The Cinemar Home Theater Construction Thread - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 60Likes
Old 12-18-2012, 07:10 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
A couple more tidbits of information on the Dune HD Max...I had an in-depth discussion with one of their company reps a couple of months ago regarding the technical aspects of this piece of equipment. Not to go into boring detail, but there are two main deficiencies to this unit: 1. The 10/100 support vs. full gigabit which may or may not matter based on your network topology and the storage devices feeding the HD Max; and 2. HDMI 1.3a output which means that it does not support 3D. There will be an update to address both of these issues by next summer so I am told, plus a few upgrades (i.e. better DACs, etc.) to really take this device to the next level. I have one of the newer ones earmarked for my rack if / when it is available.
Yeah - I haven't noticed any issues with only 10/100 support on the Dune HD Max although I've only watched a couple movies. I've launched about 20-30 and haven't seen any hiccups yet when watching any of them for a few minutes at a time.
When the 3D version comes out, I'll be using the Dune HD Max as a dedicated whole house movie player. I bit the bullet and ordered the Panasonic PT-AE8000U Projector.
Based on the reviews and forums I've read, it seemed like the clear winner to me in that price range and having all the functionality I needed.
Honestly, I'm still extremely happy with my PT-AE4000U. Given that it's a light controlled room, it seems plenty bright to me. But my curiousity to so something better has gotten the best of me. Especially during some of the promotions going on.
mcascio is offline
Old 12-18-2012, 08:29 AM
design1stcode2nd's Avatar
Quoted: 31 Post(s)
Liked: 44
Having a Pana 4k as well I'd like to see your review of the 8k to see if you feel the increased performance is worth it. I'm sure I'll have my 4k for years, I'm hoping to wait until Ultra HD (4k res) is available at below $3,000 beofre I upgrade.
Play like a Raven
design1stcode2nd is offline
Old 12-18-2012, 10:39 AM
J_P_A's Avatar
Quoted: 593 Post(s)
Liked: 450
What's the latest with Cinavia and these players? It's been quite a while since I looked into it, but back then everyone was predicting nothing but doom and gloom in the future for media streamers like the Dune. I haven't seen much about it lately, though.
I've been using a Dune for several years now, and I've been very pleased. I finally bit the bullet and bought one after I got tired of the endless fiddling with the HTPC. I'll probably pick up another one for the theater when it's finished.
The Plains Theater Has Begun
J_P_A is offline
Old 12-19-2012, 06:31 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
If HDi keeps a few models without a built-in BD-ROM then we should have a few without Cinavia enabled. It is only mandatory on players that have both BD-ROMs and support BD menus. This is why some of the lower priced Dune models are dropping BD menus altogether in favor of BD-Lite.
Killroy is offline
Old 12-20-2012, 06:37 AM
J_P_A's Avatar
Quoted: 593 Post(s)
Liked: 450
Good to know! Can they retain lossless audio. I only vaguely remember that there are more tradeoffs than just losing the fancy menus with BD lite. This is one of those things that I just have not kept up with as much as I would like to.
J_P_A is offline
Old 12-20-2012, 07:02 AM
allybuck64's Avatar
how tall are you wall MDF panels? And I think I read somewhere on here that you used 1/2'' for the walls and 3/4" for the columns is that correct.
allybuck64 is offline
Old 12-20-2012, 07:49 AM
hifiaudio2's Avatar
Quoted: 403 Post(s)
Liked: 110
I used 1/2" MDF (out about 2" from the wall to allow for treatments behind) in my theater and it worked great.
hifiaudio2 is offline
Old 12-20-2012, 10:01 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Hi allybuck64,
The majority of the room wall panels are 30" tall. They are made of 3/4" MDF. The columns are the same thickness.
The very front section is about 36" tall.
mcascio is offline
Old 12-21-2012, 07:19 AM
ScAndal's Avatar
Liked: 27
Mario,
I'm looking at the columns you made for your side surrounds. Since you are using Dipoles, any issues with your speakers since you have a fair amount of MDF blocking them?
