The Cinemar Home Theater Construction Thread - Page 30 - AVS Forum | Home Theater Discussions And Reviews
 58Likes
post #871 of 3282 Old 11-19-2011, 11:38 AM
TheaterChad's Avatar
Quoted: 25 Post(s)
Liked: 31
Originally Posted by mcascio View Post
Hi Larry,
You might want to see if they can dial in the price range a bit. That's pretty broad. Cabinets are not cheap and if you need moulding to match the specific color like I did, that gets expensive too. Anything with curves, arches or angles seems to add to the cost.
Thanks TheaterChad.
I did spend quite a bit of time planning around all the gaming tables. Especially the shuffle board. It pays though to plan it ahead of time rather than jamming everything in. I was able to move walls to fit everything in and still have space to gather and walk.
I bought the stools online:
http://www.barstools.com/bar-height-...elbarstool.cfm
Buy one initially. Then they send you a coupon code for your next order.
Excellent, Thanks for the link, that's much more affordable than what I found anywhere near me, thanks a million!!
TheaterChad is offline
post #872 of 3282 Old 11-19-2011, 12:49 PM
tbraden32's Avatar
I have some that are very similar to these too, purchased from Target on line. Really cheap price, decent quality for the price.
tbraden32 is offline
post #873 of 3282 Old 11-19-2011, 02:10 PM
Quoted: 25 Post(s)
Liked: 31
Thanks, that's another factor to think about, cost and quality, thanks for the info
post #874 of 3282 Old 11-19-2011, 02:59 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
Hi Larry,
Thanks TheaterChad.
Yeah she was just ballparking. I asked them to come up with some designs but they wanted $250 up front and I wasn't ready to do that yet.
I was there purchasing under cabinet molding for my kithcen and it cost me $200 for 32 ft at contractor prices
The under cabinet molding turned out great by the way, took me a few hours but I like perfect cuts
Larry M is offline
post #875 of 3282 Old 11-19-2011, 07:35 PM
ragged's Avatar
ragged is offline
post #876 of 3282 Old 11-19-2011, 09:08 PM
JTR7's Avatar
I must say, I love your Cinemar interface. Is that custom for you or is it included or an available for purchase skin with MainLobby?
JTR7 is offline
post #877 of 3282 Old 11-20-2011, 10:55 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Originally Posted by cowger View Post
Mario, I haven't tried sanding sealer, so that may work fine, but I vastly prefer the drywall compound over something like shellac (which, like the sanding sealer, also takes several coats).
I'm not sure how you're planning to manufacture those columns, but I think the best way would really be to miter the corners, so that you end up with the outside surface extending all the way to the corner on all both surfaces. That, however, would require a table saw, and probably a high-quality one at that (ripping something that long at 45 degrees for a perfect fit isn't trivial). If you have a buddy with a workshop, that would probably be best, *but* I'm also confident that you can get good results with the drywall compound, provided that your basic cuts are clean and straight.
Good luck! Wish we were closer so I could lend a hand on the woodworking...
Bryan
Thanks for the feedback. I didn't cut the corners at 45's. May be beyond my personal scope. But I'm still developing my prototype column. I'll check with my father-in-law and see what he thinks about the drywall compound vs. sanding sealer. Yeah - would be great to have someone with some knowledge like yourself on-site!
Larry,
When I was doing my bar, I didn't really get much input from all the places I stopped by. I couldn't really find anyone locally to do it either. So I pretty much ended up doing all the design ideas myself and then ordering the cabinetry from Home Depot. The cabinet doors worked great as paneling for the front of the bar.
mcascio is offline
post #878 of 3282 Old 11-20-2011, 11:01 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Thanks JTR7. The last two screenshots I posted are included with the current MainLobby 3. I may have posted some screens from Version 4 in the past that haven't been released yet. But will be shortly. Those will be included with MainLobby 4 and won't require the purchase of a separate GuiGraphix Library.
mcascio is offline
post #879 of 3282 Old 11-20-2011, 11:04 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
I tackled more of the columns today. Gave the Kreg jig a try as well. I wasn't really sure how many places I should screw the sides to the front. I think I ended up using about 7 or 8 per side. Applied and finish nailed some of the larger speaker mouldings and pre-cut the moulding for the bottom of the front column. I'll need to order some black GOM fabric before I can permanently mount the remaining mouldings. You'll notice a white inside frame. That's MDF that I used to attach the mouldings to and provide some additional support. I may also need to paint some of the mouldings before I completely finish nail them to the column since it's be adjoining the GOM fabric.
mcascio is offline
post #880 of 3282 Old 11-21-2011, 02:56 AM
phisch's Avatar
Quoted: 58 Post(s)
Liked: 41
That's a clever way of creating the relief on the columns, those will look great when they are done. Nice job.
phisch is offline
post #881 of 3282 Old 11-21-2011, 06:18 AM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
Larry,
Home Depot you say This isn't their stock cabinet line is it?
