Screen wall cover up panel help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-23-2010, 03:38 PM - Thread Starter
RossMc's Avatar
I've built a very minimal screen wall and now need to build the fabric cover up panels to hide the speakers etc. However, I'm having a very hard time making the frames.
What would do people normally use for this? I am trying to use 1.5 x.75 mdf strips, but I don't think they will have good enough holding power in the corners.
Any tips, it seems tough since they have to be narrow and thin.
RossMc is offline
post #2 of 6 Old 04-23-2010, 04:19 PM
eskay's Avatar
I used 1"x3" poplar screwed together with pocket screws.
www.kregtool.com
Lowes has a small Kreg kit and the pocket screws. Add a corner clamp and you'll be all set to make strong joints.
eskay is online now
post #3 of 6 Old 04-23-2010, 04:32 PM
Mr.Poindexter's Avatar
Quoted: 20 Post(s)
Liked: 29
You can make them on plywood or other wood frames and then use a brad gun to attach them. You won't see the brad nail head once they are in place.
Mr.Poindexter is offline
post #4 of 6 Old 04-23-2010, 04:38 PM
DJWikiera's Avatar
Read through this thread. Very detailed on how one member constructed his fabric panels.
DJWikiera is offline
post #5 of 6 Old 04-23-2010, 04:50 PM
Quoted: 3265 Post(s)
Liked: 2751
I built my frames with the Pre-Primed finger joined pine exterior trim boards, I usually ripped the bigger boards down to about 1 1/4 x 2 1/2 or so but I used various sizes.
post #6 of 6 Old 04-23-2010, 09:49 PM - Thread Starter
RossMc's Avatar
Thanks all for the tips and the pics. BigmouthinDC. I used your wall as a reference for building my screen wall, so the pics help. I don't think I have the ability to do the finger joints though, so I may just try to get the pocket jig tomorrow and scrap the mdf pieces I wanted to use.
RossMc is offline
