The Uniplex Build - AVS Forum | Home Theater Discussions And Reviews
Old 02-23-2010, 10:31 PM - Thread Starter
Chris Dias's Avatar
Hi Everyone,
I've been lurking on this thread for 10 years now and I've used it for some great advice to build up all the equipment for my Home Theatre. Well I bought my first house recently and I've finally got the room to build the theatre that my equipment deserves. I've really enjoyed going though lot sand lots of build threads here so I thought I'd start my own, because I'm sure I will have some questions as I go. I'll start with my Sketchup drawing:
The basement is already finished, but I will be adding a wall to divide it up.
So far I've already built the in wall rack and put up the framing for one of the walls. I will add pictures as soon as I can find the usb cable for my camera.
Here is an x-ray drawing showing the speakers behind the screen ( I will probably be going with the Seymour screen material:
Thanks in advance for the questions I'm sure you'll help me with. I'll be updating this thread regularly.
Chris
Chris Dias is offline
Old 03-02-2010, 09:57 PM - Thread Starter
Chris Dias's Avatar
Ok so I finally found my USB cable so here are some pics.
First a few shots of the space:
Here are my speakers and seats shoved off to the side during the construction:
Old 03-02-2010, 10:01 PM - Thread Starter
Chris Dias's Avatar
Here is the rack that I already built a few months ago:
Here's the back. I know, I've still got some cable tidying to do:
Old 03-02-2010, 10:06 PM - Thread Starter
Chris Dias's Avatar
All taped up:
My New toy:
Started the framing:
Old 03-02-2010, 10:13 PM - Thread Starter
Chris Dias's Avatar
And here is where I got to tonight:
So far so good.
Old 03-03-2010, 07:42 AM
mikieson's Avatar
WOW...I LOVELOVELOVE Your Pioneer receiver!!..mmmm.mmmm.. I also really like how your stage is turning out. Looking good!
mikieson is offline
Old 03-03-2010, 08:05 AM
Big Worms's Avatar
Looks like a good start.
What is your ceiling height that you have 3 rows planned?
.: Ernie :.
Big Worms is offline
Old 03-03-2010, 10:41 AM
hanesian's Avatar
Quoted: 36 Post(s)
Liked: 82
Woah! After a decade of lurking you probably know more than most. Looks like a nice space and plan. And very nice job on the rack!
Couple of quick questions for you:
What are you putting at the back of the room behind your riser? Is that the extra space for when everyone lines up all at once to refill their popcorn tubs? Or are you planning the door and/or other stuff at the back of the room?
What are your distances to your first/other rows? That first row in particular looks awfully close from the sketchup.
Finally, if you ever want to finish this - take down that PJ now!!
Good luck - subscribed!
The Un-Theater Un-Build
hanesian is offline
Old 03-03-2010, 04:30 PM
tjambro's Avatar
Now that you started, I bet your basement feels small. I know mine does.
I really chimed in because I like the name of your theater...check my sig.
tjambro is offline
Old 03-03-2010, 07:27 PM - Thread Starter
Chris Dias's Avatar
Yeah my first serious receiver was a Pioneer Elite vsx-27 10 years ago. Then a few years back, I replaced it with an Onkyo 805, but I missed the Pioneer so I sold that and got this Pioneer 07. I'm very happy with it.
Well that's where it is going to get a bit close. It 7.5 feet, so no tall people in the back row. Luckily my wife and I are both quite short. But I will definitely be telling people to mind their heads
Well my next project will be to build a Mame cabinet, so that will go at the back there. Also, you can't really tell from the Sketchup drawing, but back there will be walled off with a door added.
Yeah the first row is a bit close, but the problem is that pillar on the right wall behind the second row. the second row has to go right in front of it because if I put it beside it, there is no room to walk by. So leaving room for them to recline, pushes the front row up. I don't mind though, I like sitting close. That's what I do at the movies too.
Yeah The name came out of my disdain for all the new Multiplexes that opened up in Toronto while they closed down the best theatres in town. (The Uptown, The Eglinton, and the York for those from Toronto). It was between Uniplex or Monoplex.
