I find GOM to be ugly... what are my other choices? - AVS Forum | Home Theater Discussions And Reviews
Old 04-25-2010, 06:49 PM - Thread Starter
scooter_29's Avatar
Quoted: 28 Post(s)
Is it me or is GOM ugly? All of the samples I have seen remind me of a cube farm at a big company. I just really don't like its texture.
In any event, what other choices do I have? I will be covering floor to ceiling bass traps and some high frequency absorption panels in an alcove roughly 8'X6'.
scooter_29 is offline
Old 04-25-2010, 07:27 PM
SierraMikeBravo's Avatar
Quoted: 276 Post(s)
Liked: 177
Guilford makes numerous types of panel fabric. 701 is just one type. I personally like anchorage. Otherwise, as long as the material is acoustically transparent, its fine to use. Just do some testing on it.
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Design Information
skbyrne@sbcglobal.net
SierraMikeBravo is online now
Old 04-25-2010, 07:40 PM
Remax's Avatar
I used dazian and love it. I believe the kind I used was called Janus which is fire retardant and acoustically transparent. Prices are much cheaper than GOM too.
Remax is offline
Old 04-25-2010, 10:28 PM
Mr.Poindexter's Avatar
Liked: 29
I agree that the FR701 looks like a cubical covering - VERY ugly (IMO). I used Anchorage Midnight for my theater's main color and Streetwise Asphalt for the black as the Streetwise has a pattern in it that keeps the fabric from looking plain.
I would guess there are a ton of people who use Anchorage for their theaters. I think Art Sonneborn's is Anchorage Mulberry. I know he uses Streetwise Asphalt for the black in his theater.
Mr.Poindexter is offline
Old 04-26-2010, 06:41 AM - Thread Starter
scooter_29's Avatar
Quoted: 28 Post(s)
Thanks everyone! I was under the impression the only acoustic solution from GOM was 701. Both the Anchorage and Streetwise series will be perfect.
Old 04-26-2010, 08:01 AM
Dixon's Avatar
If you are putting speakers behind it, make sure you test it.
The anchorage is definitely a nicer looking fabric, but in my experience it isn't as transparent as the 701 and it seemed to really clip my highs. I didn't love the burlap look of the 701 black sample, but I must say that once I had it on my panels themselves, it took on a much sleeker, nicer look. Now that my panels are in place they don't look like burlap any more.
If I were just doing panels with no speakers behind them, I'd go with anchorage. If using speakers, I'd go with 701 (Danzien may also work well--I actually preferred the 701, as the Danzian sample I received was a little shiny for me-- but it is all just personal preference).
Dixon is offline
Old 04-26-2010, 08:41 AM
Mr. Goodcat's Avatar
I use stretch velvet on mine. An idea I credit to McCall! Works great, great looking, although not fire retardant, it is very AT and available in a wide variety of colors. Plus being stretchy it's damn easy to work with!
Mr. Goodcat is offline
Old 04-26-2010, 09:25 AM
msmCutter's Avatar
Send a message via AIM to msmCutter Send a message via Skype™ to msmCutter
You really think the stretch velvet is AT?
msmCutter is offline
Old 04-26-2010, 09:35 AM
Terry Montlick's Avatar
Location: State of Rhode Island and Providence Plantations
Anchorage looks nice, but acoustical transparency-wise, it's not great. The worst of all GOM fabric Carrara - gorgeous, but is really the pits acoustically.
This mean not that it won't work, but that you need equivalently a lot more treatment area to get the same effect as a more transparent fabric. Basically, it is reflecting most of the sound at around 2 kHz and above so it can't be absorbed by the fiberglass behind it. I don't think Streetwise is sold anymore, so I scrapped my acoustical test data for it.
- Terry
Terry Montlick Laboratories
Home Theater Acoustics
Critical Listening Rooms
Design, Evaluation, Alpha Certification®
www.tmlaboratories.com
Terry Montlick is offline
Old 04-26-2010, 10:14 AM
McCall did a bunch of studying on itas well. When stretched you can damn near see through it., it becomes that thin. Have you ever played around with it? If you did you might feel differently.
