Cyclone Cinema Build - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #541 of 587 Old 11-06-2013, 01:52 PM
donjuanwater's Avatar
Nice thread and great build.
Couple of questions on your status of things:
1. How did you like the Jamestown Screen. Is it holding up? Any negative issues?
2. How did you make out with the damaged laminate floor and the fix for it?
3. I don't remember any photos of yout THTLP build, can you post pictures?
4. Where did you end up putting your two subwoofers? Can you post pictures of the locations?
donjuanwater is offline
post #542 of 587 Old 11-06-2013, 03:48 PM
nickbuol's Avatar
Quoted: 553 Post(s)
Liked: 613
I can answer #4. He just recently placed one in the back of the room and one up front. Both will end up front though...
OK. I am sure that he can answer more specifically than that.
nickbuol is offline
post #543 of 587 Old 11-06-2013, 06:56 PM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
Thanks for helping Nick. You are correct, one subwoofer (the THT) is up front behind the screen. My other sub (currently a BIC) is in the back right corner of the room. I have the driver sitting in my garage waiting for the second THT to be built - I just havent gotten around to it yet. I will do a better job of documenting the process this next time around.
To answer your other questions...
1: Although it took longer to receive the screen than I would have liked, it has worked perfectly. In fact, I have pulled the screen down multiple times to adjust something (or just to show visitors). It comes down, and goes back up easily - and it has always stayed square and tight. Overall, I am VERY happy with the screen.
2: I actually haven't fixed the laminate yet. We had our first child in February and she is keeping us busy. If I wouldn't have to uninstall the quartz countertop and cabinet, I probably would have done it already. If/when I do decide to fix it, I will take a bunch of pictures.
3: There might be one or two pictures from my first THTLP build somewhere in this thread, but as I stated above, I will do a much better job this next time around documenting the process.
4. Nick was correct that I will be putting them both behind the screen when the second one is complete. They are just too big to have out in the open - plus I have room behind the screen, so it makes sense in my situation.
If you have any more questions I would be happy to answer them.
brausch is offline
post #544 of 587 Old 01-14-2014, 01:07 PM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 236
Brian,
I thought I would give your thread a bump and wish you a Happy Belated New Year! Hope all is well?
It's been a number of months since we compared notes.
Sending you a PM in a few minutes.
Cuzed2
CuznEddy Cinema
cuzed2 is online now
post #545 of 587 Old 01-14-2014, 02:52 PM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
Quote:Originally Posted by cuzed2
Brian,
Cuzed,
All is well and good out here in Iowa. Hope you are doing fine as well.
Thanks for bumping my thread, I have been neglecting it lately. Because of the bump I thought I would give a quick update on my recent projects (unfortunately none of which are HT related).
First, a bearing on our front load wash machine went out, so we were forced to replace that unit. That snowballed into a new wash machine and dryer (they have to match you know), and while they were moved out we decided to tile the laundry room floor.
Those with a keen eye above will note the poker table turned into a baby changing table...the things a guy will do for his kid...
The nice part of having the laundry room floor tiled is that I can continue to tinker with the room over the course of this next year. I need to make some storage cabinets, get some countertops installed and get the sink hooked up (all of which were put on hold while waiting for some time to tile the floor).
After the tile project was complete I moved onto a painting job. My wife and I have been promising each other a king size bed for years now and finally pulled the trigger as a Christmas present to each other. We found a clearance bedframe at Homemakers, but it was stained wood and beat up (both dealbreakers for my wife). We ended up buying the bedframe on the condition that I fix it up and paint it....which was great for me because it allowed me to buy another tool - I am now the proud owner of a Titan Advantage 400 airless sprayer! I was torn between a HVLP and an airless sprayer - both had their own merits but I ultimately went with the airless mainly for future projects.
Because the transfer efficiency of airless sprayers can be less than ideal, I was forced to install a "paint booth" in my garage. It seemed like a pain to build, but worked great.
Here is the bedframe before 6 hours of sanding, wood filling and resanding...
Here is a picture of the frame in the paint booth after 1 coat of primer...
...and here is the finished product...
