Where to get high quality short HDMI cables? - AVS Forum
post #1 of 6 Old 06-18-2010, 11:33 PM - Thread Starter
BrettB0727's Avatar
Hi All,
So I am looking for some high quality HDMI cables under 2 feet(preferable 1 ft) to compliments my high quality cables from Monoprice, this is what I have:
High Speed HDMI CL2 Rated (In-Wall Installation) Cable (22AWG) - 25ft (Gold Plated Connectors)
The closest thing I found is 4ft(http://www.monoprice.com/products/product.asp?p_id=4965), everything that is short is much lower quality.
Does anyone have any suggestion for somewhere else besides monoprice to get short cables?
Brett
BrettB0727 is offline
post #2 of 6 Old 06-18-2010, 11:42 PM
googlegod's Avatar
Originally Posted by BrettB0727 View Post
Hi All,
Brett
Why so short, there is no real plus side, between 4, 2 and 1ft. Each time its plugged into a unit the signaling is EQed so it not really like adding all the lengths together for a grand total. Besides a 4ft good cable is way better than a so-so shorter one.
http://www.monoprice.com/products/su...&cs_id=1025101
googlegod is offline
post #3 of 6 Old 06-18-2010, 11:51 PM - Thread Starter
BrettB0727's Avatar
Ones is for behind the TV for example and just needs to go a few inches to the wall plate, and because I have a very low profile mount, I am concern that there won't be the space for 4 ft of cable to be stashed behind the TV.
Another is in a different location to connect a receiver to a wall plate, and it is a fairly visible location in when I don't really want to have 3 extra feet of cable coiled up.
post #4 of 6 Old 06-19-2010, 01:43 AM
Elill's Avatar
Another option is from this crowd....I use them, have for 6 years, very happy:
http://www.cablesandelectronics.com/...eo-cables.html
25 yr warranty, made in Germany
Peter the Greek
Downunder Theatre MkII
Redefining snail pace construction
Elill is online now
post #5 of 6 Old 06-19-2010, 09:53 PM
ChrisWiggles's Avatar
Why do you care? At lengths this short the "quality" of the cable stock is practically irrelevant. Just get a cable of the length you need. If there's a problem you'll know because it won't work.
That being said, if you cannot be dissuaded by facts and just want to be able to say you have the best, blue-jeans does offer their F2 bonded-pair cable in 1-foot increments starting at 1-foot. I would not recommend their better F2 cable (which starts at 3ft) because the cable is extremely large and not flexible, and would be a bad choice for such short lengths. And as far as cable stock, you won't find better anywhere. But again, hugely unecessary. I think I have a couple of their shorter bonded-pair cables simply because I was ordering other things at the same time so i included them in the order so as not to rack up spurios shipping charges. But otherwise there's no reason to spend more than a couple bucks on such short cables.
ChrisWiggles is offline
post #6 of 6 Old 06-21-2010, 10:40 AM - Thread Starter
BrettB0727's Avatar
Well at the very least, high speed and standard speed matters correct? I have been having a tough time finding even generic high speed rated short cable, not even taking into account the guage or anything else.
I'm have been concerned about the cable quality because I noticed a dramatic improvement going for just a generic 5ft cable I had laying to the large 25ft high speed cables, and I just wanted to be sure and not loose anything.
I'll take a look at the bluejean cables.
Brett
User Tag List
