The Cinemar Home Theater Construction Thread - Page 64 - AVS Forum | Home Theater Discussions And Reviews
 78Likes
post #1891 of 3297 Old 06-07-2012, 12:18 PM
Ron_C's Avatar
Everything is looking great!! I will be having a similarly sized room as well. What radius are you using on your curve in the riser and stage?
Ron
Ron_C is offline
post #1892 of 3297 Old 06-07-2012, 12:28 PM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
Ron
Hi Ron,
It's actually somewhat of an oval rather than a circle. I had to cheat it a bit to make things work for the room. My goal was to closely match the curve in my seating...all curves were pretty much based off the seats.
I plotted points (measuring out then in) from the 3D software onto the wood when it came time to make the first curve.
mcascio is offline
post #1893 of 3297 Old 06-07-2012, 03:59 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 46
Originally Posted by mcascio View Post
We used a Benjamin Moore Regal Eggshell FInish Black (Ultra Base N319 4B).
The paint brush was a Purdy XL Glide
http://www.menards.com/main/paint/brushes-rollers-trays/paint-brushes/nylon-poly/purdy-xl-glide-paint-brush/p-1496295-c-8104.htm
What was the price difference compared to Regal Select?
Larry M is offline
post #1894 of 3297 Old 06-07-2012, 06:40 PM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
Not sure Larry.
I never looked into it.
mcascio is offline
post #1895 of 3297 Old 06-08-2012, 05:37 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 82 Post(s)
Liked: 126
we had our house painted with BM regal and i know the where super happy we went with that paint, and to be honest we have friends that used same painters but different paint and you can see difference...great great choice
snickers1 is offline
post #1896 of 3297 Old 06-08-2012, 05:43 AM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 84
Thanks Mario - Just ordered my new drills!
And I used the same paint and brush on my trim - excellent results!
AirBenji is offline
post #1897 of 3297 Old 06-08-2012, 06:36 AM
trek737's Avatar
The dark paint really makes a difference in the appearance of the theater... Very Nice! Looking forward to seeing it completed...biggrin.gif
trek737 is offline
post #1898 of 3297 Old 06-08-2012, 06:50 AM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
Thanks Mario. Does your FIL have any tips on painting trim you can share. I never seem to be able to get mine done without leaving brushmarks. I've tried adding Flotrol which helped, but it didn't look as clean as your's. I was using Porter's higher end laytex on white trim last time I tried. Theater will be black though and any brushmarks will be more evident.
GetGray is offline
post #1899 of 3297 Old 06-08-2012, 08:11 AM
Ron_C's Avatar
Quick question....what is the reason to use a brush application over a spray approach? Spray wouldn't be prone to brush stokes, so I wonder if it is just your FIL preference or another reason. I know it would be difficult for you to do with already finished ceiling(could mask off with plastic).
Ron
Ron_C is offline
post #1900 of 3297 Old 06-09-2012, 07:25 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
My FIL was very happy with the results of the first coat. He did another 2nd coat test and said he'll be using Floetrol since it sets up quicker over the original coat. That will give him time to play with it a bit more.
mcascio is offline
post #1901 of 3297 Old 06-09-2012, 07:27 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
AirBenji.
Glad you could take advantage of the great bargain.
I used my Discover and saved another 5% through Shop Discover plus got free shipping.
mcascio is offline
post #1902 of 3297 Old 06-09-2012, 07:37 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
1) Use the right brush - soft tips
2) Make sure surface is clean and dust free. If you are dragging dirt around you'll start creating lines.
3) Always paint out of a separate can from the original paint can in case you do introduce dirt to your brush
4) Apply generously on your first coat getting into all the nooks and crannies
5) Always brush into the previously painted section
6) Sand your primer and then your first coat
7) Paint with the end of the brush and not the side of the brush
8) Pull away from your insides corners
9) After you've applied generously, use the tips of the brush, not pressing hard, to lightly run over the area you just painted tapering off on your pressure
10) Paint will tend to build up higher up on your brush, use a hard clean edge, to scrape it off from time to time
When painting cabinets, he said always paint the back side first. Because your paint will have a tendency to wrap around the front corner. So when you do the front you'll be knock off that edge you created.
Elevate the object when you need to paint close to the ground so you don't pick up dirt. For example, he put a couple blocks under the door when he rolled it so he could get to the bottom edge.
These are just some of the tips I learned when he showed me. I'm sure I'm missing lots of stuff. It's a whole 'nother game when you actually try to do it.
Putty
Anothing thing, for puttying...only carry a small amount of it around the room so it doesn't absorb chemicals from your hand. Be sure to set any extra on plastic.
Twist the putty in your hand into a nice pencil tip...then push it into the hole and swipe your finger. Then run your clean hand lightly across the putty. Don't push to hard otherwise you'll create a half moon. I found just lightly rubbing it the opposite direction depending upon the hole may sometimes produce better results.
Cleaning your brush
I found out my FIL still has and uses brushes that are over 10 years old and aside from the handle still look in great shape. Cleaning them is an art form in itself. For the latex paint, he was using dish soap and comet. Then a wire brush is run through the bristles. In the soapy water, he plunges the brush into the bottom to remove the paint. He'll do this a couple time's emptying the dirty water and starting again with clean soapy water. After the brush is clean, he squishes the brush in his hands to get excess water out. Then he straightenss the bristles with his hand so they come to a sharp point. This will keep the brush like new after it dries rather than flared out.
