Brown color scheme for home theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 07-29-2010, 07:15 PM - Thread Starter
randyox's Avatar
Drywall is done and I am ready to paint...I want to go with dark brown colors...and am open to any and all suggestions of what people on the forum have done as far as paint for the walls and ceiling... Name brand, color name and etc... Thanks in advance for all the help!
randyox is offline
post #2 of 14 Old 07-29-2010, 07:44 PM
Quoted: 3898 Post(s)
Liked: 3333
Doesn't get much browner than this current Dennis Erskine project:
http://www.avsforum.com/avs-vb/showthread.php?t=1256130
You will have to wait to see the carpet picked out by the interior designer.
There are some brown theaters in the "show Us your color scheme" thread:
http://www.avsforum.com/avs-vb/showt...highlight=show
post #3 of 14 Old 07-29-2010, 08:17 PM
Leifashley27's Avatar
I ended up going with an ICI paint color called "Stewart House Brown" in my little room. (nothing compared to any of the other rooms on here)
It's much darker than this in person but I probably would have gone flat instead of eggshell on the sheen.
I wrote a little blog on picking paint colors if you're interested.
http://www.stuffthatplugsin.com/home...e-be-no-light/
Leifashley27 is offline
post #4 of 14 Old 07-29-2010, 10:38 PM
Drew_V's Avatar
The problem with flat paint is that if you rub up against it, it leaves a mark that doesn't come off (it changes the sheen). Then you have to repaint that area. With eggshell, you can wipe it off by washing the area gently. You rarely have to repaint an area unless it's a significant mark.
I doubt I'd use a flat paint in a room where people could be walking around in the darkness and putting their hands on the walls to find their way around. Those walls would be marked up in no time.
--Drew
My basement theater build thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1243820
Started: 2/20/10
Completed: 10/10/10
Drew_V is offline
post #5 of 14 Old 07-30-2010, 12:43 AM
Elill's Avatar
Quoted: 109 Post(s)
Liked: 91
Harsh!
Apparently its not brown....well not entirely - that said I think it looks good. The carpet will make or break it
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #6 of 14 Old 07-30-2010, 01:20 AM
huntrm's Avatar
Click on my signature. Small 12x15 theater, but very cozy. I used a brown fabric with a lower black fabric. Ceiling is flat black.
huntrm is offline
post #7 of 14 Old 07-30-2010, 04:33 AM
carboranadum's Avatar
Quoted: 22 Post(s)
Liked: 26
Cathan used browns in his theater and it looks wonderful. Check out his thread here:
http://www.avsforum.com/avs-vb/showthread.php?t=850462
carboranadum is offline
post #8 of 14 Old 07-30-2010, 06:17 AM
fotto's Avatar
Quoted: 21 Post(s)
I'm also doing various shades of brown in my build (see page 11). The walls (darker area) have a faux leather technique. You can see the lighter first coat on the wall in the middle between columns. I didn't paint that area as I will have GOM Poppy colored acoustic panels between the columns with some wall reveal around those.
fotto is offline
post #9 of 14 Old 07-30-2010, 06:41 AM
Dixon's Avatar
My room is primarily a dark olive color, but I have a brown ceiling, brown carpet, brownish trim and brown couches.
http://www.avsforum.com/avs-vb/showthread.php?t=1264923
Dixon is offline
post #10 of 14 Old 07-30-2010, 10:22 AM
defrederickjr's Avatar
We went all brown too, and we love it. Here are a couple of not so great pictures (see my sig for more in the thread)...
I don't remember the brand, but I think one of the colors was called Bison Brown. Don't recall if that was the walls or the ceiling. (wow, I'm a lot of help, huh?) Probably doesn't matter 'cause you can barely tell the difference between them. I do wish the ceiling was a bit darker, or at least enough to see the difference.
defrederickjr is offline
post #11 of 14 Old 07-30-2010, 01:04 PM
Jedi's Avatar
Quoted: 43 Post(s)
Liked: 30
....for acoustical fabric I used GOM Anchorage Coffee Bean. Its a very rich, deep dark brown solid with woven texture.
Are Eleven Channels Really Enough?
Jedi is offline
post #12 of 14 Old 08-20-2012, 10:43 PM
cdika17's Avatar
Anymore brown color scheme's out there?
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #13 of 14 Old 08-20-2012, 10:52 PM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
Mine is pretty much all brown with some red tint to it...
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #14 of 14 Old 08-21-2012, 01:32 PM
BroncoSport's Avatar
My theater has brown GOM below the oak chair rail. And when I can afford the seating they will be brown leather!
Click on the link in my signature to see the pics.
BroncoSport is offline