Old 03-03-2010, 07:30 PM - Thread Starter
Chris Dias's Avatar
Here a picture of the carpet that I will most likely be going with along with some paint samples that I still haven't settled on yet for the walls:
And here is my cat, who has taken to sleeping on the sample all the time:
Old 03-06-2010, 07:49 PM - Thread Starter
Chris Dias's Avatar
Should I insulate the partition wall? I am not concerned with soundproofing the room, but will not insulating it cause any sound issues within the room?
Chris
Old 03-07-2010, 12:08 PM
jamis's Avatar
Chris
We insulated all walls even though we didn't have to. It's not vary expensive and it's better to have no noticeable effect than possibly regret it later.
jamis is offline
Old 12-15-2010, 08:04 PM - Thread Starter
Chris Dias's Avatar
Well folks, it's been a long time. I've been plugging away here and there in the summer, but had a large break when a leak was found in my foundation. I finally got that repaired in October. I'll post some more pics of where I am now. I'm very close to being done.
Old 12-15-2010, 08:06 PM - Thread Starter
Chris Dias's Avatar
Old 12-15-2010, 08:08 PM - Thread Starter
Chris Dias's Avatar
Old 12-15-2010, 08:11 PM - Thread Starter
Chris Dias's Avatar
Here is the media shelf being made:
I built the back in pieces so that there would be no visible brackets in the shelf, yet it would be strong enough to support the weight of everything without bowing.
Old 12-15-2010, 08:13 PM - Thread Starter
Chris Dias's Avatar
Old 12-15-2010, 08:16 PM - Thread Starter
Chris Dias's Avatar
I closed in the windows:
Old 12-15-2010, 08:17 PM - Thread Starter
Chris Dias's Avatar
Here it is painted:
Old 12-15-2010, 08:19 PM - Thread Starter
Chris Dias's Avatar
Old 12-15-2010, 08:21 PM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
Now that's a riser!! How tall is the first riser? Short enough for no step I'm assuming?
Would it be too difficult to modify the second riser in the area of the step? I'm thinking that area might be easier to negotiate if the lower riser swept around the corner and became the step to the upper riser, instead of having the little extension separating the step from the lower riser. Based on your framing, it seems like it would be fairly easy to cut off the extension. Just a thought.
Spaceman is offline
Old 12-15-2010, 08:22 PM - Thread Starter
Chris Dias's Avatar
Old 01-01-2011, 11:47 AM - Thread Starter
Chris Dias's Avatar
Hi Spaceman,
I didn't see your post because you snuck it in while I was still posting pics. The riser is about 10 inches which is slightly above a regular step but good enough to be able to step up to it. And thanks for the suggestion, I debated about how to make that second step for a while, but in the end I like it the way it is, I wanted it to be a deliberate, separate step.
I check out your build thread, It is looking good, but hasn't been updated in a while, how is it going? I see you got Atlantic Technology Speakers. I've had some (System 450THX) for about 10 years now and still love them. I'm actually looking for 2 more surrounds to put at the back.
Chris
Old 04-15-2011, 05:15 PM - Thread Starter
Chris Dias's Avatar
So I made a secret bookcase door. Here are some pics.
Old 04-15-2011, 05:17 PM - Thread Starter
Chris Dias's Avatar
A book can be slid onto that bracket so when it is pulled down, the door opens:
Old 04-15-2011, 05:19 PM - Thread Starter
Chris Dias's Avatar
This is from the inside
Old 04-15-2011, 05:23 PM - Thread Starter
Chris Dias's Avatar
Here it is with the carpet and speakers installed:
Old 04-15-2011, 05:29 PM - Thread Starter
Chris Dias's Avatar
I picked up these in walls for the rears:
Old 04-15-2011, 05:49 PM
hanesian's Avatar
Quoted: 36 Post(s)
Liked: 82
Wow - that's a lotta red! And are you keeping the ceiling ultra reflective white?
Cool door!
hanesian is offline