I used to just throw away brushes after every use because I could never get them clean and I thought that's what most people did!
mcascio is offline
post #1903 of 3297 Old 06-09-2012, 07:45 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
Ron
I think I had asked him about spraying it a while back but I think he thought the paint would have been too thick. Plus I already had the top ceiling area finish painted and fabric in the soffit.
He sprayed my entire house as well as did finish work on my bar to match the bar cabinetry and it turned out fantastic. So I didn't really question him. He's the expert.
mcascio is offline
post #1904 of 3297 Old 06-09-2012, 07:47 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
I finished puttying last night.
Glad to be done with that phase.
The oil primer on the Oak areas was still not completely dry.
My FIL was over early painting some more areas that were ready for him.
mcascio is offline
post #1905 of 3297 Old 06-09-2012, 07:57 AM
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
Putty
Mario: Thanks very much! 2 questions, What type putty did you use? Some painters use caulk, I had one guy say to use spackling. Wondered what you were using? Second, you mention sanding the 1st coat, aren't you using laytex? I didn't think you could sand laytex?
GetGray is offline
post #1906 of 3297 Old 06-09-2012, 08:19 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
I used DAP Professional Painter's Putty '53'.
My FIL using All Purpose Whiting if the consistency of the putty isn't right or too oily I believe.
You can sand Latex lightly to get a smoother finish. I did a quick google search and it looks like it's common.
I think most of us are just used to paint on drywall where you usually have a sand texture in the paint and sanding isn't necessary.
mcascio is offline
post #1907 of 3297 Old 06-09-2012, 08:22 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
Doh.
Our kitchen plasma just went out the other day - no picture (anyone know if plasma's have fuses?) ( I hear the power click on but I can't see the picture brightness change or see an onscreen menu so I'm assuming it's shot). Ice maker stopped working, started working again last night. And the D-box actuator failure makes three.
Usually things break in three around our house...so I'm hoping that's it for a while.
mcascio is offline
post #1908 of 3297 Old 06-09-2012, 09:05 AM
Edge540's Avatar
Mario,
i have a samsung lcd that had capacitors go bad in the power supply. powering up the unit only gave a clicking sound and nothing else on a four year old tv. i beleive this is more a samsung issue as they used cheap caps that cant handle the heat in this location. Four dollars and a little time investment had the thing working fine once again.
i did read that the samsung plasma doesnt have this issue due to better caps used but never know.
Edge540 is offline
post #1909 of 3297 Old 06-09-2012, 06:50 PM
tbraden32's Avatar
Mario,
Your progress is great...! Question, on your columns you have left the tops and sides open, assuming for speakers in the rear ones but what about the front ones? Acoustics?
tbraden32 is offline
post #1910 of 3297 Old 06-09-2012, 07:06 PM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
Originally Posted by Edge540 View Post
Mario,
Mine is a Hitachi. It doesnt have an external power supply so I wouldn't really know where to begin. It's about 8 years old. Tv's just don't last as long as the old tubes.
mcascio is offline
post #1911 of 3297 Old 06-09-2012, 07:08 PM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
Originally Posted by tbraden32 View Post
Mario,
Thanks. Anywhere I don't put speakers gives me an opportunity to add acoustic treatment. I was thinking of putting Oc703 in all the lower half columns. I could probably make them 6-8" deep.
mcascio is offline
post #1912 of 3297 Old 06-10-2012, 07:22 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
I finished priming the insides of the front wall cabinet floor and top. I know you won't see it, but I figured I've come this far.
I also put one coat of paint on the back sides and edges of the cabinet doors. I'll sand and then put another coat on today and then let my FIL do the fronts.
mcascio is offline
post #1913 of 3297 Old 06-10-2012, 07:54 AM
cmgunn's Avatar
Doh.
Could be the ZSUS and/or YSUS boards.
cmgunn is offline
post #1914 of 3297 Old 06-10-2012, 05:07 PM
HFGuy's Avatar
Quoted: 202 Post(s)
Liked: 179
It's threads like this that make me want to work alittle harder at work smile.gif
HFGuy is online now
post #1915 of 3297 Old 06-12-2012, 07:47 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
Thanks. I think I'll track down the model# and see if I can find anything online. I really don't have any tools that would allow me to test anything if it's failed so I may be up the creek on this one.
mcascio is offline
post #1916 of 3297 Old 06-12-2012, 07:48 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
mcascio is offline
post #1917 of 3297 Old 06-12-2012, 08:21 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
I made a little progress last night.
I rolled black paint onto the flooring of the front cabinetry wall and put a coat of paint where all the hinges are going and the dividers between the cabinets.
Here's all the cabinet doors sanded after the first coat.
mcascio is offline
post #1918 of 3297 Old 06-14-2012, 09:36 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
The Seymour screen and masking panels arrived yesterday. It looks like they packed it really well.
My FIL finished giving the walls in the theater their first coat. He also gave one side of the door a first coat.
I finished putting on the 2nd coat on the back side of all the cabinet doors and rehung them so it's easier for my FIL to put two coats on the front side.
mcascio is offline
post #1919 of 3297 Old 06-14-2012, 09:53 AM
Brad Horstkotte's Avatar
Liked: 72
Looking great Mario, the room is going to look sick when the carpet goes in!
Brad Horstkotte is offline
post #1920 of 3297 Old 06-15-2012, 06:10 AM - Thread Starter
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 124
Thanks Brad. I did take a carpet sample in there and it certainly does pop nicely.
mcascio is offline
Speaker Systems
