Build log: DIY rotary sub for contemporary HT in 100 year old house? - Page 9 - AVS Forum | Home Theater Discussions And Reviews
post #241 of 1242 Old 11-03-2010, 11:01 AM
fotto's Avatar
Quoted: 21 Post(s)
Man, that just looks like one bone gnawing, jaw grinding project (the beam that is).
I saw in one of your previous pics that you had some temporary supports in place for the joists, but they're missing now on one side. Is it safe to assume that you're planning on re-installing those before cutting joists?
fotto is offline
post #242 of 1242 Old 11-03-2010, 11:04 AM
premiertrussman's Avatar
Quoted: 17 Post(s)
Originally Posted by Beemer533 View Post
Oh, I forgot to ask (you may have mentioned it before) how are you planning on securing the jack posts top plate to the beam?
I think i remember him saying something about chewing gum and duct tape...so long as he could find someone to chew the gum for him....
_____________________________________
Shades of Grey Theater
Currently Playing: Overwatch/WoW - Legion
premiertrussman is offline
post #243 of 1242 Old 11-03-2010, 11:15 AM - Thread Starter
AndreasMergner's Avatar
The jack posts will be secured to the beam with some (wood) lag bolts perhaps? They would be secured into the packed wood since I can't exactly use a nut on the other side any more. I just have to drill a few holes, which is not so bad with a decent bit. I could also weld them in about 1/2 the time. I do have a welder. For some reason I would want them removable. Is that dumb? I mean, you could easily grind off the welds.
Those jacks in the pic are the "temporary" type, so I have not attached them. I have two of the "permanent" type ready to go, but they don't adjust in length -- so will go up only when I get the beam in its final position.
I do have hearing protection and will use it for the nailer...along with eye protection. "Everybody put their Mickey Mouse ears on!" Thanks!
Fotto: I do have the temp walls on both sides of the beam still. You can see them just at the left edge of the pic. I wouldn't want to cut the joists without the temp walls!
Current HT: HTPC-->Epson 5010 projector-->135" screen, BFM TLAHs x7 & THT
Andreas' Slow Rotary Sub build
AndreasMergner is offline
post #244 of 1242 Old 11-03-2010, 02:08 PM - Thread Starter
Received my Green Glue, clips, DC-04s, Silenseal and a couple of other sound isolation supplies courtesy of the SoundProofing Company! Just in time...ok, well quite a bit earlier than I need, but it won't hold me up at all.
It's always fun to receive something in the mail.
post #245 of 1242 Old 11-04-2010, 06:36 AM
Quoted: 17 Post(s)
I know right? Why is it so fun getting something in the mail? Even if its just something stupid...its still exciting...or maybe I'm just easily amused.
post #246 of 1242 Old 11-04-2010, 07:28 AM - Thread Starter
Cutting through the joists this way is tough work. (Sawsall with tight clearances) I wish I had come up with an easier method! I'm hoping to get this beam finished today and my arms/shoulders are already tired....
post #247 of 1242 Old 11-04-2010, 10:22 AM - Thread Starter
I have to go to HD to get some more Sawsall blades. I'm hoping that will make it at least 5 times easier...I hope.
I finally did some tweaking with my THT and Crown XTI amp. Apparently I didn't have the amp bridged. Now I know what the driver sounds like when it bottoms out even with the sub channel turned all the way down on the receiver side. Turned back just a bit and HOLY CRAP that is a lot of LFE. I haven't watched a few popular scenes for LFE since my new AVR. The WOtW lightning scene makes me want to run and hide and it's not even at max.
Do I really need a rotary?
post #248 of 1242 Old 11-04-2010, 10:28 AM
Quoted: 17 Post(s)
hehehehehe! That story makes me giggle. I really want to build mine! Maybe ill sneak in the lumber i need for it when i go get my floor for the riser! Ill have to figure up again how much i need...it seems like it was only two sheets to build it.
post #249 of 1242 Old 11-04-2010, 11:41 AM
Beemer533's Avatar
What kind of question is that
Of course you don't NEED one, but you really SHOULD have one Especially since I am waiting for the build. Now that you said something you must build it!!
Whiskey Tango Foxtrot, Over.....
Beemer533 is online now
post #250 of 1242 Old 11-04-2010, 11:44 AM
Beemer533's Avatar
I think the easiest method is to cut them from above with a worm drive circular saw....
That would be the easiest way if you discount the part where you have to rip up your floor
You know in DIY one small project always leads to 5 or 6 more.
post #251 of 1242 Old 11-04-2010, 11:55 AM - Thread Starter
PT: 2 sheets of 4x8 should do it. I only used two tubes of PL adhesive, but there are others who used something crazy like 8 of them! WAY overboard....
Beemer: Ha ha! I plan on doing/trying the rotary even if it is not needed. I might have to tell my wife that I'm doing something else though. Making a toy for the baby??
Well, new blades made the job about 10 times easier. I have 11 of the 13 joists cut. I left the two that the winches are attached to. That way I can rest and think out how I want to approach them. The winches are still a failsafe support, but I also have 2x8s under the beam along with the jacks.
post #252 of 1242 Old 11-04-2010, 01:23 PM - Thread Starter
All the joists are cut. I would just crank that beam up there, but now I have cut about 50-100 nails that are sticking out from the subfloor. I need to give the shoulders a rest. Damn.
