The Cinemar Home Theater Construction Thread - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 60Likes
post #1081 of 3284 Old 12-27-2011, 08:08 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Originally Posted by longtimelurker View Post
get the dewalt biscuit joiner....it is fairly cheap, quite good, and you will find uses for it.
thinking about cutting biscuit joints on a router makes my brain hurt.
Thanks for the info guys on the biscuit joiner.
mcascio is online now
post #1082 of 3284 Old 12-27-2011, 08:08 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
Glad the spoundproofing is paying off this early!
__________________
Ted
The Soundproofing Company
Ted White is offline
post #1083 of 3284 Old 12-27-2011, 08:15 AM
Quoted: 3445 Post(s)
Liked: 2906
Now you are showing off with all that hardwood riser/steps treatment. I'm Jealous.
post #1084 of 3284 Old 12-27-2011, 08:30 AM
theWalkinator's Avatar
Good job! I have some difficult time to cut curves with jig saw, mind to share some tips?
theWalkinator is offline
post #1085 of 3284 Old 12-27-2011, 08:35 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Just another perk I didn't even think of initially.
post #1086 of 3284 Old 12-27-2011, 08:38 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Wow. I'm honored. I've seen your incredible work...there's nothing to be jealous about. I'm learning as I go.
post #1087 of 3284 Old 12-27-2011, 08:44 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Well I am by no means an expert. Although I have logged quite a few hours now with the jig saw on this project.
1. Get the right tool for the job (The Bosch and blades make a big difference)
2. Use the right blade (again using the wrong bosch blade will affect your cut, time and clean edge)
3. Take breaks. You begin to zone out.
4. Don't let the blade get too hot. See #3 and take breaks.
5. Clean the dust off the surface so you can see the line ahead
6. Let the jig dictate the speed. If you push it through too fast, you might start cutting the edge at an angle unintentionally. The jig saw will pretty much push itself.
7. Use your free hand to guide the jig
8. Go slow and make small adjustments to stay on target
Does anyone know how long these blades should last when cutting oak?
post #1088 of 3284 Old 12-27-2011, 02:01 PM
btinindy's Avatar
Quoted: 38 Post(s)
Liked: 56
Great work. It looks really good and I can tell that you are taking your time one the cutting.
My luck with blades on hardwood like this is new blade ever 50' or so. Could probably go longer, but the cut would start to fray the wood which required a lot more sanding! I hate sanding, and blades are cheap (relatively and if you find a decent source!) YRMV.
Keep up the great work. Glad you like the Bosch.
btinindy is offline
post #1089 of 3284 Old 12-27-2011, 02:35 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Thanks btinindy. I need to make a trip to Home Depot to stock up on more blades!
So I'm tossing around the idea of carpeting the front stage...before I commit to the work and materials. It would be a pretty large time saver and would also eliminate some of the light reflections in the room. I added the bullnose in other areas mostly to help prevent someone from mistepping in the dark theater. The front stage is not a concern obviously.
Any thoughts on which you guys would do based upon these renders? I would still using 1/4" solid surface for the rise...just carpet on the top.
post #1090 of 3284 Old 12-27-2011, 03:08 PM
MysticalJet's Avatar
Quoted: 81 Post(s)
Liked: 152
I like the carpet for the front stage... but I'm biased because that is what I did. I just like the continuity and seamless flow.
So I vote carpet
BTW - I am still amazed at those renders every time I see them.
MysticalJet is offline
post #1091 of 3284 Old 12-27-2011, 03:53 PM
scl23enn4m3's Avatar
How about using solid black carpet? I like the look of carpet and the pro of being non-reflective. But the patterned carpet on the stage doesn't flow as well as solid black with the two angled columns up front.
scl23enn4m3 is offline
post #1092 of 3284 Old 12-27-2011, 04:17 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
I have found the Bosch jig saw blades, as well as just about any other brand and type of saw blades, to be much more affordable from Amazon than either Menards or Home Depot. And if you have Amazon Prime, you will get them delivered in two days. Only the times when Menards has something like a 15%-20% off on Bosch accessory's sale, is when they come close to Amazons prices.
Trust me, Amazon has lost money on me with their free two day delivery for prime members. Free two day delivery on two sets of 48"x18"x72" steel wire shelving units at 65lbs each and a 85lb TV stand assured that.
