Build log: DIY rotary sub for contemporary HT in 100 year old house? - Page 10 - AVS Forum | Home Theater Discussions And Reviews
Old 11-05-2010, 01:53 PM - Thread Starter
AndreasMergner's Avatar
Beemer, thanks for your suggestions. I was thinking that when I'm in HD in a bit, I'll be checking out the hardware section for anchors. One of them will work. If it expands at all past the steel, it will not be coming out!
Epoxy and cross drilling would work too, but an anchor will be much simpler.
I'm just resting my shoulders a bit before continuing.
Current HT: HTPC-->Epson 5010 projector-->135" screen, BFM TLAHs x7 & THT
Andreas' Slow Rotary Sub build
AndreasMergner is offline
Old 11-05-2010, 03:30 PM
Richard Cohen's Avatar
Quoted: 26 Post(s)
Liked: 37
Any chance that you can chisel out the wood filler beam just large enough to slip a nut in place for you to get a few bolt and nuts in?
Home Theater Forum - fun place and nice people
http://www.hometheaterlounge.com/forum.php
Richard Cohen is offline
Old 11-05-2010, 07:19 PM - Thread Starter
Richard: not a bad idea if I could be bothered! Anchors will do fine. These bolts are not holding the beam up. They are just there to prevent the support from being knocked out from under the beam. They are mostly for shear which I could accomplish by pins if I wanted....at least that is my understanding unless someone tells me otherwise.
Joist hangers are done!
I can't tell you how exhausting this was. I have had my arms over my head for days now! I'll take out the temp walls tomorrow after swapping the bolts out and getting up the nerve.
Old 11-05-2010, 07:37 PM
Beemer533's Avatar
It is amazing how only a few inches makes a difference.... Looking good!
I would say you are right as far as securing the posts to the beam; a pin would probably do the trick. Of course you would need to secure the pin somehow, so you might as well go with the expanding anchor.
On that note, how are you securing the posts to the floor?
Whiskey Tango Foxtrot, Over.....
Beemer533 is offline
Old 11-05-2010, 08:51 PM
Tedd's Avatar
Quoted: 930 Post(s)
Liked: 342
Do you have a welder?
Tedd is offline
Old 11-06-2010, 05:34 AM - Thread Starter
Beemer: Right, my biggest concern is for the top bolts to fall out. Some of them are that loose. I don't intend on body slamming the posts in the mean time, so it should be fine.
I don't know if any of you have tried to move a support while it is supporting a house, but it won't budge...even without top and bottom bolts! When I was really cranking on the screws to lift the beam flush with the subfloor, the posts were not rotating. I always gave the posts some test pushes to see how stable they were and they never moved except if the floor was uneven. The bolts help with that issue too -- the post won't rotate if the support is not flat on the floor.
The bottom is secured with Tapcons.
Tedd: I do have a welder. It probably would have taken less time to weld it, but I wanted the ability to remove the post without the use of a grinder. I'm not exactly sure why.
Oh, also the support that I took out that was under the old beam was secured with two nails at the top. Ha ha!
Old 11-06-2010, 07:00 AM
Beemer533's Avatar
I'm sure it will be fine, just don't have a square dance upstairs until everything is secure
I remember reading about your tapcon woes now! They can be a pain sometimes....
Now don't get mad, I know you slaved over all those holes in your beam but I would weld a couple beads on each post and forget about it..... Unless you're planning on taking the beam with you when you move
Old 11-06-2010, 07:17 AM
dbldare's Avatar
I agree. Especially since you are planning on a rotary in there.
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
Old 11-07-2010, 01:50 PM
Beemer533's Avatar
Is the sheetrock up yet?
Sorry, I can't work on my own house for a while, so I'm just making sure somebody else is
Old 11-07-2010, 06:46 PM - Thread Starter
I took one temp wall down today. The new beam didn't sag at all.
I was doing a bit of baby room work. Yesterday was cleaning in prep for a pizza party we threw. We made some amazing pizzas on bricks in my oven on the clean cycle!
