need for supply/return with a mini-split system? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 08-16-2010, 12:21 PM - Thread Starter
docquest's Avatar
Would you need an air return supply on a room that you were planning to install a mini-split AC system in? Our home uses baseboard heating so we don't have central A/C or it associated ductwork. To cool our basement theater I'm planning on putting in a mini-split A/C unit. To minimize sound leakage and intrusion I'd like to avoid putting in air supply/return lines in the room. I figure I can just leave the door open when its not in use to get fresh air in the room. Should that be adequate?
docquest is offline
post #2 of 16 Old 08-16-2010, 12:31 PM
ithunter's Avatar
A mini split is a ductless system...basically a really nice window unit minus the window....it does have a line set that will need access to the condensing unit and most folks put those outside...
ithunter is offline
post #3 of 16 Old 08-16-2010, 01:12 PM
Quoted: 3255 Post(s)
Liked: 2743
What do you get when take a well built air tight theater space, a mini-split and a half a dozen people?
Answer: dead people, there is no fresh air.
post #4 of 16 Old 08-16-2010, 01:18 PM
3fingerbrown's Avatar
check out my build thread in my signature for how I tackled the problem of adding a return air fan to a room that had two supply vents and no return. For the most part I was able to add my return vent using sound isolation techniques. Good luck!
3fingerbrown is offline
post #5 of 16 Old 08-16-2010, 06:32 PM
snickel's Avatar
What he said^^^ you need to get fresh air in your room
snickel is offline
post #6 of 16 Old 08-17-2010, 07:53 AM - Thread Starter
docquest's Avatar
Thanks for the feedback. Luckily I have easy access to adjoining rooms so adding a supply and a return shouldn't be too hard. I don't want to be in the headlines about the family that trapped in their own home theater like a bunch of coal miners. I just need to do it right so I don't negate all the effort of the double drywall, green glue, clips, etc. So for a 12x18x7.5 sized room do you think a reutn and a supply that were both 6" flexible insulated duct with a serpentine path would be enough?
docquest is offline
post #7 of 16 Old 08-17-2010, 10:34 AM - Thread Starter
docquest's Avatar
Talk about perfect timing. I just saw the thread on examples of dead vents. I thought I researched all aspects of my theater build but I guess I missed the dead vents topic. The amount of knowledge and info sharing here is just fantastic.
docquest is offline
post #8 of 16 Old 08-17-2010, 07:41 PM
snickel's Avatar
nope a 6" supply would need a 8" return air to remove same amount of air. I would start with 2 7" supplys and a 12" return air, and you may need more.
snickel is offline
post #9 of 16 Old 08-17-2010, 07:49 PM
snickel's Avatar
Ok I was wrong you said you had no ac so you are just using the dead vents for fresh air so yes a 6" supply and a 6" return air will work
snickel is offline
post #10 of 16 Old 01-19-2011, 06:09 PM
uscmatt99's Avatar
I just found this thread while searching for ideal minisplit systems to use for my theater. I've been working with the HVAC guy doing the rest of my house, and we concluded that a minisplit system would be the easiest way to cool the theater room while allowing heat to the rest of the house for our cool Michigan winters.
Unfortunately neither the builder or the HVAC guy have done theater rooms with the degree of sound isolation we have planned. Glad I found this thread, or I wouldn't have been around to tell you all how my theater turned out! I'm going to work with them on designing a dead vent system for the room.
On another note, after a long discussion, it looked like it was going to be a royal pain to take a zone off of the rest of the HVAC to adequately cool the room, so we're still going with a minisplit. Any brand recommendations for the quietest system? The best I found was a Sanyo that was at around 25-38 dB depending on fan speed.
uscmatt99 is offline
post #11 of 16 Old 06-16-2014, 12:28 PM
BrolicBeast's Avatar
Quoted: 1088 Post(s)
Liked: 1129
I guess this answers the mini-split v.s. dead vent debate.
Dead Vent it is.
BrolicBeast is online now
post #12 of 16 Old 06-16-2014, 12:48 PM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
I'll be using a Ducted mini-split, so that I can also use it to bring in fresh air. It also gets the fan noise out of the room.
LeBon is offline
post #13 of 16 Old 06-16-2014, 02:10 PM
kmhvball's Avatar
Quoted: 496 Post(s)
Liked: 275
I am planning a Mini-Split for the Heating/Cooling Needs, and am doing a separate dead vent type 'air supply' into the room for fresh air.
I didn't want to tap into my main system for sound concerns.
I am still figuring out the Air Return, I will use my current system, there are a few 90 degree bends before the main supply lines. I just now need to do research on 'how' to tap into a Return!
Kevin
kmhvball is offline
post #14 of 16 Old 06-16-2014, 05:14 PM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
The air handler for the ducted mini-split is separate from your "main" system. You can run the supply and return from the duct mini-split air handler through dead vents to control sound. You can also pull in outside sir to the air handler for fresh air.
LeBon is offline
post #15 of 16 Old 02-09-2015, 08:34 AM
Liked: 0
Do you have pictures of how you build your set up LeBon? I am deciding between a wall head unit Easy install) and a ducted Mitsubishi set up via dead vents. I welcome any input.
Bongani is offline
post #16 of 16 Old 02-09-2015, 08:51 AM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
I don't have pictures, execpt of the soffit vents in my build thread. My system is new construction, and it is fairly elaborate. The split air handler is mounted in the attic, along with a small dehumidifier. The ducting is all flexible duct. The main supply and return are 12" diam, and they split to 2 10" supplies (in the front soffit) and 2 10" returns in the rear soffit. The registers are 4" x 48" bar-grille type. My room is about 19' x 22' x 9'. The unit is a 12000 BTU/hr. heat pump. The climate here is very temperate, so we don't need a lot of capacity. (My main system has no A/C cooling.)
LeBon is offline