Old 04-26-2010, 10:18 AM
msmCutter's Avatar
I'm not saying it's not, I'm honestly asking. I want stuff that blocks tons of light but doesn't reflect sound so much. I'll have insulation to absorb the sound. Of course, if the fabric gobbled sound (not reflected it) I'd be okay with that too
Old 04-26-2010, 10:23 AM
Fabric, unless it is VERY thick, doesn't absorb sound.
Old 04-26-2010, 10:31 AM
Liked: 29
Old 04-26-2010, 10:49 AM
Oh..I misread it in the form of sarcasm. That's my bad.
It would not block light at all. If you want to block light just get a light blocking shade
Old 04-26-2010, 11:10 AM
Liked: 29
Maybe he meant absorb light as opposed to reflecting it. If there is insulation behind the fabric, why would it need to block light as there would be little light that is going to pass through even 1/2" of insulshield.
Old 04-26-2010, 11:39 AM
At this point I am just confused!!!
Old 04-26-2010, 11:46 AM
Liked: 29
Old 04-26-2010, 01:15 PM - Thread Starter
scooter_29's Avatar
Quoted: 28 Post(s)
- Terry
What would you recommend then besides 701? The panels I am most concerned about are meant to absorb mid/high freqs in the alcove. From your comment, it doesn't sound like Anchorage is the way to go.
Old 04-26-2010, 01:30 PM
msmCutter's Avatar
Sorry lads! What I'm trying to say is I don't want the fabric to reflect light. I don't want it block light either. I'd really like it to absorb light/cover up whatever color the underlying sound absorbent material I use.
The only real light in the room is coming indirectly from a projector. Black velvet not stretched too thin sounds like it would do a great job of soaking up the errant light.
Old 04-26-2010, 02:59 PM
Okay, back on track now. I use stretch velvet on the sides of my screen as well, that way any light spillage will be soaked up. I can say anything about the cover up as under it is black linacoustic.
Old 04-26-2010, 08:53 PM - Thread Starter
scooter_29's Avatar
Quoted: 28 Post(s)
Now that my thread has been hijacked, can we please get back to my original question. Terry has pointed out that Anchorage doesn't perform as well as 701, especially for mid/high frequency absorption. So what are the alternatives? (And please start your own thread if you want to talk about the light reflection of velvet).
Old 04-27-2010, 08:22 AM
msmCutter's Avatar
It's the same topic bro. We're discussing it as better looking fabric to cover sound aborbing material.
Old 04-27-2010, 08:34 AM
The following is a limited list of other Guilford fabrics well suited acoustically for acoustic panels:
Hopscotch 2813
Lido 2858
Venesia 3575
VSB 2145
VSS 2402
Wilshire 2735
Auster 2537
Bailey 2299
Cordial 4055
Spinel 3582
BTW Jo-Ann burlap is acoustically transparent enough for speaker cloth usage!
Old 04-27-2010, 08:57 AM - Thread Starter
scooter_29's Avatar
Quoted: 28 Post(s)
Thanks Terry for the list. Many in there are a lot more presentable than 701.
Old 04-28-2010, 10:52 AM
DMF
DMF's Avatar
701 isn't as bad as you might think from the samples. Just get a color as close as possible to the surrounding wall color and the panel will almost disappear. Perhaps you're tending to think of it as a decorative accessory. It's not.
No matter where you go. ... There you are.
DMF is offline
Old 04-29-2010, 02:18 PM
Quoted: 3027 Post(s)
Liked: 2545
701 all around in my space.
Old 04-29-2010, 03:17 PM
GPowers's Avatar
Quoted: 37 Post(s)
Liked: 46
Thats because GOM is used by a lot of manufactures of cubicles.
GPowers is offline