The tiling and bedframe were completed over the holidays during the short periods we were not on the road. I also painted two ugly nightstands - which now look okay. For my last project, my coworker (who helped me tile) wanted to build a built-in entertainment center for his home. I wasn't about to tell him no after he helped me tile (plus I enjoy this type of thing) so we got busy this past weekend and built it last Saturday and part of Sunday.
Nothing too fancy, but it turned out nicely. All shelves are dado'd and the back panel of the center section is inset 2" in dados to hide wiring.
I am now in the process of painting two old end tables to be used next to our bed, they have been sanded and have one coat of primer but are still waiting for paint.
brausch is offline
post #546 of 587 Old 01-14-2014, 04:27 PM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
Looks good. Can I spend a few hours in your paint booth some time? biggrin.gif
NickTheGreat is offline
post #547 of 587 Old 01-14-2014, 06:50 PM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
Anything for an Iowa State fan!
brausch is offline
post #548 of 587 Old 01-15-2014, 10:14 AM
GWCR's Avatar
Quoted: 17 Post(s)
Liked: 39
I thought I remembered seeing a video of your "bearing" going out...
Washing Machine
GWCR is offline
post #549 of 587 Old 01-15-2014, 10:18 AM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 236
Brian,
VERY Nice job on the headboard and entertainment center projects!
So for your laundry room Saga:
I'll bet that bearing failure was on 5~7yr old whirlpool Duet?
Looks like I will be shuttling between Ames and DesMoines for the long MLK weekend.
Helping my brother in DSM pre-wire his basement man-cave remodel, and will be borrowing my son from ISU to help pull wire biggrin.gif
Cuzed2
CuznEddy Cinema
post #550 of 587 Old 01-15-2014, 07:10 PM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
Washing Machine
Wow. I didn't have to fix any drywall in the laundry room so thankfully mine didn't go like that.
Originally Posted by cuzed2 View Post
Brian,
Cuzed, thanks for the kind words.
The washer was indeed a whirpool, but it was there when we bought the house. Very well could be from that time period though. I kicked around the idea of tearing it apart to fix it, but decided it probably wasn't worth my time.
As for your trip to Des Moines, if you run into some free time, you are more than welcome to stop by and check out the theater. I will be helping a buddy finish his basement bathroom remodel on Friday night and Saturday, but I should be free all day Sunday. Feel free to bring your son along, Cyclone fans are always welcome! Send me a PM and I will get you my phone number and address if you are interested.
Also, I am sure you have it covered, but if you end up forgetting any tools and need to borrow something, just holler.
brausch is offline
post #551 of 587 Old 01-16-2014, 07:33 AM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 236
Brian,
Very generous of you; and hopefully our work schedule will allow us to have a quick stop-by, at least a chance to meet.
Right now I have a vehicle very full of tools and equipment (hopefully I have all of our needs covered).
I'll be sending you a PM when I have a better feel for our timeline - Thanks Again!
Cuzed2
CuznEddy Cinema
post #552 of 587 Old 06-09-2014, 06:23 PM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
Well it's been quite awhile since I have posted last - I guess that happens when there is no theater progress. Aside from raising a little one, I have been keeping busy with some side projects (unfortunately not in the theater).
Some updates - in the order of completion since my last post.
First I tiled a buddies basement floor with a friend (the buddy we were doing this for was in another state for army officer training). This was also the basement that I helped frame, wire and drywall. The floor had a big slope to a floor drain in the adjacent storage room, so we had to first level the floor. In the future I will build a custom transition from the tile floor to the storage room floor.
Dried leveler the next morning
Bathroom before grout
Start of the main room
Finished product
It's a lot of work, but very gratifying to see the final product.
The next project was a built in storage system for my sister-in-law that lives nearby. This was a Christmas present from my wife and me to them - I just didn't get it completed until March.
Main closet
Small closet
You can't really see from the pictures, but the shelves are dado'd into the main vertical support. The shelves were all pre-painted with my airless sprayer with the fine finish tip (it just does such a great job - much better than a brush or roller). Everything went pretty smoothly with the exception of the bulging plaster walls.
The last project I have been working on has been planned since we have owned our house. While I was finishing my basement, we also converted the open master dining/living room into two separate rooms. This allowed us to make a nice laundry room where the master dining room had originally been (that we have never intended to use). During this process, I roughed in the dryer vent, domestic water and drains for the laundry in addition to a rough in for an additional sink for the laundry room.