Drywall will be going up hopefully sooner rather than later...but it will likely be a couple of weeks.
I found out that since the beam is about .75" lower than the joist, I will be able to mount the whisperclips directly to the joist as the clip plus the hat channel is about 1.375", which gives the drywall about .5" clearance from the beam. That will save me some time.
Old 11-08-2010, 06:26 AM - Thread Starter
Oh, and I realize drywall in a couple of weeks is unrealistic.... It is possible, but not probable.
Old 11-08-2010, 06:57 AM
premiertrussman's Avatar
Quoted: 17 Post(s)
I hate drywall...sell some body parts and hire it done...
_____________________________________
Shades of Grey Theater
Currently Playing: Overwatch/WoW - Legion
premiertrussman is offline
Old 11-08-2010, 06:58 AM
Quoted: 17 Post(s)
I am SO doing that.
Old 11-08-2010, 07:24 AM - Thread Starter
I don't mind drywall at all. I have a collated screw gun that is awesome. I also bought a drywall lift for the ceiling. I don't trust someone to know how to do the clips/dd/gg correctly....since none of them have done that before. I am also not going to mud the walls since I'll have fabric panels on them. I'm debating fabric on the ceiling or at least near the screen -- flat black otherwise and that won't show any minor mistakes.
For pizza, buy "unglazed half height fire bricks" at a specialty brick place. I bought 8 of them for <$10. I disabled my self clean latch so it won't lock the door. I took out just two screws. Check out pizzamaking.com and their forums for people just as obsessed about pizza making as avsforum is for avs junkies! Recommended. I used this recipe for dough and it works great: http://pizzamaking.com/lehmann_nystyle.php I weighed out all the ingredients on a digital scale, put them on the dough setting in a bread machine, put them in the fridge overnight, and it was great. You need to make a peel out of 1/4" ply and you are ready to make great pizzas. I could go on for a bit more. I love to cook and pizzas are one of the world's perfect foods.
Under no circumstances are you to disable your self clean lock. If you do what Andreas suggests, you WILL burn your house down.
In other words, don't sue me for doing what I do.
Old 11-08-2010, 07:59 AM
Quoted: 17 Post(s)
Thank you so much! I am so checking all that out. I had aspirations of building a brick pizza oven on my back porch, since it has a chimney back there not being used...but...i think that maybe a tad ambitious.
Whats the advantage to using the cleaning cycle on your oven? Does it just run hotter than just a regular bake or broil?
Any chance you could post a picture of your bricks and peel?
Old 11-08-2010, 08:08 AM - Thread Starter
I read about the wood fired brick ovens. They look cool. My wife said NO! I agreed though. You can only use it when the weather is nice and it might not fair so well with freezing in the winter.
I recommend trying out the bricks at the hottest setting in your oven at the very least. You need to use a peel to put the pizza in (build it on there). Then to pull it out, use tongs and the peel. My peel is just a 19" x 36" piece of 1/4" ply with one end sharpened (you don't really even need to do that).
Using the self clean setting allows you to get hotter. That is better for thinner crust pizzas. It can get too hot though so you have to turn the self clean cycle on and off. I bought an IR thermometer to see how hot the bricks were getting. I liked them at about 700 degrees. For thicker pizzas >1/4" crust you will want to cook longer at a lower temp.
Old 11-08-2010, 08:46 AM
Quoted: 17 Post(s)
pictures...or they dont exist! Just kidding! So what kind of shop is going to have those kinds of bricks...there are a couple masonry stores around...and a patio & fireplace type store.
Old 11-08-2010, 08:48 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
A very interesting twist on the thread. I'd love to hear more about the bricks also.
__________________
Ted
The Soundproofing Company
Ted White is offline
Old 11-08-2010, 09:19 AM
Quoted: 17 Post(s)
Haha, in the these sort of LOOOONGGGG.....DRAWWWWWNNN out build threads....we need something else to talk about to pass the time.
