Silverwood Cinema Build Thread - AVS Forum | Home Theater Discussions And Reviews
Old 02-14-2010, 12:24 AM - Thread Starter
boomergt's Avatar
My wife and I built a home in the Twin Cities which we left the basement unfinished. I decided to build a HT after going through this forum seeing all the very nice setups.
The room will be 16’x11.5’x8’
Construction began in November and has slowed down due to my wife and I having baby girl..
So far I have completed the framing, electrical, Low voltage and stage. I have HAVC being put in on Monday. We will be doing two supplies and one return. I will finish the riser, put up some insulation and run a couple cat5e runs to the rack.
Let me know what you thing and any advise will be great.. Thanks!
I will be running a Lutron spacer system with 2 zones. I will also have a switched outlet for a rope light.
Here is the outline of the room
Space
I am planning on having a 104" screen
Room framed
Stage which is now filled with sand
Riser - I used 2x6s due to city stating the max height of the riser could only be 7.75" once finished.
At framing inspection the inspector said it would not matter.. So I filled it with insulation and put a second layer of 3/4" plywood on top..
The back corner of the room has a sharp angle to it. I built this out and I am having a custom cabinet built for DVD storage.
I had a 2post rack sitting around that I put into one of the walls. I will only have 20 U's showing in the end. This should be nice having the back of the components in the Mech. room. The rack will has its own 20amp circuit.
I wired two outlets into the riser for power recliners. I also wired another 1gang box that will be used for a 1gang light (Pass & Seymour hallway light with sensor TMHWLECC).
I have wired 4 4" recessed lights and 5 sconces
Low voltage is finished. I did run 2" PVC from the projector LV box to the rack.
This is what I am looking to do with the screen wall.
boomergt is offline
Old 02-14-2010, 03:37 AM
Adidas4275's Avatar
looks like a great space..... nice work so far. are the speakers going to be behind fabric or visible?
Adidas4275 is offline
Old 02-14-2010, 09:17 AM - Thread Starter
boomergt's Avatar
I plan to have them hidden behind fabric panels.
boomergt is offline
Old 02-16-2010, 09:22 PM - Thread Starter
boomergt's Avatar
I had the HVAC finished on Monday and the inspection is on Thursday. Once inspection is completed I am going to insulate the rest of the walls and ceilings.
Riser filled with Insulation
Riser capped
Back wall filled with insulation
boomergt is offline
Old 02-18-2010, 08:38 PM - Thread Starter
boomergt's Avatar
I started to put up insulation. I hope to have the walls finished this weekend.
boomergt is offline
Old 03-04-2010, 10:22 PM - Thread Starter
boomergt's Avatar
I now have the room fully insulated and ready to be sheetrocked.
I am going to start the sheetrock this weekend.
boomergt is offline
Old 03-04-2010, 11:19 PM
Remax's Avatar
How do you keep your room so clean while you work?
Remax is offline
Old 03-05-2010, 04:57 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 100
shop vac?
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
Old 03-05-2010, 09:32 AM - Thread Starter
boomergt's Avatar
I have been cleaning the room after each phase.. My wife has been going down also and sweeping.
boomergt is offline
Old 03-05-2010, 02:03 PM
rpyles's Avatar
Nice! I'm just starting my demo right now. I'm planning on running conduit myself. Is 2" enough?
rpyles is offline
Old 03-05-2010, 06:18 PM - Thread Starter
boomergt's Avatar
For me 2" should be plenty. I only have a hdmi cable ran. But if needed I should have no problem fitting a DVI, component and should have plenty of room to spare.
boomergt is offline
Old 03-05-2010, 06:52 PM
Big Worms's Avatar
Very nice start!
.: Ernie :.