Here is the framing for the "sink"
The sink is actually a terazzo mop basin...
There will be tile all around the mop basin. You can also see the rough in's for the sink trim. We are doing a shower head on an adjustable rail on the wall to the right, and a typical mop basin faucet on the back wall.
The next part of the laundry room project is the cabinets. I got some very preliminary pricing for cabinets and they were going to be WAY more than I wanted to spend, so I decided to build my own (still trying to decide if that was a good idea!)
Here is our daughter inspecting the pile of plywood
Here is the start of one of the two main storage cabinets. I have dado'd the small compartment for adjustable shelving.
Here is the upper cabinet that will be located between the two main cabinets
Here is a picture of how I attached the face frame to one of the large cabinets. I think the dado's on only one side of the plywood released some stresses in the wood and caused a slight bow in the panel. I clamped a 6' level to the panel before attaching the face frame.
The three main cabinets that will be located on the wall opposite the mop basin and W/D
Pieces cut for the shaker style doors
Quite a bit of table saw work, as I don't have a bit set to make these with the router
One of the doors for the center cabinets
I think I have some wimpy clamps...
A couple of the big cabinet doors
Here are the three doors for one of the main cabinets. I used poplar for all portions of the cabinet. The plywood was really nice, but the hardwood lumber left a lot to be desired. Almost every piece had a twist, or a bow, or was wavy. It was a real pain to try to find boards good enough to use for the doors (and face frames).
Here is the only picture showing the set of drawers I will use next to the W/D, it is still waiting for a face frame in this picture. You can also see in this picture the upper cabinet for above the W/D.
While building the cabinets I needed to build some door jamb extensions for a couple doors for my buddies house. I wanted to get these done before I started to paint my cabinets, as they needed to be re-primed.
This past Sunday there was no wind, so I started priming. Here are the two doors having the jamb extensions primed.
Here is one picture of the priming process
One thing I did not anticipate was the bird poop from the robins flying overhead...some of them missed...while others were direct hits...
As of right now all components have had one coat of primer applied. I have the doors sanded down and have to sand the cabinets at some point this week. While sanding the primer, I found that there was a little color showing through the first coat of primer, so it looks like everything will need another coat of primer before I start with the real paint. It's unfortunate, because its a lot of work, but I guess its better to do it right the first time instead of having that color show through after the cabinets are installed in the laundry room.
Theater related update.
One of the next things I would like to do is work on measuring my room with REW (BEFORE I build sound treatments). I have a UMIK, but I cant seem to get the levels set correctly. If anyone in the DM metro area has an SPL meter that I could borrow, I would appreciate it (even better if they have a microphone that I could use to test against mine).
The results from my meter have never seemed correct, and a whole lot of doubt surrounds that microphone after the troubles they had with my release of mics. It could also be an incorrect set up on my part in the REW software too...
I also have all the components available for a second THTLP (amp driver, etc) but I will not be starting that until the laundry room is complete (or at least until I am at a stopping point)
Last edited by brausch; 02-11-2015 at 07:26 PM. Reason: Fixed the broken picture links...
brausch is offline
post #553 of 587 Old 06-10-2014, 09:17 AM
Quoted: 381 Post(s)
Liked: 255
post #554 of 587 Old 06-14-2014, 02:19 PM
nickbuol's Avatar
Quoted: 553 Post(s)
Liked: 613
Has something happened since the forum upgrade? I can't see your pictures brausch.
Not liking this update at all yet...
Mfusick likes this.
nickbuol is offline
post #555 of 587 Old 06-16-2014, 09:54 AM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
Nick,
I don't know what happened. Some of the pictures work, some don't.
It's a shame...that last update was picture intensive! I will fix the links later if necessary. Everything seems to be really slow with this update.
Although I am not a fan of this update, I wasn't a fan of the previous update either. I wish they would go back a couple revisions.
Mfusick likes this.
brausch is offline
post #556 of 587 Old 02-11-2015, 07:28 PM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
I have finally updated my posts to fix the broken picture links in posts 531, 545 and 552. Not sure what happened, but they should be fixed now. Let me know if any aren't showing up and I will get them fixed.