My main issue with the bar is the location with the trapezoid opening, I have googled for hours looking for a similiar setup and nothing
Perhaps I'll stop by Home Depot and see if they have any ideas
Larry M is offline
post #882 of 3282 Old 11-21-2011, 08:49 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Thanks Mike. It does add more depth to the columns and a bit more dimension.
mcascio is offline
post #883 of 3282 Old 11-21-2011, 08:52 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Hey Larry. They are Kraftmaid cabinets. Special order. A lot of the other "more expensive" places we went to were also carrying Kraftmaid and I had heard good things about them. Plus I didn't want to spend a ton on bar cabinetry.
I haven't seen your bar plan, but if you are trying to fit cabinetry into that angled area, why not use standard cabinets with 45's on each end and then cut the counter to fit the shape. Then use fillers as needed.
mcascio is offline
post #884 of 3282 Old 11-21-2011, 09:18 AM
ModestHT's Avatar
Wow, your project is really looking great. The bar turned out classy and I love the shuffle board. I really wanted to add one to our basement but just couldn't figure out a good place for it. Looking forward to future updates.
ModestHT is offline
post #885 of 3282 Old 11-21-2011, 03:50 PM
roknrol's Avatar
Quoted: 27 Post(s)
I agree. I was wondering how you were going to take the columns from the renders and turn them into reality. Mystery solved!
My vote for the MDF edge concealment is to use sealant, generous amounts of wood filler, then palm sander. I've used that method and also the drywall compound. The latter is quicker initially, but may (in my case -- did) develop cracks down the line.
roknrol is offline
post #886 of 3282 Old 11-21-2011, 05:30 PM
BeerParty's Avatar
That's a brilliant idea! I just wish I had thought of it before I bought my bar stools.
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #887 of 3282 Old 11-21-2011, 09:15 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
Thats basically what I was thinking but hoping a cabinet designer or someone can show me an example so I can get a more clear idea. I laid masking tape down to get an idea
Larry M is offline
post #888 of 3282 Old 11-22-2011, 06:14 AM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
How are you attaching the fabric in the columns?
Any more details on the trim you used? Interested in the back profile
Larry M is offline
post #889 of 3282 Old 11-22-2011, 08:25 AM
cowger's Avatar
Liked: 73
Good point. How thick was your drywall compound? For what I was advising, it ends up being absorbed into the MDF; there's nothing to crack. Again, it depends on how close to perfect the original cuts are. If they are way off and he's filling more than maybe 1/64th", I'd be concerned that many fillers could crack, including drywall compound.
Mario, do you have a router? If so, you could use that to flush trim the front so that it's exactly matched to the sides. Might be an easy way to ensure that any filler ends up at zero thickness.
Bryan
cowger is offline
post #890 of 3282 Old 11-22-2011, 08:39 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Hi Larry,
Here's a diagram showing the moulding I'm going with.
I'm still on the fence about how to tackle attaching the fabric. Especially on the sides. I'm open to recommendations.
For the sides, I was thinking of just using hot glue or contact cement to attach it to the MDF. I'm thinking stapes may fray the edge of the MDF since I only have about 1/2" of contact with the mdf to fabric.
Here's an illustration. The moulding is 3/4" and I'll finish nail it over the top of the fabric and then into the mdf.
For the lower front of the column, I have a lot more room to staple or glue the fabric. The top half grill needs to be removable. I'm planning to use a plastic speaker frame from parts-express.
I ordered the Black GOM so I'll be getting to that phase soon.
I cut all the mouldings for the first column. I became more and more efficient. I started using a finished cut moulding piece as a template to mark the next piece for cutting. The trick was to place them back to back on the floor and then use a sharp pencil to trace the cut line. This narrowed by cuts down to about two or three per moulding per side. Much easier than using the measuring tape. Then to shave off a hair, I would lower the mitre saw blade down and push the moulding against the blade. Then lift the blade up and make the cut. The teeth are a little larger, so it just shaved a smidge off the end moving me closer and closer to my finished cut. These are probably all stuff the pro's know, but being my first time. I'm learning as I go.
mcascio is offline
post #891 of 3282 Old 11-22-2011, 09:08 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Bryan
Bryan,
I can definitely say that the edges are not perfect. And even with the Kreg jig, as I tightened the screws it pushed the edges a bit over their mark as I joined the pieces together. I think I'll need to clamp the MDF together next time before joing them to keep them from moving off their square. I think the hairline edge can be sanded though.