Just kidding!!! You've been trucking right along lately AM!!!
Old 11-08-2010, 09:29 AM - Thread Starter
Funny that there is an interest in making pizza. I will answer any questions you have.
OK, PT: I will take a couple of pics tonight. It is a very simple setup though! This is where I went to get the bricks: http://www.grimmbldg.com/ They have bricks and building supplies. Just call your local place and ask for "unglazed half height fire bricks". It will be the same thing when I call today asking about hat channel. You could also ask the question: "Do the bricks contain any lead? I will be using them to cook on." I did.
BTW: We had one professional chef and two amateurs (me included) designing the pizzas. These are pizzas we made Saturday night - red: (margherita, linguica (portuguese sausage), linguica/onion/red pepper, "pinwheel"-Italian-sausage/onion/something, spinach/something/otherstuff) white: (pear/gorgonzola/onion/pinenut, clams/arugula)
Other pizza tips: canned whole San Marzano tomatoes (don't use the sauce in the can) with garlic blended with a hand mixer for sauce; provalone and mozzarella +/- romano/parm for cheese
Old 11-08-2010, 09:46 AM
Quoted: 17 Post(s)
So many good pizza tips! I've always wanted to get into making good home made pizza...but never had a good jumping off point.
My buddy in high school had a wood fired pizza oven in their kitchen...it was incredible. (the house wasnt to shabby either)
Old 11-08-2010, 10:33 AM
Vcook's Avatar
looking good, I'm impressed!
Vcook is offline
Old 11-08-2010, 11:46 AM - Thread Starter
I've tried a number of times and it was never even close as good as our favorite pizza place. With the bricks, I can honestly say we made great pizza. It is also fun to be able to put whatever you want on it and not be charged a couple of bucks per topping. I think next time I have a pizza party, I'll make another pizza peel so that I can be prepping the next pizza while one is cooking.
Thanks! I was really happy after pulling down one temp wall. It feels much more open. I can't wait to get the other side down tonight -- I just need 10 minutes. I wanted to do it last night, but we had a birthing class.
Old 11-08-2010, 01:15 PM
Beemer533's Avatar
Man, it never even occured to me to use the self clean feature to make pizza! Not that I clean the oven or anything anyways....
I've been making pizza on my grill for years now and I've been pretty happy with the results.
That is pretty cool idea though, I'm going to try it as soon as I get home, especially since there will probably be snow on top of my grill by the time I get back
Old 11-08-2010, 01:34 PM - Thread Starter
Beemer: Gas or charcoal grill? Do you put it directly on the grate?
I guess it all depends on what type of pizza you want to make. There are different kinds and different methods.
Old 11-08-2010, 03:07 PM
Quoted: 17 Post(s)
AM do you wrap your bricks in tin foil or just cook directly on them? Im really intruiged!
Old 11-08-2010, 06:20 PM - Thread Starter
I cook directly on them just like you would with a wood fired oven.
I took down the other temp wall. YES! No sagging of the beam still, so I call that success.
I connected a water pump, and some tubing under the 1st floor. I'm now testing how well the radiant heat will work through to the kitchen tile. Hopefully it will heat fairly well so I can justify putting radiant heat throughout the 1st floor.
Old 11-08-2010, 06:28 PM
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
The rotary sub is coming along nicely! But I don't understand how you attached the fins?
Nice job on the house BTW.
Subscribed.
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
Old 11-08-2010, 07:13 PM - Thread Starter
JapanDave: I haven't made the rotary sub yet! I'm trying to at least get some walls first.
Temp walls and support gone. You can see the red radiant heat tubing hanging down. I'm thinking it is not going to work since the floor above isn't getting warm.
As promised: the pizza peel and a new fire brick.
The bricks installed in the oven waiting for pizza.
Hughman's Avatar
In light of recent posts I think the rotary sub may be referring to a submarine sandwich, something like this perhaps.
Hughman is offline