Finished laundry room update coming soon...
brausch is offline
post #557 of 587 Old 02-11-2015, 07:37 PM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
Here is the latest laundry room update. This room is now finished - finally!
Tile starting around the mop basin
Finished tile with sink/shower trim installed
Sample paint colors
Opposite wall of the laundry room
Photo showing both sides and the quick herb shelf I made for the wife
Here you can see how the washer and dryer fit. You can also see the three drawer base cabinet I built in this photo.
Two panoramic iphone photos (not the greatest quality, but they give a good idea of the finished product)
A few nice options in this room are the quartz countertops and the undercabinet LED lighting. The LED lighting each have a dedicated switch. Both circuits have a dimmer mounted under the upper cabinets. My wife is absolutely in love with this room. It has also given us some great storage space that we didn't previously have.
brausch is offline
post #558 of 587 Old 02-11-2015, 07:56 PM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
I am on a roll, so I am going to finish up posting pictures and will be caught up to my (almost) current progress.
After finishing the laundry room, I transitioned my work back down to the basement. We have a living room area in the basement that was never quite finished. To finish the room, we had always planned on building a custom built-in in a small alcove. The alcove was present because of the need to hide existing sanitary piping installed during the original construction of the house.
Because of the 90 degree turn on the stairwell down into the basement, I had to stick build this built in. Everything was cut to size in the garage and carried downstair for assembly.
Here is the start of the built-in.
Doors built and ready for hinge installation. I took this picture to show the tight construction of my shaker door frames - the laundry room frames had gaps - where the doors pictured below turned out perfect
Hinges installed
Doors installed
Floating shelves installed
I mentioned that this post ALMOST brings me up to date. My wife has painted this built-in, but I do not have any pictures of the final product at the moment. There will obviously be a TV installed between the floating shelves, we just have not purchased one yet. I will need to cut in a power outlet behind the TV and also install a low voltage box to route the wires from behind the TV to inside the built-in.
And now, finally, a theater related update!
I have also built a second THTLP and installed it behind the screen!
I have not even had a chance to EQ anything yet, but its finally built and back there. I do need to paint it one of these days, as you can see it behind my screenwall if the lighting is right.
There is a possibility that I may be hosting a stop for the central Iowa theater crawl in March, so I hope to get things EQ'd prior to that date. I will need to do quite a bit of research to do this, as I am very unfamiliar with anything other than running Audyssey Multeq XT32 and hoping things are halfway decent. I have a UMIK, but it was from one of the early batches and I am not sure I have it working correctly.
If anyone has a good starter thread that I should reference when figuring out REW and my UMIK, I would appreciate the direction.
brausch is offline
post #559 of 587 Old 02-12-2015, 09:38 AM
Quoted: 381 Post(s)
Liked: 255
Wow! You've been busy
I like the laundry room. My wife's subtle nudging about redoing ours are becoming less nudge-like every day.
post #560 of 587 Old 02-12-2015, 10:09 AM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
Grabbed a quick picture of the painted built-in last night.
brausch is offline
post #561 of 587 Old 02-12-2015, 11:26 AM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 236
Brain,
That's quite the "catching-up" posting! There is no way I can show my wife your thread - that laundry room is over the top, and I would never hear the end of it .
I would love to make a trip to your neck of the woods, and seek an invite (barge in) on that crawl, AND help you with REW. My excuse would have been to see my son at ISU for spring break.
However looks like his spring break is earlier in March, and would not align/allow for my cover story. However; should I end up making a trip to retrieve or deliver him back to Ames > I'll drop you a note to offer REW assistance.
Keep up the good work, and keep posting these updates
Cheers!
Cuzed2
CuznEddy Cinema
post #562 of 587 Old 02-13-2015, 09:10 AM
Quoted: 34 Post(s)
Liked: 4
I just went through every page of your build. Wow, it looks amazing. All I know is that I won't be showing my wife hose pictures of your laundry room. I don't need another project added to the list.
EricBurns is offline
post #563 of 587 Old 02-13-2015, 02:21 PM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
Brain,
Cheers!
