Where to install PJ and HT equipment in dedicated theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-28-2010, 07:06 PM - Thread Starter
koberlin1's Avatar
I have been perusing the AVS forum for years and more recently dedicated theater design. After some reading here is what I was thinking of doing regarding equipment and projector locations. I would love any advice from those who have accomplished this successfully.
To preserve the dedicated HT room aesthetics as well as heat and noise levels of the equipment and projector I was thinking of installing the equipment rack and PJ in the rear wall of the theater.
For the the equipment I could leave ~2.5 - 3 ft behind rear wall. No access from behind...just from the front. I have had success with the sliding racks for equipment and assume I would frame out an enclosure to accommodate the height and width I need with a door on the front. Could lift it off the floor so it is centered on the wall. I could cool using Middle Atlantic's CLOSET COOLER system to keep things cool.
For the projector I could frame out an enclosure utilizing the 2.5 - 3 ft space behind rear wall. Perhaps a plexiglass front would help keep fan noise from entering the theater. Middle Atlantic's DUCT COOL system would seem to work well for cooling the projector. I could have it vent to the outside of the building. Not sure if the plexiglass front would inhibit the cooling.
Ideally the theater would have its own dedicated HVAC system so there would be cool air to ventilate through the equipment and projector.
I would run conduit in between projector and equipment rack for cabling and would run speaker and sub cables through framing to front stage area and surround locations. Maybe a conduit run from equipment rack to stage area as well for future cabling (through ceiling joists and down behind the screen).
Thanks for your thoughts on this!
PS Not minor issue topics I know but thought I would mention.... I was planning on a platform floor/seating design with a 12" high (2 step) platform in the back of the theater to accommodate a 3-seat common arm theater sofa then the same 3-seat common arm sofa in front of platform on the rooms floor 10 feet back from a 120" screen (and projector with the needed throw). Aisles down each side, and to keep sound from escaping a foyer type of entry at the side of the theater. Overall interior theater dimensions 20' W by 24' D by 10' T. Have some sound proofing, acoustical treatment, interior design, equipment selection, electrical and lighting ideas in mind as well.
_____________
K
koberlin1 is offline
post #2 of 13 Old 06-28-2010, 07:18 PM
Quoted: 3255 Post(s)
Liked: 2743
A critical element of your plan is the throw ratio specifications of the projector you select. Not all will be happy at 21 ft.
Do you know what projector you would like to use?
Is 120 diagonal or width? a 16:9 or 2.35:1 screen?
Also FYI there is a specialty optical glass you will want to use to separate the projection area from the room, it is not Plexiglas. I don't remember the name.
post #3 of 13 Old 06-28-2010, 08:55 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
I think this is the right stuff -
http://www.edmundoptics.com/onlineca...=1919&search=1
I could be wrong, haven't used it myself.
Also I think you need to tilt the glass at the right angle relative to the screen etc etc....not simple
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #4 of 13 Old 06-28-2010, 09:16 PM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 246
That glass is pretty cheap. Will it degrade the image? I was going to have my projector shooting through a hole in the wall, but if the glass won't hurt the image, I may go that route.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #5 of 13 Old 06-28-2010, 09:48 PM
Liked: 2743
IMHO the current projector offerings are pretty quiet. Putting them in a hush box or adjacent room pointing through a hole with some acoustical absorption on the surrounding surfaces will sufficiently tame the noise without bothering with a piece of glass to separate the spaces.
post #6 of 13 Old 06-28-2010, 10:01 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
Thats the approach I am going to take - aiming to get the sound floor down to around 20db with projector and hvac running (all other gear, except a CD player will be outside the room)
That said I'll be having a small screen and projector probably 92" or 100" 2.35 so I wont have a big, loud projector for that
Peter the Greek
Elill is offline
post #7 of 13 Old 06-29-2010, 11:30 AM - Thread Starter
koberlin1's Avatar
Was leaning towards the Epson Home/Pro Cinema 8100/9100. Specs seem to indicate I can get a 120" 16:9 image at a throw distance of 20' (at 1.25x). I was mistaken when I mentioned the interior room depth at 24'...the interior depth (screen to rear wall) would be 20' but framing would be 24' allowing for 3' behind rear wall and 1' behind screen. The 1' will allow for acoustical boxes to fit around the backside of the in-wall LCR's I would put behind the screen....actually center would be behind the screen and LR's would be wide hidden behind a false wall/flanking columns.
A 120" diagonal 16:9 screen
I agree...just thought it would be nice keeping it out of the room. Also did not know of he specialty glass required. You know of any hush box designs floating out there?
That is nice and quiet! In the past I have used a mini-split for AC and a heat exchange system with insulated duct (with at least 2 90 degree turns in the run) and it has kept my HVAC soundfloor minimal. The vents are the culprits as they force incoming and outgoing air through the vent architecture creating whistling etc.
Thanks for all your help!
_____________
K
post #8 of 13 Old 06-29-2010, 01:56 PM
Liked: 2743
Flaming Ridge has a hush box built into a rear soffit. If you do a search on hush box you should get more hits.
post #9 of 13 Old 06-29-2010, 03:41 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
Originally Posted by koberlin1 View Post
The vents are the culprits as they force incoming and outgoing air through the vent architecture creating whistling etc. Thanks for all your help!
You need to be aiming for 250 cubic feet per minute vent velocity, apparently the Nailor bar diffusers are the go, if you can get em
Peter the Greek
Elill is offline
post #10 of 13 Old 06-29-2010, 05:36 PM - Thread Starter
koberlin1's Avatar
Thanks! Wow Elill just saw your personal theater thread and looks like you are in the thick of it! How is the progress?
_____________
K
post #11 of 13 Old 06-29-2010, 05:59 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
G'day - well I was in the thick of it, its on hold at present as we're getting two puppies in a month or so......the only way I could convince the Mrs to make them sleep outside was to build the mother of all kennels (insulated, sealed doors, solar and wind ventilation, a deck, ramps, waterproofed, it sits on structural supports......blah blah blah
To cut a long story short, my weekends and money have been rediverted. Will start again in September I hope. HVAC and electrical rough-in is next. Oh and I picked up a full size rack for A$1200 (used for 6 weeks, so they say), its got a glass door, casters, vents, fully panneled......couldn't say no to it
I keep changing my mind regarding the design (contemporary or traditional), its doing my head in - not sure how I am going to approach things now
Peter the Greek
Elill is offline
post #12 of 13 Old 06-29-2010, 08:58 PM
GRBoomer's Avatar
250 feet per minute - this is the face velocity through the diffusers to minimize rushing air noise.
Cubic feet per minute is volumetric air flow, which is what you need to calculate the air changes per hour and the BTUs to remove from the room. Rule of thumb 6-9 ACH which is similar to the exchange rate for a kitchen. Once you get the air exchanges based on the volume of the room then you can calculate the airflow (CFM) requirements, then add enough diffuser face area to reduce the face velocity to 250 fpm.
GRBoomer is offline
post #13 of 13 Old 07-01-2010, 01:57 PM - Thread Starter
koberlin1's Avatar
wow your puppies are gonna have some nice digs! Been looking at suspended ceilings and they offer some great design apps...easy to install and big impact. Will leave the HVAC to the experts..
_____________
K
