The Cinemar Home Theater Construction Thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 79Likes
post #721 of 3298 Old 10-11-2011, 07:43 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 125
Originally Posted by Jailguy View Post
I went with the John Mansville brand and I paid $7.20 per 2x4 board, plus no shipping. I'll PM you the name and address of the place when I'm on my home computer.
Wow. That's a fantastic deal.
mcascio is offline
post #722 of 3298 Old 10-11-2011, 07:49 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 125
The first steps are taking shape. A little challenging bending a 1x12!
I'm going to fill the inside with insulation. The top will be treated with two layers of 3/4" OSB. We'll be putting 1/4" MDF on the face of the stair with finishing nails and a bull nose edge using 3/4" MDF and a 1/2" MDF combined and routed.
The next step top will be completely MDF. I like the contrast of the carpeting and the solid material on the steps. Hopefully that will also make it less dangerous when navigating the theater in the dark. I should be able to route LED lights underneath the bull nose of each step. They'll be plugged in behind the front row seats.
mcascio is offline
post #723 of 3298 Old 10-11-2011, 09:40 AM
iced98lx's Avatar
very encouraging! Stay at it!
My "Resale Home Theater" build --- Last Update 10/10/11
My DIY 125 inch Laminate Screen --- Don't Build yours like this!!
iced98lx is offline
post #724 of 3298 Old 10-11-2011, 05:33 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 46
MDF as the top of the stair?
Larry M is offline
post #725 of 3298 Old 10-11-2011, 05:39 PM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 125
I'll be using 3/4" MDF (that will be painted black) for the bull nose on each step. The front stage and one step will have MDF on the TOP walking surface per my renderings.
The carpenters recommended that since it was going to be painted black anyways as opposed to using wood. I was thinking the columns would also be made out of MDF.
Any downsides to this theory?
mcascio is offline
post #726 of 3298 Old 10-11-2011, 05:49 PM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
I personally would use a hardwood for the bullnose. I have concerns over whether or not the bullnose on an mdf sheet would stand the test of time.
It certainly would route a lot easier.. but given all the time/money/energy spent on everything else, I would go with oak.
Tim
Mr.Tim is offline
post #727 of 3298 Old 10-11-2011, 05:54 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 46
MDF is a great material, but I would never imagine using it for something that might have foot traffic on it. IMO it is too soft and I don't know how the paint/stain will hold up. I guess I would use oak as a common wood even though I don't like oak's markings...maple or birch as inexpensive wood will be nice
Columns out of MDF are fine BTW
Larry M is offline
post #728 of 3298 Old 10-11-2011, 07:22 PM
w1retap's Avatar
Quoted: 52 Post(s)
Liked: 51
Definitely don't use MDF for places with foot traffic. It wears really easily. When painting MDF, it takes a lot of coats because it just soaks into it.. and still still doesn't turn out that great.
w1retap is offline
post #729 of 3298 Old 10-11-2011, 08:00 PM
deewan's Avatar
Quoted: 294 Post(s)
Liked: 288
+1. I can't believe they said mdf would be fine. It will dent the first time someone kicks it or drops anything on it. I use it all the time for speaker cabinets and know the dangers or a little too much pressure and the effects it has on the mdf.
deewan is offline
post #730 of 3298 Old 10-12-2011, 03:50 AM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
I would second maple. Expensive, but very nice grain.
Mr.Tim is offline
post #731 of 3298 Old 10-12-2011, 05:02 AM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 46
I find it not priced too bad; it seems to be in the middle between oak and the imported woods with a great grain.
Looking at the amount he needs, it won't break the bank too much vs. MDF
Larry M is offline
post #732 of 3298 Old 10-12-2011, 05:23 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 125
Thanks guys. That's what's great about this forum. Just diverted a potential disaster.
I'll check out the 3/4" wood stock at Menard's today. Oak is really only 30% more than MDF. Maple appears to be almost 3x but probably would suit my needs better and would see less grain when painted black.
mcascio is offline
post #733 of 3298 Old 10-12-2011, 02:34 PM
roknrol's Avatar
Quoted: 32 Post(s)
Liked: 38
If you're going to sand, prime, and spray a couple of coats of good-quality latex, I wouldn't think the grain of the oak would show through. Oak would definitely hold up to the wear and tear; maple is a little hard to come by from the big box stores, but your region may be different.
roknrol is offline
post #734 of 3298 Old 10-12-2011, 04:34 PM
btinindy's Avatar
Quoted: 38 Post(s)
Liked: 56
You should fill the pores prior to priming if you are going to paint it.
btinindy is offline
post #735 of 3298 Old 10-15-2011, 04:03 PM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 125
What do they use to fill the pores?
mcascio is offline
post #736 of 3298 Old 10-15-2011, 04:05 PM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 125
They made some progress on the front stage today. Next step...steps!