ScAndal is offline
Old 12-21-2012, 08:09 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Originally Posted by ScAndal View Post
Mario,
Hi ScAndal,
My Side and Back Surrounds are actually set to Tripole mode.
I never really took the time to see if I was loosing anything after constructing the columns. I know when I built the columns I did my best to make sure the side openings (fabric area) would accomodate the placement and angle of the speakers. This wasn't too difficult to do taking accurate measurements of the speakers and putting them into my 3D software.
The only way I could think of to measure the results was to measure the volume of the tripole sound coming from the sides of the speaker. So I pulled the speaker out of the cabinet and placed a sound level meter a couple inches away from the tripole speaker and measured 97 dba.
I put the speaker back in the column and measure again just outside of the fabric and it measure 95 dba.
So from this test, it appears I'm loosing 2 dba through the side tripole's because of the columns. Although the front of the speaker should be producing the same level of sound since there is no MDF blocking it.
mcascio is offline
Old 12-21-2012, 06:07 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Since adding the Dune HD Max - it pushes out a bit more information that I wanted to add to my LED MainLobby Movie Poster.
I've added a progress bar at the top above NOW PLAYING and also the time code just below NOW PLAYING.
Not sure I'm sold on it and may reorganize the look again, but it's pretty cool to see the time updating as the movie is playing.
mcascio is offline
Old 12-21-2012, 06:42 PM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
how about add another row at bottom and have the progress bar and time left also maybe move dbox icon under the movie rating?
snickers1 is offline
Old 12-27-2012, 10:24 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Yeah - i'm gonna have to play around with some more ideas. I liked the idea of it at the top since that's where the start time / end time was located.
But by shrinking the height of the cover art, it will give me some more room.
mcascio is offline
Old 12-27-2012, 10:29 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Hope everyone had a great Christmas.
These cups showed up under the tree for the theater's front row D-Box seats.
They work great for mixed drinks and soda and prevent spills while sitting in the motion seats.
mcascio is offline
Old 12-27-2012, 10:38 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
The new Panasonic PT-AE8000U is installed.
A few first impressions and some comparisons of the PT-AE4000U I previously had in the theater.
Out of the box, the colors seem more vibrant compared to the 4000. There's certainly more light output and brightness.
I can see the walls around the room light up more because of this...but not to the point of it distracting. Everything really seems sharper.
The NORMAL lamp mode seems louder than the PT-AE4000U.
I like the fact that I can now hide the text PROCESSING IMAGE as it switches back and forth between different screen size / formats. Especially for movies like Tron where it's switching within the movie itself.
I was curious to see how much better the 3D has improved. While I have yet to watch an entire movie, I was impressed with the 3D. In fact, I wanted to show my Father In Law what it looked like and I only had one pair of 3D glasses. He actually was so wowed by it that he sat by himself in the theater and watched the entire movie (Ice Age).
I have yet to do much tweaking of the settings aside for some options in 3D.
My perspective is if you are an existing AE4000U owner and not interested in 3D, you might consider holding on to your 4000 for a while - or just upgrade to the 7000.
But I think the jump in price from the AE4000U to the AE8000U is definitely worth it if you also want to dive into 3D. You'll have to figure in the cost of the 3D glasses though too. They aren't cheap.
Hope that helps others make a decision.
mcascio is offline
Old 12-28-2012, 04:33 PM
cowger's Avatar
Quoted: 20 Post(s)
Liked: 75
GREAT info on the 8000, Mario, thanks! I'm using the 4k today and while I'm tempted to upgrade, I'm not that into 3D just yet.
But your review is just what I was looking for in terms of decision making...
Bryan
cowger is offline
Old 12-28-2012, 04:39 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Bryan
Good to hear. I guess if someone didnt have a light controlled room they might make the jump sooner too.
mcascio is offline
Old 12-28-2012, 06:55 PM
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
cw5billwade is offline
Old 12-29-2012, 03:39 AM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
Ahh great idea Mario
My wife sells promotional items and she is always bringing samples home.
Hmm maybe once the theater is done I can get a logo put on it
Larry M is offline
Old 12-31-2012, 10:45 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Larry.
That's a great idea. I like the idea of branded cups for the theater.
