keep you posted and plan for a future demo at my house
That is hilarious about the d-box. It was really fun!!
Jeff
post #3216 of 3222 Old 03-12-2015, 11:55 AM
Liked: 0
Mario,
Loved your theater build, you have contributed a ton to the aspiring DIY'ers and for that I THANK YOU. Did you build your own screen or did your order it from Seymour? If DIY, can you point me to some tips for building your own CIH screen with Seymour AT material?
MAXTATE
maxtate is offline
post #3217 of 3222 Old 03-12-2015, 12:23 PM - Thread Starter
mcascio's Avatar
Quoted: 56 Post(s)
Liked: 89
Hi Maxtate,
Thanks so much. Glad you found the thread helpful.
I ordered my screen and frame directly from Seymour.
mcascio is offline
post #3218 of 3222 Old 03-12-2015, 01:23 PM - Thread Starter
mcascio's Avatar
Quoted: 56 Post(s)
Liked: 89
Jeff
Hey Jeff,
I don't think it will support 4k. But I think it might provide a good interim solution until 4k is more mainstream.
Yeah - keep me posted on your speaker selection.
mcascio is offline
post #3219 of 3222 Old 03-25-2015, 01:18 AM
marlon1925's Avatar
Quoted: 51 Post(s)
Quote:Originally Posted by kmhvball
Do you use some type of Matrix switch to get different signals to the end destination TV locations?    How many 'inputs' could you have and how many output locations?
I have an 8x8 audio/video matrix switch. (8 inputs to 8 outputs) I double up a couple of TV locations like the outdoor popup TV that get less frequent use.
We offer larger matrix switches like 8x16 or 12x16 that typically get installed into restaurants and bars though.
Where did you buy the switch sir?
marlon1925 is offline
post #3220 of 3222 Old 03-25-2015, 09:34 AM
kmhvball's Avatar
Quoted: 231 Post(s)
Liked: 117
I haven't purchased one, but, Mario got his from the Cinemar web-site (albeit, he may not have ordered from the web-site, I believe he has contacts ;-):
https://www.cinemarsolutions.com/hdt...ches_cmx88.php
marlon1925 likes this.
kmhvball is offline
post #3221 of 3222 Old 03-25-2015, 09:44 AM
Bassfeen's Avatar
Quoted: 108 Post(s)
Liked: 81
This may sound bias coming from me but a Full Quested System in this theatre will kick ass. The Quested LT (Long Throw) will work perfectly well in this sort of design.
I just getting a AT Screen, Raise the speaker height
Bassfeen is offline
post #3222 of 3222 Old 03-25-2015, 02:39 PM
dragonleepenn's Avatar
Quoted: 125 Post(s)
Liked: 59
[IMG][/IMG]
Like these in "thebland's" theater.
PeterV
dragonleepenn is offline
Speaker Systems