Johnla is offline
post #1093 of 3284 Old 12-27-2011, 04:22 PM
HFGuy's Avatar
Quoted: 200 Post(s)
Liked: 177
Man those are some really shallow cup holders
HFGuy is online now
post #1094 of 3284 Old 12-27-2011, 05:39 PM
tbraden32's Avatar
I say carpet with a wood bullnose to keep the look...
Agree with Mystical on those renders. They are amazing and so real looking.!
Keep it up Mario
tbraden32 is offline
post #1095 of 3284 Old 12-27-2011, 05:49 PM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 83
+1 for plain black carpet. And the theater really looks great Mario!!
AirBenji is offline
post #1096 of 3284 Old 12-27-2011, 07:37 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
I'm a Amazon whore.
I won't buy anything unless I check with Amazon first
My Bosch jig and blades came from Amazon
Larry M is offline
post #1097 of 3284 Old 12-27-2011, 07:38 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
Looking good Mario, keep up the good work
Larry M is offline
post #1098 of 3284 Old 12-28-2011, 05:52 AM
misugrad's Avatar
Mario - fantastic layout and build; I've been following along. I'd say your main room carpet for the stage; seems to work better in your rendering.
Mike
Started the build...Theater With A View
misugrad is offline
post #1099 of 3284 Old 12-28-2011, 06:29 AM
ModestHT's Avatar
Looking awesome Mario! Man, you've made a ton of progress in a relatively short period of time. The stage probably would be easier and look great with carpet and, like you said, would minimize reflections.
ModestHT is offline
post #1100 of 3284 Old 12-28-2011, 08:01 AM
dwightp's Avatar
Now I just need to figure out how to make a biscuit joint. I'm pretty sure I just need a bit for the router but will do some research.
You could also join the sections of bullnose together using pocket screws (on the bottom, of course). You would assemble the whole section on the work bench and then lay it in place. Personally, I would use pocket screws before I would cut biscuit slots with a router.
If you want to use biscuit joints, you should check Craigslist for used biscuit joiners. You should be able to pick up a machine for under $100 that would be perfectly fine for occasional use.
dwightp is offline
post #1101 of 3284 Old 12-28-2011, 08:06 AM
dwightp's Avatar
I like the idea of solid black carpet on the horizontal surfaces and black-finished wood on the vertical risers. The difference in sheen and texture will call attention to the fact that you have different levels there, while still being fairly subtle.
dwightp is offline
post #1102 of 3284 Old 12-28-2011, 08:07 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
I have a biscuit joiner and would recommend it over the router... I also have a jig system... what the heck is it called... I wanna say Craig System... Anyway, I think Big has this system also. Uses jigs to guide the drill to make precise holes, then use their screws. I like that also.
__________________
Ted
post #1103 of 3284 Old 12-28-2011, 08:16 AM
It is called Kreg.
post #1104 of 3284 Old 12-28-2011, 08:18 AM
speedoflight's Avatar
Liked: 24
It's Kreg
speedoflight is offline
post #1105 of 3284 Old 12-28-2011, 08:18 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
Kreg! That's it. Thanks
__________________
Ted
post #1106 of 3284 Old 12-28-2011, 08:59 AM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 83
+1 on the Kreg jig. It has been incredibly useful for me.
AirBenji is offline
post #1107 of 3284 Old 12-28-2011, 10:39 AM
dwightp's Avatar
Pocket screws = Kreg jig
Here's the kind of joint we're talking about:
dwightp is offline
post #1108 of 3284 Old 12-28-2011, 10:52 AM
trek737's Avatar
Your theater is looking great... Nice Job!
trek737 is offline
post #1109 of 3284 Old 12-28-2011, 12:21 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Thanks guys. I do have the Kreg jig. Used it extensively on the columns. I'll go that route instead of the biscuits.
If I decide to run with the carpet on the stage, can I just construct the top layer out of OSB? Then put a lip underneath to beef it up for the carpet to wrap around?
I don't think a bull nose will look right on the stage given the shallow depth of the stairs but something I'll double check.
I have my "carpet lady" checking into a black carpet to match the color and weave of the Masland Quadrate Time's Square. That may sway my decision on solid oak, black carpet or the same Time's Square pattern.
post #1110 of 3284 Old 12-28-2011, 01:28 PM
Liked: 2906
Masland has a nice basic plush black. IMHO It won't matter if it is darker and different weave than the rest of the floor. That is the gray Quadrate of the floor. The plush is so black you really don't see the weave.
Speaker Systems