Let me know if your wife has similar cups as promotional items and if they can be ordered in small quantities.
I did some Koozies branded with our themed annual outdoor party logo I created a few years back and it was a big success.
mcascio is offline
Old 12-31-2012, 12:25 PM
HopefulFred's Avatar
Quoted: 496 Post(s)
Liked: 432
Tervis will insert your object into their tumbler. Can't beat the quality.
HopefulFred is offline
Old 12-31-2012, 02:01 PM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 142
Be sure to check the size of your cup holders. The ones in my Berkline 13175s are not big enough to hold a 24 oz Tervis tumbler, and the bases on their 10oz, 12oz and 16oz tumblers aren't much smaller. HopefulFred is right though, you can't beat the quality.
Spaceman is offline
Old 01-01-2013, 05:35 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
Mario
How did you attach the fabric screens to your columns and picture frames?
It looks like the moulding is nailed to the framing/mdf and your friction fitting the fabric in???
I picked out some panel moulding the other day, it's not as nice as I would like but not bad. I've been racking my brain on how I'm going to make removable screens for the columns
Larry M is offline
Old 01-01-2013, 05:37 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
Larry.
I'll have her look into it. Usually they are quantities prohibitive to what a homeowner would need but I'll look anyhow smile.gif
Larry M is offline
Old 01-02-2013, 07:05 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Mario
Hi Larry,
If you are referring to the moulding frames on the front lower section of the columns.
I build the frames first. Then attached the fabric to the frames with staples. Then attached the frames with a couple finish nails.
Here's the link to the details:
http://www.avsforum.com/t/1208912/the-cinemar-home-theater-construction-thread/2010#post_22162038
And some pics from that post:
I used different techniques for the sides. Let me know if you were referring to something else.
The top half where I needed access for the speakers are removable. I used magnets to hold the frames in.
mcascio is offline
Old 01-02-2013, 07:08 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Good to know.
I'm guessing your Berkline cup holders are the same as my berkline's.
I'd be interested int he 16oz tumbler's. Anyone know for sure whether they'll fit into the Berkline cup holders?
mcascio is offline
Old 01-02-2013, 07:26 AM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
Hi Larry,
I was reviewing that post last night. I'm still not understanding how you did it.
The picture with the moulding facing down with the fabric stapled to it, is the fabric stapled right to the moulding or do you have a small frame attached to the moulding?
Where and how did you attach the magnets?
Larry M is offline
Old 01-02-2013, 07:34 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Hi Larry,
In the above photo, I attached the fabric to the moulding...no frame was needed because the moulding itself was beefy enough. These frames are the small ones located on the front of each of my columns on the lower half. They are not removable. I finish nailed them right to the column. Initally I was going to make them removable, but it wasn't that big of a deal.
Now the top half of the columns have removable frames using magnets. The frames were plastic and bought from parts-express.
This post goes into details of how I build the frames and attached magnets:
http://www.avsforum.com/t/1208912/the-cinemar-home-theater-construction-thread/900#post_21251596
mcascio is offline
Old 01-04-2013, 12:47 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 108
Good to know.
I picked up a 16oz Tervis Tumbler at the local Bed Bath and Beyond.
I can confirm that they do fit in my Berkline cup holders.
Has anyone else done a custom Tervis tumbler for their theater?
I would think you wouldn't want them all to be the same so that you know which cup is yours. It might be cool to have movie themed cups but due to copyright issues, that won't work. I did see some Star Wars tumblers on ebay though.
mcascio is offline
Old 01-04-2013, 03:03 PM
Quoted: 496 Post(s)
Liked: 432
Not considering cost (not sure how much it might run), I'd want my name on a marquee, embroidered on a patch and put in the tumbler ...or maybe the name of a movie. Lots of embroidery shops (like a stand in the mall) can probably put something together for you. Maybe they already have a marquee design that they can just insert your text into. You might pay for the custom design, but I bet a 2 inch by 3 inch patch with your name on it (or "JAWS" or "NIGHT OF THE LIVING DEAD" or "MOONRAKER") would be pretty reasonable. I have never used Tervis's custom services.
Speaker Systems