I'm looking forward to trying out that palm nailer. It should be fun for about 10 nails and then it will be work again. Ha ha!
post #253 of 1242 Old 11-04-2010, 05:16 PM - Thread Starter
I pretty much have it up, but there is some wiring in the way that I'll have to move. I wanted to see if I would clear it, but doesn't look like it. I didn't get to the joist hangers, but still happy with the progress.
post #254 of 1242 Old 11-04-2010, 05:32 PM - Thread Starter
The new beam is 8.5" tall and the old beam is 8" tall. To the bottom of the joists is about 6'11", but the joists are only 7.5" tall, so the beam actually hangs down about an inch below the joists. I still gained 7" of height which is a lot when you are comparing 6'10" and 6'3" before floor or ceiling.
post #255 of 1242 Old 11-05-2010, 07:04 AM
Quoted: 17 Post(s)
Definitely worth it. Those are some critical inches to be sure!
post #256 of 1242 Old 11-05-2010, 07:14 AM - Thread Starter
I have to keep telling myself it is worth it! It is only $1000 and 8 days time for a $10k(?) and 6 month(?) project.
Beam is all the way up! I still have joists to hang. I tested my palm nailer and it drives a nail in about 1 second! Hopefully that means it won't take too long to do the joists. I also have to secure the permanent posts. They are in, but without the bolts that prevent you from kicking the posts out from under the beam....not that you can as there is a lot of weight on the posts.
post #257 of 1242 Old 11-05-2010, 07:28 AM
Quoted: 17 Post(s)
Looking great! Thats going to be an awesome feeling getting that project behind you.
post #258 of 1242 Old 11-05-2010, 09:02 AM - Thread Starter
I will be even more excited when I can start framing! Isn't that were most people *start*?? Lucky!
So, I go to HD to pick up lagbolts and Tapcons. I drill a hole in the concrete for the tapcon with the bit that comes with it. I use a hex driver on the drill in hammer mode as the instructions recommend, I get half way in and.....the tapcon breaks. What the...?
I'll try another one, but come on!
post #259 of 1242 Old 11-05-2010, 09:08 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
That is REALLY inspiring!
__________________
Ted
The Soundproofing Company
Ted White is offline
post #260 of 1242 Old 11-05-2010, 09:18 AM - Thread Starter
Ted: the beam, the framing or the Tapcon?
Ok, so I'm 0 for 2 with Tapcons. I'm going to do a search see how to avoid this.
post #261 of 1242 Old 11-05-2010, 09:23 AM - Thread Starter
Ok, so I'm not blowing the hole. Ha ha....and apparently I'm using too long a screw. Oh man, I kill me.
Back to HD again.
How to keep friggin' Tapcons from breaking (my title)
post #262 of 1242 Old 11-05-2010, 09:30 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
I was referring to the beam. Brings back memories...
__________________
Ted
post #263 of 1242 Old 11-05-2010, 09:35 AM
Vcook's Avatar
blow or vacuum out the holes before driving your tapcon in and you'll have better results.
Vcook is offline
post #264 of 1242 Old 11-05-2010, 10:31 AM - Thread Starter
Thanks Ted! Can't wait to start using the Green Glue you've sent.
Vcook: I was born in Chicago. Yes, I blew out the holes and used a shorter tapcon and it was no problem at all.
Now I need to drill into the beam and install the lag bolts before hanging the joists. I think this took about 3 times longer than I thought...which is about how most things go anyway.
post #265 of 1242 Old 11-05-2010, 11:17 AM
Beemer533's Avatar
Man, looking at that beam, I almost feel bad lounging around my hotel room this weekend.... (in Israel the weekned starts on Friday).
That is truly a huge acomplishment! Nobody got killed and your house is still standing, can't ask for more than that
Nice job! Now get working on my, I mean your, rotary sub!? I'm dying here!!
post #266 of 1242 Old 11-05-2010, 11:43 AM - Thread Starter
Thanks Beemer! I have my share of lounging moments too. No rotary until it's time!
I have the posts all nicely secured except the hole for the lag bolts on the top of the posts are positioned just perfectly such that they are between the two 2x8s packing the I beam. Most of them are spinning around freely, so I'll have to get some sort of expanding bolt. Another trip to HD! Woo hoo!
...but I'm going forward with the joist hanging anyway. The posts are not going anywhere. This nailer is the isht! I'm jacking up each joist a small amount before attaching its hanger. I figure the beam will take the weight of joist before it sags too much. It's probably less than 3/32" per joist, but what the heck.
post #267 of 1242 Old 11-05-2010, 11:59 AM
Beemer533's Avatar
Have fun with the palm nailer! Too bad about the bolts spinning, that is annoying.. At that point I would pull out your welder.
Probably a good idea with joists, just don't over jack them.
post #268 of 1242 Old 11-05-2010, 12:21 PM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 83
Looking good Andreas!
AirBenji is offline
post #269 of 1242 Old 11-05-2010, 12:37 PM - Thread Starter
Beemer: I spent the effort to drill the holes, and I'm going to use them, dammit! Making 8 holes straight up through 5/8" of steel is not that fun.
I'm just jacking the joists up a bit. I can see if they are slightly sagging compared with the subfloor above.
The nailer is fun, fun fun. I'm 1/4 done and then I can start removing the temp wall.
Ben: Thanks! Looks like a hell hole in basement in real life, but it's getting closer.
post #270 of 1242 Old 11-05-2010, 12:48 PM
Beemer533's Avatar
I feel your pain! Drilling up over your head is not fun in anything, much less 5/8" steel.
I don't know if you've come up with anything yet, but one option might be to use threaded rod and some sort of epoxy. Just wait for it to dry and put some nuts/washers on the bottom.
That might be a mess though, if the epoxy is runny at all..
You could also drill a hole perpendicular across each vertical hole ( in the 2x8) and use threaded rod with a nut top and bottom.
