Review this alternative to attic fan thermostat... - AVS Forum | Home Theater Discussions And Reviews
Old 08-23-2010, 01:23 PM - Thread Starter
Robert_S's Avatar
I am installing a bathroom fan system to vent out my equipment room. I have seen several people use attic fan thermostats to turn the fan on/off based on temp in the equipment area. Those attic fan thermostats are ugly since they are made for the attic.
I came across line voltage thermostats for cooling systems. Here are the two main ones I have found that look viable:
http://www.drillspot.com/products/13...Thermostat?s=1
http://www.amazon.com/Lux-Products-V.../dp/B000E7BTFO
Does anyone have any experience with these?
Do you think they would work in place of the attic fan thermostats?
Robert
Robert_S is offline
Old 08-23-2010, 03:34 PM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 236
Robert_S,
I'm one of those guys that used the attic thermostat. I wish I had seen this link for the robertshaw unit first. Looks to me like it will do the job.
Cuzed2
CuznEddy Cinema
cuzed2 is offline
Old 08-23-2010, 03:48 PM
[OC]Pik4chu's Avatar
Ive used one similar to the Lux model, no idea which one it is since its just a plain box but it worked very nicely. Pretty easy to install given Im no electrician. I use it in my 'server room' in my basement to vent hot air out a basement window. It looks very professional and clean.
[OC]Pik4chu is offline
