Jikkjack's DIY Horizontal Masking Documentation - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By jikkjack
post #1 of 14 Old 01-22-2010, 09:47 AM - Thread Starter
jikkjack's Avatar
As promised - here is the documentation for my DIY IR Controlled Masking System. I am happy to answer any questions and make updates to the documentation on request. I will update the version number as updates to the documentation are made.
DIYMaskingSystem.pdf 452k .pdf file
Open:
Closed:
And Video...
dabsabre and Mikkle like this.
jikkjack is offline
post #2 of 14 Old 01-22-2010, 10:04 AM
Jive Turkey's Avatar
Quoted: 216 Post(s)
Liked: 135
Putting that instruction PDF together for others is admirable. Thanks for taking the time and effort.
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is offline
post #3 of 14 Old 01-22-2010, 11:48 AM
adammb's Avatar
Quoted: 20 Post(s)
AWESOME!!!!!!! Will this transfer to a CIH version? I really would like some info on how you did this and am very impressed.
Adam
My Theater build
Ribbed for your pleasure
adammb is offline
post #4 of 14 Old 01-22-2010, 11:50 AM
BritInVA's Avatar
Thanks Jason - bookmarked for HT MKII (when ever that is).
Be good to add links to where you got the parts.
What was the final cost?
Great Job,
Mark
BritInVA is offline
post #5 of 14 Old 01-22-2010, 12:00 PM - Thread Starter
jikkjack's Avatar
Thanks Mark. Final cost was about 300 dollars and most of the parts came from av-outlet.com.
Thanks adammb. I don't see why not. Check out this thread from another forum member ScottJ007. He has a solution for 4 way masking that is very nice. He used a different motor configuration but other than that - some of the design elements are similar.
http://www.avsforum.com/avs-vb/showthread.php?t=941076
jikkjack is offline
post #6 of 14 Old 01-22-2010, 12:17 PM
jjmj427's Avatar
That is Phenomenal! Good job, I was always wanting to do a masking system but wasn't quite sure how to go about it.
cheers,
JJ
Number of trips to the Hardware Store: Can't count that high!
Sunbeam Cinema Build Thread
jjmj427 is offline
post #7 of 14 Old 02-06-2010, 01:28 PM
CIR-Engineering's Avatar
That is really nice. I am checking out your PDF now. Thanks for all the info
craigr
Precision Video Calibration Craig Rounds
JETI Specbos 1211 Spectroradiometer
Klein K10-A Laboratory Grade Colorimeter
Murideo Fresco Six-G & Six-A HDMI 2.x Multimedia Generator / Analyzer
LightSpace XPS Pro & ChromaPure Pro Color Calibration Software
www.CIR-Engineering.com - craigr@cir-engineering.com
CIR-Engineering is offline
post #8 of 14 Old 02-06-2010, 04:11 PM
Quoted: 216 Post(s)
Liked: 135
May I suggest that you also post this in the DIY subsection of the Screens forum? A lot of folks do searches for masking there.
Nice job.
See ya. Dave
post #9 of 14 Old 02-26-2010, 07:26 AM
ndfi's Avatar
That is awesome!
ndfi is offline
post #10 of 14 Old 02-26-2010, 11:32 AM
docprego's Avatar
That is simply genius. My new HT build thread is focusing on (among other things) building a screen with motorized remote controlled integrated masking. A recent post in my thread linked me to your PDF instructions and I was blown away. I do not plan on building a false wall, do you think I could still incorporate your system into a DIY screen only? I realize the frame for the screen will be bulkier than a simple screen only frame, but that's more than acceptable.
One question about the remote controlling of it, from what I gathered the motor allows you to set 3 pre-determined stop points; top, bottom, and a custom one. Does it also allow you to move the masks to any position you desire up or down without programmed stops. What I mean is does it allow control of the motor up and down when a button is held until it's at the right position?
Thanks again for sharing all of your hard work and experimentation, it is a huge help to those of us that would like to follow in your footsteps!
My Ridiculously Inexpensive Dedicated Kick *** Home Theaters!
RIDKAHT <The Original>
RIDKAHT <<The Sequel>>
RIDKAHT <<<Part III>>>
docprego is offline
post #11 of 14 Old 11-11-2010, 08:04 AM - Thread Starter
jikkjack's Avatar
Thanks guys...sorry for the delay in responding.
The feature you are describing is absolutely possible. It is a jog feature. You can jog the masks up and down in small increments.
jikkjack is offline
post #12 of 14 Old 03-09-2013, 03:14 AM
iguder's Avatar
Hi, I'm new to this forum, and I'm not sure i know my way aroun here yet - I know this an old posting, but that PDF that is mentioned in this post, where do I find that ?
Awesome job, I've been looking for someting like this, that is affordable and build-able.smile.gif
iguder is offline
post #13 of 14 Old 11-26-2013, 08:12 PM
naperthrill's Avatar
I apologize, but I don't see the pdf?
naperthrill is offline
post #14 of 14 Old 05-19-2015, 09:14 AM
HTownTheater's Avatar
Quoted: 23 Post(s)
Big thank you for putting the PDF together as well as the build thread!
I'm curious what your local source for the 1-1/4" metal tube was? I need 117" for my screen and avoutlet has up to 105" it looks like.
HTownTheater is offline
