recessed lighting size - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 04-26-2010, 10:24 AM - Thread Starter
twinkiestar's Avatar
I am finishing a dedicated HT room, relative small room 17x12.5, I have a tray ceiling/soffit about 2 ft wide, wonder what size of recessed light would look good on my environment..
here are some dimensions:
the ceiling is 8'11" while the tray is 7'9" tall
plan to build a 10 inch riser near the back of the room.
should I use 4" or 6" cans?
twinkiestar is offline
post #2 of 19 Old 04-26-2010, 01:25 PM
sathyakamaraj's Avatar
I feel 6" is too big...just my word..i am in da learning stage also..
I am planning to put 3" recessed lighting like some other people in the forum ( which I really liked it )...15X18 room size..
Live till die
sathyakamaraj is offline
post #3 of 19 Old 04-26-2010, 01:29 PM
http://www.avsforum.com/avs-vb/showt...essed+lighting
this thread can help you too..
Live till die
post #4 of 19 Old 04-28-2010, 10:57 AM
DMF
DMF's Avatar
Definitely not 6". Use 4" or even 3". I gather they all have to go in the 2' space around the tray?
No matter where you go. ... There you are.
DMF is offline
post #5 of 19 Old 04-28-2010, 11:18 AM - Thread Starter
yes. they are all in the 2' tray. agree 4" looks good,
now my next challenge is the 4" IC cans are still too bulky and it doesn't fit on one side of the tray as there is drain pipe occupying half of the 2' tray width.. so if I use the non-IC cans (smaller), I'll not be able to put the fiberglass insulation - how would I then fill the cavity then (otherwise, would there be resonance due to the hollow tray?)
thanks.
post #6 of 19 Old 04-28-2010, 12:21 PM
budk's Avatar
I have 4" cans in my room and I think they are perfectly sized for a small theater.
Bud
There is a solution to every problem.
2nd Run Cinema - A fabric frame theater
budk is offline
post #7 of 19 Old 04-28-2010, 03:54 PM
Tedd's Avatar
Quoted: 926 Post(s)
Liked: 339
Couldn't have said it better myself!
Tedd is offline
post #8 of 19 Old 04-28-2010, 04:33 PM
rto
rto's Avatar
The best thing about a 4" can, is the fact that you don't have to pay the ridiculous premium for low-voltage IC fixtures.
rto is offline
post #9 of 19 Old 04-29-2010, 06:28 AM
jelloslug's Avatar
I'm using 3" cans in my soffit. They were $10 each including the bulb.
jelloslug is offline
post #10 of 19 Old 04-30-2010, 02:08 PM
DMF
DMF's Avatar
Fill the parts between the cans. Or leave it out. If there is structural resonance, loose insulation isn't going to do much in the way of damping anyway.
DMF is offline
post #11 of 19 Old 04-30-2010, 02:14 PM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
It's perhaps not so much structural resonance as air cavity resonance. Anything sealed and hollow should have some absorption inside.
__________________
Ted
The Soundproofing Company
Ted White is offline
post #12 of 19 Old 04-30-2010, 02:18 PM
HT_SoulMan's Avatar
Will be using 3" cans for the soffit and 4" in the ceiling for the screen wash.
HT_SoulMan is offline
post #13 of 19 Old 04-30-2010, 02:22 PM
Johnsteph10's Avatar
Quoted: 31 Post(s)
I used 4 inch IC cans in my soffit which is 16 inches wide and they fit perfectly.
John
Johnsteph10 is offline
post #14 of 19 Old 05-02-2010, 09:38 AM
SinisterJ's Avatar
4" IC Halo Cans in 18" Soffit works perfect USA Lighting trims if your looking for black trims they fit Halo Cans
My (Old) Theater Build Thread
Samsung UN75-F6400 | Denon 2313CI | Def Tech BP8060 | Def Tech CS8060 | Def Tech SR8080 | Sony VPL-HW40-ES | 120" Elite Starling Tensioned
SinisterJ is offline
post #15 of 19 Old 05-02-2010, 10:51 AM
Drew_V's Avatar
Can someone tell me why people put lights above their screens? Is it just for looks?
I don't have any above mine, but I wonder why would I need them at all?
--Drew
My basement theater build thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1243820
Started: 2/20/10
Completed: 10/10/10
Drew_V is offline
post #16 of 19 Old 05-02-2010, 11:56 AM
jelloslug's Avatar
Looks.
post #17 of 19 Old 05-02-2010, 12:08 PM
Quoted: 31 Post(s)
I put lights behind my AT screen to illuminate my speakers a la Imax style....
John
post #18 of 19 Old 05-06-2010, 02:58 PM
DMF
DMF's Avatar
I don't know of any fixtures that are sealed. For that matter, he could just leave some extra air gaps and call them resonators.
DMF is offline
post #19 of 19 Old 05-06-2010, 03:00 PM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
I was refering to the hollow areas within structures like a soffit. Not suggesting we fill our light fixtures with insulation.
__________________
Ted
