Are bass traps all created equal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 03-18-2010, 05:03 PM - Thread Starter
bond_007's Avatar
Are they all made of the same material? I dont have much money, these looks like a cost efficient deal. Great reviews! thanks
http://cgi.ebay.com/Soundproofing-Fo...item563a9ccb66
bond_007 is offline
post #2 of 15 Old 03-18-2010, 05:46 PM
Stereodude's Avatar
Quoted: 3454 Post(s)
Liked: 2526
Your link doesn't work.
Stereodude is online now
post #3 of 15 Old 03-18-2010, 06:28 PM - Thread Starter
bond_007's Avatar
bond_007 is offline
post #4 of 15 Old 03-18-2010, 06:45 PM
Stereodude's Avatar
Liked: 2526
Eh... Use some OC703 or OC705 instead.
post #5 of 15 Old 03-19-2010, 09:34 AM
marklabelle870's Avatar
Quoted: 17 Post(s)
Liked: 32
Search Super Chunk or OC703 traps. I bought some for about $100 USD and cut them into 17x17x24" triangles (you'll get 9 per 2" sheet of OC703) and then covered them with speaker cloth from Joanne's Fabric for about $20.00.
Amazing difference in the sound!
marklabelle870 is offline
post #6 of 15 Old 03-19-2010, 01:12 PM
Remax's Avatar
Definitely use oc703 instead.
Remax is offline
post #7 of 15 Old 03-19-2010, 02:41 PM
Ethan Winer's Avatar
Quoted: 267 Post(s)
Liked: 363
Thanks for moving this to the public forum. You already got the right answer, but I can add a bit more: That foam is not acoustic foam, and the data they show is fraudulent. The data shows it as being very similar to an Auralex LENRD foam corner, which itself is not as good as more standard materials such as rigid fiberglass in a 2x4 foot size. But when I measured that brand of corner foam in a lab it absorbed far less than claimed, as you can see in the graph below. (SOURCE)
--Ethan
Ethan Winer is offline
post #8 of 15 Old 03-19-2010, 05:17 PM
mscott's Avatar
Wow, how's that for free quantitative advice?? Amazing resources here. Thanks Ethan.
As someone who has 703 installed -- +1 on the superchunk method. Easy and cheap relative to other methods.
mscott is offline
post #9 of 15 Old 03-20-2010, 12:29 PM - Thread Starter
bond_007's Avatar
Wow Ethan thats a serious answer, your a true professional! ill check out the recommend bass traps thanks
bond_007 is offline
post #10 of 15 Old 03-20-2010, 12:33 PM - Thread Starter
bond_007's Avatar
i want something pre made, space it a concer thats why i wanted corner wedge style
bond_007 is offline
post #11 of 15 Old 03-20-2010, 01:14 PM
Quoted: 17 Post(s)
Liked: 32
For the price of that pre-made one - I'll cut up the OC703 and wrap it with GOM 5 times over.
Let me know where you live and I'll ship it to you.
BTW the superchunk OC703 traps are "corner wedge style". Check it out - and there's a video: http://www.avsforum.com/avs-vb/showthread.php?t=700442
All you need is a stapler and a handsaw or a long knife.
post #12 of 15 Old 03-20-2010, 02:46 PM - Thread Starter
bond_007's Avatar
im down for that now i need like 6-8 wedges but was those cut in half would work i want to treat the ceiling corners as well
bond_007 is offline
post #13 of 15 Old 03-20-2010, 02:52 PM - Thread Starter
bond_007's Avatar
bond_007 is offline
post #14 of 15 Old 03-21-2010, 10:59 AM
Quoted: 17 Post(s)
Liked: 32
what about these?
http://cgi.ebay.com/Dark-Charcoal-Ac...item3cab3fdf5d
None of those are going to get even close to what the superchunks would get you to. You need ping Bpape or check out some his threads.
post #15 of 15 Old 03-21-2010, 01:23 PM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 111
Bond ....
What about? What about? What about? All of the "what about's" can go on forever. Chat, talk to, email Bpape, or Ethan and get real information and products that actually work.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Chairman
www.erskine-group.com
Dennis Erskine is offline