I do have a router. What type of bit are you suggesting using? The edges that I cut for the first column look pretty smooth.
Everything's going black, so I'm hoping shadows and just the overall room will hide some of the imperfections.
mcascio is offline
post #892 of 3282 Old 11-22-2011, 09:22 AM
cowger's Avatar
Liked: 73
Awesome. My advice would be to get a bit like this:
http://www.rockler.com/product.cfm?p...20router%20bit
Make your face frame about 1/8" too wide, attach the sides as straight as you can, with about 1/16" of overhang on each side, then trim it flush with that bit. Should yield perfect results every time.
Bryan
cowger is offline
post #893 of 3282 Old 11-22-2011, 09:51 AM
deewan's Avatar
Quoted: 226 Post(s)
Liked: 211
While building speaker cabinets I do exactly what is listed above with the fluch bit. Cut the pieces about 1/8 inch too big, then use the Kreg to join them with a slight overhang and use the flush bit to trim. Makes a perfect seam every time.
I wouldn't use wood filler or dryuwall compound on the MDF or seams. It will crack. If it's possilbe to construct these columns in a well ventilated area I sugguest using Bondo. It smells horrible (think of the glue used in model cars when you were growing up) but it will seal well and when sanded will give you a SMOOTH surface. I used bondo on my curves speaker cabinets. Here is a picture of the before and after. You can see how rough the before was, and how smooth the bondo is sanded and painted.
deewan is offline
post #894 of 3282 Old 11-22-2011, 10:34 AM
ModestHT's Avatar
Larry,
You can also special order cabinets at Menard's. They will design your space for free but it does require time and thought. I must have changed our plan at least 10 times You might also want to stop by Menard's / Home Depot and grab a cabinet catalog to see what sort of cabinets, styles, hardware, and trim you're interested in. There are a ton of choices.
The extra's from mouldings to trim to real 3/4" cabinet construction can get expensive but not as much as custom cabinets. We ended up getting all of our cherry cabinets at Menard's at 20% off. I also ordered a couple of quarts of matching stain and ended up staining much of the trim and wainscoting around the bar and saved a ton of money that way.
All of this is detailed in the link below.
ModestHT is offline
post #895 of 3282 Old 11-22-2011, 01:36 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Looks cool. How easy is it to work with bondo?
Would I need to bondo the entire column or just the corners?
One thing to that's in the back of my mind is that I'm not necessarily trying to make it look like the corner doesn't exist, but rather create a smooth matching finish on the cut edge so it's paintable. I want it to look like painted wood (but without the grain). If I look at my expensive kitchen cabinets, you can see where the wood panels were seamed together. But the edges are nice and flush.
I'm not necessarily looking to make it look like the columns were drywalled and there are no seams.
mcascio is offline
post #896 of 3282 Old 11-22-2011, 01:37 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Any tips/tricks for cutting the GOM and working with the large roll? It seems like it'd be challenging to get nice straight cuts with scissors.
mcascio is offline
post #897 of 3282 Old 11-22-2011, 05:29 PM
deewan's Avatar
Quoted: 226 Post(s)
Liked: 211
Bondo is fairly easy to work with. Must like Drywall compound, only you have to mix the material with a hardener and it dries solid within minutes (depending how much hardener you use). Sometimes it's 3-4 minutes, sometimes 10. It won't work well if you are trying to keep the seams of the wood and just seal the end cut MDF. It's more if you don't want to see seams. I would maybe suggest using something like pine instead. Keeps the seam, won't have to seal the end cut after sanding. Just my two cents.
deewan is offline
post #898 of 3282 Old 11-22-2011, 06:11 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
Hi Larry,
Nice selection of trim, may I suggest a fancier base? You have a lot of curves in all your trim, but the base looks relatively flat.
By the way, absolutey incredible job with the diagrams...jeez I ask for the molding profile and I basically get the CAD version...pure excellence
Larry M is offline
post #899 of 3282 Old 11-22-2011, 07:49 PM
carboranadum's Avatar
Quoted: 21 Post(s)
I measured the length that I needed, unrolled the length onto the floor in another room, then used a level on top of the GOM, and cut beside the level using it as a guide.
It worked really well and I didn't have any errant cuts.
Good luck!
carboranadum is offline
post #900 of 3282 Old 11-23-2011, 06:33 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Guys.
Thanks for all the great advice. My father-in-law seems comfortable with the bondo. So I think we'll try that on the edges. Then use sanding sealer on the entire unit along with sanding.
Larry,
I actually intended on going a bit fancier with the trim. But I had quite a bit left over from the basement that I decided to use that instead of just throwing it away. Otherwise, I would have gone with a slightly taller base and more decorative.
mcascio is offline
Speaker Systems