I think I'm going to order sand bags from Lowe's and have them deliver it for $20. Hopefully they can deliver some dry sand. Is 6 mil plastic ok to use within the stage joists?
mcascio is offline
post #737 of 3298 Old 10-15-2011, 04:23 PM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
Mr.Tim is offline
post #738 of 3298 Old 10-15-2011, 04:42 PM
btinindy's Avatar
Quoted: 38 Post(s)
Liked: 56
I have used wood filler successfully followed by a really good filler primer or sealcoat. It may take several applications and sanding to get it really good and smooth so a good hard maple may be a better alternative and use BIM primer prior to painting. Make sure you use a good paint that will stand the test of time. Probably an oil based paint or a good acrylic from Benjamin Moore or Sherwin Williams.
btinindy is offline
post #739 of 3298 Old 10-15-2011, 06:27 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 46
(cough) Benjamin Moore (cough)
Larry M is offline
post #740 of 3298 Old 10-17-2011, 07:00 AM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 84
Hey Mario - yes, 6 mil plastic is the way to go for the stage joists. Looking good!
AirBenji is offline
post #741 of 3298 Old 10-17-2011, 10:48 AM
KNKKNK's Avatar
Quoted: 39 Post(s)
Liked: 103
+1.. Maple is actually slightly harder than both red and white oaks and wont require as much prep work for a paint finish
KNKKNK is offline
post #742 of 3298 Old 10-17-2011, 10:50 AM
dwightp's Avatar
To fill wood pores using shellac or lacquer, you have to apply many coats -- 10 or 12 -- and then sand most of it away. Basically, you're building up shellac in the pores and sanding it away in other areas, until the entire surface is smooth. It takes a long time and makes a mess. It can be worth the trouble if you're going for a mirror finish that highlights the grain of the wood. There's no reason you couldn't use the same process under paint, but there are easier alternatives.
If you're going to paint the wood, any decent filler can be used to fill the wood pores, so long as the filler dries hard. Since the wood is going to be painted, you don't care about whether the filler looks like wood -- which opens the door to some better products, I think. I happen to prefer a product I buy at an auto paint store. It's a lacquer-based body filler sold in a tube like a big tube of toothpaste. It is easy to apply with a flexible putty knife, it dries very fast, it sands pretty well, and it won't shrink. I have also used Bondo with good results.
Whatever paint you use, it is highly unlikely it will stand up to foot traffic unless you put a couple of layers of clear top coat over it. I would strongly encourage you to use a top coat made for finishing wood floors. Here's an example from a manufacturer I like:
Link: http://www.woodessence.com/WFF2000-W...nish-P132.aspx
dwightp is offline
post #743 of 3298 Old 10-17-2011, 08:16 PM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 125
Thanks guys for the responses.
I'll probably be going with Oak since it's readily available and on sale at Menard's.
More exciting progress tonight as the next steps were put in on the riser and the front stage.
mcascio is offline
post #744 of 3298 Old 10-17-2011, 09:26 PM
cdika17's Avatar
Really starting to take shape, keep the updates a coming!
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #745 of 3298 Old 10-18-2011, 03:29 AM
misterkit's Avatar
What did you make the DBox platform out of? It looks like the Bosch Rex Roth stuff.
misterkit is offline
post #746 of 3298 Old 10-18-2011, 04:09 AM
MysticalJet's Avatar
Quoted: 81 Post(s)
Liked: 153
Really Really coming along nicely. I like the design and color scheme quite a bit. What camera are you using to take the photos?
MysticalJet is offline
post #747 of 3298 Old 10-18-2011, 06:31 AM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 84
Great work Mario!
AirBenji is offline
post #748 of 3298 Old 10-18-2011, 10:03 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 125
It was constructed out of T-Slots. I had a local company cut the pieces and pre-drill the holes for me. I'm not familiar with the Bosch stuff, but it's possible there are similar products and/or even sold under different names.
mcascio is offline
post #749 of 3298 Old 10-18-2011, 10:06 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 125
Thanks. I'm using a Canon EOS 50D.
Shouldn't be too much longer and I'll need to order the fabric for the walls. Then I'll truly be committed to the color scheme.
mcascio is offline
post #750 of 3298 Old 10-18-2011, 10:07 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 125
Great work Mario!
Looks like you're not too far behind.
mcascio is offline
Speaker Systems