Big Worms is offline
Old 03-06-2010, 12:31 AM - Thread Starter
boomergt's Avatar
Started the sheetrock today.
boomergt is offline
Old 03-10-2010, 11:16 PM - Thread Starter
boomergt's Avatar
I have finished putting the sheetrock up on the ceiling.
boomergt is offline
Old 03-13-2010, 10:59 AM - Thread Starter
boomergt's Avatar
I have started getting the sheetrock on the walls.. Hopefully I can continue working on it this weekend.
boomergt is offline
Old 03-21-2010, 10:16 PM - Thread Starter
boomergt's Avatar
I was able to get some more rock put up this weekend. Hopefully I can get the sheetrocking finished this week.
boomergt is offline
Old 03-28-2010, 09:04 PM - Thread Starter
boomergt's Avatar
Well I did not get the sheetrock finished but I did make some progress. I have one sheet left for the room then I need to rock the outside of the door. The the inspection.
The rack
boomergt is offline
Old 04-06-2010, 09:34 PM - Thread Starter
boomergt's Avatar
I have finally finished putting up all the sheetrock. I have an inspection tomorrow morning. Then starts the taping...
boomergt is offline
Old 04-06-2010, 09:44 PM
malovich's Avatar
a few short comments, what was your reasoning for not having sound isolation of any means? those surround locations will be really close to peoples ears. the triangular odd section would make an excellent bass trap. I wish you luck and enjoyment in your theater!
XBL Krimzen Rage
malovich is offline
Old 04-07-2010, 07:04 PM
ChiefJC's Avatar
Making some good progress man, keep up the good work. I start frameing this weekend on my build!!, what equipment are you plannng for Pj and Screen? 16:9 or 2:35:1?
__________________
Jeremy
My HT build here.
Louisville Kentucky Services
Phone Systems
Cabling
ChiefJC is offline
Old 04-18-2010, 09:01 AM
Zivman's Avatar
Quoted: 93 Post(s)
Liked: 62
what you are looking at will be sconces for lighting. the surrounds will be up closer to the ceiling. Look for the oragne low voltage boxes on the ceiling.
As far as sound isolation... we really didn't look into a ton, and felt unless the equipment was very top of the line, the difference it would make would not be noticed by the average person. Also, the odd shape of the room made it hard research how to do it properly.
Any suggestions on it would be appreciated though. We have thought about putting base traps on each corner of the stage area. Any thoughts on that?
Zivman is offline
Old 04-18-2010, 09:03 AM
Zivman's Avatar
Quoted: 93 Post(s)
Liked: 62
projector he is looking at AE3000.
Think he is leaning towards a fixed 2.35:1 screen
Zivman is offline
Old 04-18-2010, 04:19 PM - Thread Starter
boomergt's Avatar
Actually the PT-AE4000U. As Zivman said I am probably getting the 2.35.1 screen.
boomergt is offline
Old 04-24-2010, 09:47 PM - Thread Starter
boomergt's Avatar
We started mudding today.. We almost have the first coat on..
boomergt is offline
Old 05-15-2010, 09:48 AM - Thread Starter
boomergt's Avatar
Last coat of mud went on last night.. Just some sanding then to primer and paint.
boomergt is offline
Old 06-20-2010, 01:34 PM - Thread Starter
boomergt's Avatar
Finally was able to spend some time to get a couple coats of primer on the walls.. I also got two coats of paint on the ceiling and the screen wall.
I plan to get the other wall painted this week.
boomergt is offline
Old 11-16-2010, 11:35 PM - Thread Starter
boomergt's Avatar
Well it has been a while since I posted any updates.. I have been slowly moving forward on the room.. I have finished painting the room and most of the trim has been put up in these photos.
boomergt is offline
Old 11-16-2010, 11:37 PM - Thread Starter
boomergt's Avatar
The custom cabinet has been installed. The rack will be framed out like the cabinet trim
boomergt is offline
Old 11-16-2010, 11:43 PM - Thread Starter
boomergt's Avatar
The trim is finished, Door is installed, carpet is installed. I have the final room inspection on Monday. I will be ordering the screen next. Also the rack trim out is in the process also.
boomergt is offline
Old 11-17-2010, 02:54 AM
Digital_Chris's Avatar
Wow, everything is looking great so far and done so dang quickly! I can't wait to get started on mine!
Digital_Chris is offline