Thanks Cuzed. Let me know when you are in town - you are more than welcome to swing by and check the place out...any REW assistance is a bonus!
Eric, every page? That sounds exhausting! Thanks for taking the time to post. I am glad you enjoyed the thread.
brausch is offline
post #564 of 587 Old 02-16-2015, 04:45 AM
Quoted: 34 Post(s)
Liked: 4
I have quite a bit of time at work to fill as this is our slow time. I especially like how you did all your own woodworking. I have to get my shop going just to keep all the dust contained to the basement.
Again, very impressive work!
post #565 of 587 Old 03-24-2015, 07:57 AM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
I finally pulled the trigger on something I had been putting off for a long time - a door seal set for my theater room door.
Here is the box it came in
It was shipped with a piece of 1X4 to prevent bending
Here are all the pieces
And here is how I cut the aluminum.
I was worried about using my tablesaw to cut the aluminum, as I have never done it before. It turns out I was worried for no reason, the aluminum cut just like oak.
Here is a picture of the pieces installed.
I had hoped to take before/after measurements outside the room, but my UMIK is untrustworthy at the moment. I can, however, say that is actually makes a pretty big difference - surprising, actually.
I ended up going with the 870 door seal system, instead of the beefier 770 system. The STC of the 870 is 49 vs the STC 52 for the 770. From some quick research, I think my 1.75" solid core door only has an STC of 31. For that reason, I decided to go with the $100 cheaper 870 system. I am very happy with me decision, and very happy with the results.
There seems to be a fine line between getting enough pressure on the top/sides to stop the sound, but still be able to easily latch the door. The automatic door bottom was a breeze to install and adjust - and it works like a charm.
I plan on taking these back off and painting them to blend into the door frame.
brausch is offline
post #566 of 587 Old 03-24-2015, 09:43 AM
thrillcat's Avatar
Quoted: 172 Post(s)
Liked: 233
Why do I feel that you perhaps spent from the same pool of extra cash that I suddenly have lying around - i.e. "The Indianapolis Trip" fund?
Where did you order it from?
I love my iPhone, but it will never replace my turntable.
The Cinema 1858 Remodel Thread
thrillcat is online now
post #567 of 587 Old 03-24-2015, 10:05 AM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
Thrillcat,
Maybe it was a blessing in disguise that the Cyclones lost...because you are correct, I WOULD have made the trip to Indy if they made it that far - and I am sure that would have been expensive. Even the Kansas City trip for the B12 tournament got expensive.
I ordered the seal kit from The Soundproofing Company. I have a 32" door and the 36" seal can only be trimmed up to 2", so I think it may have had to be custom made. Just something to think about if anyone who is reading along is thinking about buying an automatic door bottom.
brausch is offline
post #568 of 587 Old 03-24-2015, 10:09 AM
thrillcat's Avatar
Quoted: 172 Post(s)
Liked: 233
Thrillcat,
I ended up selling my B12 tourney tickets since we went to Mexico last week and would've had to miss the championship game. That money was added to the fund that I had been putting away. Was still in Mexico when they blurped out against UAB.
My summer projects primarily focus on soundproofing, and I'm looking at doors and seals...so this is good info. Thanks!
post #569 of 587 Old 03-25-2015, 09:55 AM
Quoted: 381 Post(s)
Liked: 255
You guys ruined it for us all!
thrillcat likes this.
post #570 of 587 Old 06-03-2015, 08:30 PM - Thread Starter
brausch's Avatar
Quoted: 14 Post(s)
I have been playing around my woodshop the past month, mostly testing my abilities. My old bag toss game is over 10 years old and was in need of replacement, so the replacement became my guinea pig project.
I could go into details, but here is the final product instead.
They consist of a walnut plywood top dovetailed into solid hard maple sides with a circular maple inlay. The legs are laminated solid walnut between hard maple with a mortise and tenon stringer between the legs.
Finish was a coat of BLO, a topcoat of dewaxed shellac followed by 6 coats of waterbased poly.
I am pretty happy with how they turned out, but in the future I would have used an oil based topcoat instead of the water based - as it washed out some of the color in the final coats.
nickbuol and kjlewie like this.
brausch is offline
